Question about Hotpoint Refrigerators
Hotpoint fridge freezer FF71P
Top of fridge is freezing even when it is turned down.I have a new thermal fuse but cannot locate where it goes,any Ideas? thanks Les Phillips.
5 Suggested Answers
  • 1462 Answers
SOURCE: Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
Posted on May 07, 2007
  • 17 Answers
SOURCE: fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Posted on Dec 10, 2007
  • 125 Answers
SOURCE: Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Posted on Feb 07, 2008
22yooper
  • 828 Answers
SOURCE: ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
Posted on May 18, 2008
WeListen2You
  • 538 Answers
SOURCE: Hotpoint Fridge freezing the food.
thermostat is buried behind the walls of that unit, are you ready to run this one..takes quite a bit of time..but
will get the item, if you can supply the actual serial number from inside or back of that unit..
Posted on Oct 26, 2008
Everything on top shelf of fridge freezes even on lowest temperature
you should send model number,if you have a damper control in your model most likely this is the problem,all that happens is cold air blows over from the freezer from the evaporator fan and blows through the top section of the fridge side,if the damper door isn't closing all the way it will cause freezing in the fridge section.
Nov 25, 2013 | Hotpoint Refrigerators
WHERE IS THE THERMOSTAT ON HOTPOINT FRIDGE FFA60
i have a hot point,side by side,little old but great fridge.It is located where adjustments are you can hear it click when you turn it up or down but their is a element in freezer like a big fuse that gets hot and defrosts the coils behind the plastic in freezer.if it is out it will cause unit to freeze up and it will not cool properly.I replaced mine and man what a difference.At first icecream would sometimes be ok then not.if you turn fridge down for while then turn it back up and hear a click then it starts to run its the element in freezer
May 25, 2012 | Hotpoint Refrigerators
Water Leak
1) make sure the drain on the floor in the back inside is clear of food and not fill with frozen water. If it is, pour hot water through it to clear.
2) that drain hose drains water down to a pan under the unit that should be evaporating from the heat of the compressor, but lately with all the humidity we've had, it may be playing catch up with itself.
3 Keep doors closed as much as possible
4) check and make sure door seals are tight.
Jul 16, 2010 | Hotpoint FFM70 Bottom Freezer Refrigerator
Hotpoint RLA30s Freezing!
check the ptc overload relay it could have stuck and is supplying power to the compressor all the time even if the thermostat is off,its on the compressor body where the wires go to the compressor
May 11, 2010 | Hotpoint RLA30 Compact Refrigerator
My is SxS fridge is warm on top & freezing on bottom- both sides
there is a computer board part number WR55X10942 ,if you're in front of the fridge it's on the left hand side down near the bottom,
Mar 21, 2010 | Hotpoint HSS25GFP Side by Side...
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Freezer comparment will freeze OK, but fridge does not get cold.
If the freezer is working properly, and the fridge is not, it is usually the evaporator fan. It should be located behind the back panel in the freezer. Usually, a fan blade is stuck, or the motor is stuck on it's bearing. You may need to reposition the fan or apply some oil to the bearing. If you cannot get the fan to spin, you might need a new fan motor. Check the voltage first before buying a new motor. You should get around 110V AC .
Dec 31, 2008 | Hotpoint  16.6 Cu. Ft. Top-Freezer...
Hotpoint rfa18 Fridge Freezer
Is the back wall full of frost? If so you have a defrost problem, most likely the defrost is stuck in the run mode. this is located above the controls area in the fridge.
Nov 14, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Ffa70 hotpoint fridge freezer
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Fridge is freezing food
no more than likely that your thermostat is faulty all f/freezers have 2 stats 1 to keep fridge cool and 1 to the freezer u will need to replace the 1 in the fridge m8
Aug 15, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
37 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Gil Shultz
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
