Question about Pioneer CDJ-200 CD Player
Moved by royal mail and now wont turn on
Pioneers CDJ 200, when plugged in feels like there is some power as there is a slight hum, there is no display though and it will not take a CD.
Any help appreciated
  • jojoba77 Nov 06, 2008
    It turned out it was the transformer. it cost me £90.00 for the repair shop to supply and install it
It turned out it was the transfomer that needed replacing, I took it to a place that did repairs and it cost me £90.00
Posted on Nov 06, 2008
I have the same problem...did u solve it?
I have a CDJ 200 cd player the power when turned on there is no display YASH
Hi Yash,
pls make sure and check the fuse of your CDJ. Also check the power output that is 240v or 110v.
thx,
djajay
May 25, 2010 | Pioneer CDJ-200 CD Player
Cdj 200s bought from america not working. they have american plugs on at 120v. i have tried an america to uk travel plug and 240v to 120v stepdown transformer but this has not resolved issue....... would...
Yes, fuse may be blown, first check out the fuse of CDJ,
if it does not work. Install a physical 120v American transformer
also change the switch of 240v to 120v from back of CDJ
thx,
djajay
Feb 07, 2010 | Pioneer CDJ-200 CD Player
Pioneer cdj 200 wont read discs
Hi, try cleaning the lens with a cleansing disk. if this doesn't produce results, it will confirm a major issue within the lens assembly. you will need to replace the lens assembly in this case. it is unable to track or read in this damaged sate.
May 19, 2009 | Pioneer CDJ-200 CD Player
CDJ 200 without electricity fuse blow off?
no you cannot do that , the device works on 120v( 117v around me) , but it cannot be changed like that , you would need a trans former that breaks down the voltage to 120v
changing the fuse will not change the circuitry in the device
Nov 30, 2008 | Pioneer CDJ-200 CD Player
Cdj 1000 mk 2 cd won't go in front load tray
sounds like a cd slot mech problem,if you havent had it repaired you can send it to us.
thanks.
http://www.audiovisualservices.info/
Oct 05, 2008 | Pioneer CDJ-1000MKII CD Player
Plugged cdj-800 and mixer into a European outlet-now they won't turn on
ok, remove screw under the cd mixer and slide down carefully the top of the cdj and then trace where the power cord connects in to circuit(there is a fuse there try to change anew one..thats is!
Aug 11, 2008 | Pioneer CDJ-800 Turntable
Cdj 200 will not turn on
It actuall might be the fuse or there is a little short circut switch on one of the boards. That switch could have gotten moved.
Nov 20, 2007 | Pioneer CDJ-200 CD Player
Pioneer CDJ-200 CD Player Logo
210 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
