Question about HP Deskjet 6980 InkJet Photo Printer
HP 6980 Network light on is flashing
  • Anonymous Jun 26, 2008
    Network light flashes, then goes off
I had this issue with my 6988 printer---the solution was to unplug the power cord and then press and hold the power button for 30 seconds---thus draining off the static charge in the printer--- plug power cord back in---good to go.
Posted on Dec 12, 2008
Where to find driver for HP Deskjet 6988 printer in Windows 7 ?
You'll find any available drivers for the HP Deskjet 6988 on the support page for the 6980 series printers: https://support.hp.com/us-en/drivers/selfservice/hp-deskjet-6980-printer-series/468002/model/3422864 .
The Windows 7 driver should be found by Windows Update when you connect the printer with a USB cable. If you are using the printer in a network, you need to manually add a printer (using the wizard) from the Printers and Devices Control Panel. Start this after you have the printer connected to your router or switch. See https://support.hp.com/us-en/document/c01796879 and expand the section for Wireless or Wired Connection (Windows 7, Vista).
I hope this helps.
Apr 14, 2017 | HP Office Equipment & Supplies
What does a flashing, orange, upsidedown lightbulb mean?
This page explains about what to do depending on what light is blinking. Looks like there's a few solutions for the symptom you describe.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00575443&cc=us&lc=en&dlc=en&product=467982&tmp_track_link=ot_search
Nov 09, 2010 | HP Deskjet 6980 InkJet Photo Printer
New printer cartridge light still flashes printer
clean the contacts of cartridge carrier (the place you put cartridges in ) with a wet towel
Apr 27, 2010 | HP Deskjet 6980 InkJet Photo Printer
Which way should i connect the hp deskjet 6980 to network
You can connect it to any of those but I would suggest connecting it directly to your router or a hub on your network for easiest installation.
Nov 17, 2009 | HP Office Equipment & Supplies
Orange cartridge keeps flashing after cartridge
Are you using a factory new HP ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Also take a moment and make sure that all of the protective tape coverings have been removed from the cartridge.
Don
Oct 22, 2009 | HP Deskjet 6980 InkJet Photo Printer
Hp deskjet 6980 - green light on key beside the lock
it can be the problem of cartridges got faulrty so that needs replacement any of the two cartridge can be faulty. or the wire less connection issue.in that caee just conmnect the printer with a usb wire and check out.if same problem in connecting wire then its cartridge issue foir sure.
Feb 26, 2009 | HP Deskjet 6980 InkJet Printer
HP Deskjet 6980 InkJet Photo Printer Logo
655 people viewed this question
Ben Johnson
