Question about Hoover U8147-900 WindTunnel V2 Bagless Upright Cyclonic Vacuum
Hoover vacuume keeps shutting off
  • 868 Answers
Check the cord ,it may be loose at the wall.
Posted on Jun 24, 2008
Have a Hoover windtunnel vacuum and it keeps on overheating and shutting off. have checked all filters and they seem fine
Let's just hope, OK ?
1) Small possibility the vacuum is plugged up.
Take it all apart and clean every part, perhaps that will help.
Compressed air is really helpful.
2) Worse luck.
The bearings of the motor are failing, it is just about "toasted", and it is time to find a new one, as the bearings are neither lubricate-able or replaceable.
God bless your efforts.
Feb 17, 2017 | Hoover Vacuums
Why is it my vacuum cleaner keeps shuting off after ten minutes. i have a Hoover wind tunnel uh70086
Sounds like it has an overheat problem and is shutting down to protect itself. Make sure the exhaust filter is clean and that there are no blockages. Hoover UH70086 WindTunnel Cyclonic Pet Rewind Plus Upright Vacuum Parts...
Sep 17, 2015 | Hoover Vacuums
Uh70600 hoover keeps shutting off
Most vacuums contain a high temperature circuit that will shut off the motor if it gets to hot. Thoroughly clean or replace all filters so the machine can "breathe" easier and stay cool.
Nov 20, 2013 | Hoover UH70600 WindTunnel Max Vacuum,...
Re hoover 5914-900/the yellow ball keeps automatically sealing almost as soon as turned on/the mesh filter appears to be clear
Be sure to leave a gap of about 3/4 of an inch between the top of the filter, and the lid of the tank. Without this gap, the ball will shut off the suction prematurely.
Apr 04, 2011 | Hoover SteamVac F5914-900 SpinScrub...
The hose has a hole in it and the red ball keep shutting it off. Model F581-900 I have another Hoover SteamVac that is broken too. Where can I get these fixed, I live in Crown Point, IN. Thanks Valerie
I have a tube of Goop used to repair shoes. Using a rubber glove with a moist finger apply Goop (won't stick to glove then) over hole and allow to dry for 24 holes. Fixed my problem.
Nov 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
HOOVER WINDTUNNEL SELF PROPELLED OVERHEATING AND SHUTTING OFF
It sounds like it is overheating because of a blocked flow of air that keeps the motor cool. Check for a blockage from the area of the
roller brush through the hose to where it goes into the bag.
Tom
Oct 22, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
I was vacuuming and my hoover vacuum died
they have a thermal shut off on the motor so if it gets too hot it shuts down
can take up o 30 min to reset check all filters make sure nothing is blocking
Aug 15, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Filter keeps clogging
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=719779
Generic problem for all Vacuums
Posted by ozandcaza on Jun 29, 2008
Report abuse
Dust etc collects in the filter above the dust container. The dust container remains empty. Hoover then over heats and cuts out. Collect in replaced new filters in Hoover but problem still remains.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. My question is how old is the Hoover vacuum? If it less than a year you should really see an Authorized Hoover vacuum cleaner dealer that the problem might be covered under a factory warranty. This should not be happening and it sound to me like there is a clog somewhere in the vacuum fill area that is causing it to do this to you and the vacuum. You are lucky that you have a thermal switch that does shut it off. If not and it is over the one year factory warranty then you should see a local vacuum cleaner dealer in your area or contact Hoover Cust Serv @ the website and or phone 3 listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 29, 2008 | Vacuums
U5180-910 vacuum shuts off on own
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Nov 18, 2007 | Hoover U5180-900 Vacuum
Hoover U8147-900 WindTunnel V2 Bagless Upright Cyclonic Vacuum Logo
129 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
