Panasonic SA-PM19 Disc Changer
The tray for disc #2 stays half-way open. It will close when you hit play but will not play the disc. When you shut off the machine, the tray will open half-way again. Appreciate any help or direction. Thank you.
    President:
  • 624 Answers
If this is under warranty just take it in and get it repaired. If so, I feel sorry for the technician who must fix it.
If it is not under warranty, just RUN, run as fast as you can away from this machine. Panasonic made several models with this same mechanism in it and they all have major problems. They are the hardest CD mechs to repair. A mechanical nightmare. Most places will just replace the entire mech, but that would make the repair cost about $150. It may be better to just get a new one.
Your problem is a very common one for these. I am very sorry you got stuck with Panasonic's worst CD player ever. I work at an authorized Panasonic repair center, I am being totally honest with you about this. I really do feel bad for you. How could you know that this design was the worst they ever made? You couldn't!
This is the CR16 mech (that's what panasonic named it) yo ucan call any authorized Panasonic service center and ask somebody who fixes them if they have ever heard of that mech and I would be shocked if they had anything good to say about them.
let me know if you need any more help.
Dave
Posted on Jul 01, 2008
Panasonic SA-PT460 disc tray keeps opening. When system switched on disc tray opens, then closes and then opens and stays open. can't play a disc.
SA-PT460
Original fault tray would not stay closed,opened up 460 case and then removed 2 screws on rear of drive. unplug 2 ribbon cables.
unscrew 1 screw in micro switch pcb rotate and spay cleaner into switch and rock switch several times until the reading across switch is 0 ohms before you start you will find the switch has about 2.5 k of resistance across it witch is too high.
as long as you have about 4ohms it will work.
Aug 14, 2011 | Audio Players & Recorders
Panasonic SA-PM19 5 disc player jumps around, starting at or near first track, plays a little, then jumps a good chunk, plays a little more etc, until it reaches (quickly) the end of the disc. It does this...
Could be a CD defect, but probably just dust inside. Try canned air, or connect IPOD after you convert CD's to MP3's or other player to AUX port as a connector as a work a around. Splicers available online if you already have a TV connected.
Mar 20, 2010 | Panasonic Audio Players & Recorders
10 year old stereo system CD changer won't play discs
Dust may not be the entire cause, but without knowing the make and model, anything I list would be pure speculation. Please post the make and model. That should give me enough info to list the probable problems and their solutions.
Thanks,
Dan
Mar 17, 2009 | Audio Players & Recorders
HT900
I kept hitting the disc exhange/eject button to turn the unit on and after a couple of tries it finally opened about half way. The whole reason i wanted to open it was to get the last dvd that i watch out of it. Well in doing so i noticed that there were some discs rattling around up underneath the cd tray (from my 1 1/2 year old). After shaking the unit a couple of times i was able to get the discs out of the underside of the disc tray. When i hit the disc exchange to close the try the unit powered up, closed the tray, and operated fine and i am back to using it like i used to with out any other problems.
Oct 15, 2008 | Panasonic SC-HT940 System
Panasonic SA-AK66 Sound Problems
I have a Panasonic SA-AK66 5 disc changer stereo system. At first I was getting a no disc. I inserted my cd disc cleaner, now it won't play the disc or open (the drawer). What happened?
Nov 26, 2007 | Panasonic Audio Players & Recorders
CD tray repeatedly opens and closes
is this a yamaha 5 disc changer, table. not the cartridge type...
Aug 02, 2007 | Yamaha CDC-502 5-Disc CD Changer
636 people viewed this question
 Grubhead
Grubhead
