All in one printer installed on pc, driver installed but pc saying device not detected
  • beenaeem Mar 10, 2009
    printer is taking out test page but when try to scan or print anothre doc it simply says no device detected
  • Anonymous May 13, 2009
    I guess dell sucks - I've the same problem...
Try putting it in another USB plug, give it a blow inside to make sure there's no dust, if this doesn't work, check another USB device to make sure it's not the USB that has a fault. it could be a fault in the cable, so try holding it tightly into the USB plug, good luck
Posted on Jul 31, 2008
My Canon printer PIXMA MP 800 cannot be3 installed with my windows xp. Help please
ARE YOU UNABLE TO INSTALL YOUR PRINTER AND OTHER DEVICE MOSTLY REASON ARE YOU HAVE NO SUITABLE DRIVER THE BEST STEP THE FIND DRIVER GO TO MY COMPUTER MANAGE, DEVICE MANAGER, PROPERTY ON DEVICE WHOSE DRIVER ARE NOT FOUND, COPY DEVICE ID CODE OPEN http://devid.info SITE AND SEARCH YOUR DRIVER AFTER SEARCHING EXTRACT YOUR DRIVER ON ANY LOCATION GO TO DEVICE MANAGER, UPDATE DRIVER SELECT PATH OF DRIVER INSTALL DRIVER TO USE THIS STEPS
May 18, 2011 | Cannon Office Equipment & Supplies
Installation
uninstall the printer completely and then try installing it back
Aug 23, 2008 | Canon PIXMA MP470 All-in-One Printer
Says warming up but then get scanner failure message
Friend, You need to reinstall the device as the scanner portion of the drivers are malfunctioning. Please read the following and act accordingly:
Although there is a wizard to install devices on your PC or laptop, but still there are problems being faced by users. The reason is that there is a logical procedure for installations. Read on.
There are two things that you install. The drivers for all the devices and the program to use that device for some. First of all insert the CD that came with the device into the CD drive and let Autorun takeover. You will be guided throughout the process. Just answer a few questions and the SW will start the installation process for drivers. Once drivers have been installed then you can proceed with the installation of the program needed to run the device, not for all devices. After this task is accomplished always reboot the computer/laptop.
After the reboot, attach the device to the PC. Windows will immediately start the detection process and on detection will load its drivers that you had just installed. And then a notice appears in the right bottom corner of the screen saying "The new hardware was successfully installed and is ready for use". Or words to that effect. Now you can start using the new device whether through its specific program or through other programs that are meant to use it.
There are times when you are reinstalling the drivers. In that case you must first uninstall the old drivers and reboot the PC/laptop. Uninstall it from Control Panel->Add Remove Programs. And then reboot and reinstall.
Apr 20, 2011 | HP OfficeJet K80 All-In-One InkJet Printer
My olivetti anyway printer worked fine with my laptop,but will not work with my new pc,just reads no device detected
attach printer your new pc. pc on and printer power on. detect your printer than install driver in your new pc through printer driver cd.
if no detect your printer than right click my computer than properties than hardware than device manager than select any and top option scan for hardware changes, detect your printer and install driver.
Mar 02, 2010 | Office Equipment & Supplies
Brother DCP165c Driver installation Problem
I would boot in safemode (hold down f8 immediately when it starts (when it says Starting Windows xp), then delete all printers (associated with this) in device manager.
remove any printer software as well (add remove programs or start programs (printer program name, remove software IF listed),
also remove the port you are using in device manager be it lpt or usb. if the drivers siuggests installking without it connected do so, otherwise, just restart and it shoudl start installking the hardware amnd software it finds. be sure you have the correct drivers ready as well>
Good Luck
Jul 09, 2009 | Office Equipment & Supplies
Hp photosmart c4200
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Dec 17, 2008 | Office Equipment & Supplies
Need help hooking up my canon MP 240 tp my pc.My pc detectsthe printer then says no printer detected.
You need to install your printer first.
If you already have installed your printer, do this:
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
If you don't have installed your printer do this:
Get your printer software from: www.canon.com
USB printers (Windows 98, Me, 2000, and XP only)
  1. Make sure that the USB cable is unplugged from your computer and your printer. USB devices work differently from older devices and usually need to have the drivers installed before you connect the device.
  2. If you have an installation disk, insert it into the drive. If there is an installer provided, it should run or be executed here. Follow its instructions, and it should take care of installing your printer in a few moments.
  3. If you don't have an installation program, plug the USB cable into your computer and your printer. This should trigger the Add New Hardware Wizard.
  4. Click Next, and then select Search for the best driver for your device. Click Next.
  5. Uncheck all options except Specify a Location. Click Browse. Browse to the disk, CD, or directory where your printer drivers are located. Click OK, and then click Next twice. Note: You can download some drivers from the web. Consult the web site of your printer's manufacturer, or see Where can I find driver updates for my Windows computer?
  6. When all the files are copied, click Finish.
  7. Turn on your printer. Windows should detect the printer's presence and finish the installation. If the option to print a test page is offered, do so. This will confirm the installation. Click Finish.
Nov 05, 2008 | Office Equipment & Supplies
Driver install problem
I think it's a problem with the Operating Systems .
If you can try to reinstall the operating systems and try to install the printer .
Aug 07, 2008 | Canon PIXMA MP470 All-in-One Printer
J5780 Installation Problem on Windows 2000 PC
hi this is due to improper Software Installation stapes below
  • Un install all printer driver & software u install
  • disconnect printer from computer
  • restart u r computer
  • insert Software cd in to cd rom
  • install software ,follow instruction & fill up Information.
  • when notify you to please connect printer thorgh USB please connected Usb cable to your Printer.
  • printer shuld be ditected then follow instruction
  • complite Installation & cheak it out..
If this information is useful for u please rate me....
Jun 09, 2008 | HP Officejet J5780 All-In-One InkJet...
Z23 usb problem
Apr 11, 2008 | Lexmark Color JetPrinter Z23 InkJet
55 people viewed this question
jasbo
jasbo
