Question about Miele 24 in. G665 Built-in Dishwasher
No water entering machine.
Turn machine on and other than a low hum nothing else happens.Water does not come in.
It may be that the tray underneath the machine is full of water and this appears to activate the anti flood device and shuts off the water supply. If you remove the panel under the door you should be able to check. There are 2 screws to the side and 2 to the top of the small panel. I am uncertain where the water came from on my machine but this appears to have solved my problem.
Posted on Jun 26, 2008
My Kenmore Elite dishwasher just hums when we start it.Its not starting and no water is filling up
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You should NEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Aug 09, 2010 | Kenmore Dishwashers
Tip
So your Dishwasher sits and "Humming" cannot turn off, no response.
on Mar 27, 2010 | Dishwashers
It has the green light lflashing where it start but nothing happens
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Jun 01, 2010 | Dishwashers
Opened lid during wash cycle. Machine stopped but later restarted. The same thing happened two weeks later, but the touchpad has no function. It is getting electrical power to the dishwasher. Thoughts?
May 06, 2010 | Dishwashers
My dishwasher fills, but won't start running. it just sits full of water and just hums.
Apr 14, 2010 | GE 24 in. GSD1000G Built-in Dishwasher
Kenmore disposal hums, nothing jammed, everything moves freely, but wont spin. reset button stays tripped & wont catch
Apr 03, 2010 | Kenmore 13742 / 13744 / 13749 Built-in...
No water
First thing is to make sure the hot water supply is turned on under the sink.
Second, manually move the overflow float up and down to ensure freedom of movement. The float looks like a little hat or a cone inside the machine at the bottom. If it was stuck up, you have just solved your problem.
The last thing to check is the inlet valve. It is under your machine. The hot water line is connected to it. You must shut off the water and disconnect the line from this valve. The filter screen may be clogged. This will be obvious once you remove the water line.
If not clogged, attempt to operate the machine in this state. The valve should be doing something when the machine starts. Buzzing - clicking - humming. If it does nothing, replace it.
Good luck
Nov 24, 2009 | Asko 1385 Dishwasher
Whirlpool DU8900 XT-5 the water comes in at beginning of cycle and the heater heats the water, but the machine does not go any further. it kinda' hums but no water gets pumped and moving. at end of cycle...
if you can hear a low humming noise when it should be pumping water round, then suspect the circulating pump.
fault can be motor capacitor - low cost part
or
pump seized - see if you can turn it by hand
Sep 15, 2008 | Whirlpool Dishwashers
Dishwasher confused
i suspect this is nothing to do with switching off during the cycle.
take the bottom plate off and check if there is water leaked into the bottom pan. alternatively, if you can, tilt the machine back to 45deg and see if water runs out.
most machines have a float switch in the base so that if water leaks, all that will happen is that the drain pump runs and i think this is what you are hearing
Aug 07, 2008 | Dishwashers
No power to dishwasher
depends on the sequence. many, but not all, dishwashers start with drain to get rid of the slops. if yours starts with fill, then no water supply will prevent progress.(you should be able to hear a low hum which is the valve energised) check also that the door is closing properly and latching. better to use cold water fill not hot
May 09, 2007 | Frigidaire GPDB698SSBK Dishwasher
Miele 24 in. G665 Built-in Dishwasher Logo
273 people viewed this question
Top Miele Dishwashers Experts
icatci
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
