Question about Motorola MU21CV (1 Channel) 2-Way Radio
MU21CV my radio MU21CV WAS STORED 5 YEARS. NOW I WANT TO BE USE THEM & MY RADIO CAN'T BE ON. WHAT CAN I DO?
  • Motorola Master
  • 1,654 Answers
It is likely your radio needs a new rechargeable battery.
Posted on Jun 24, 2008
Tip
Battery and charger tips
The M series Motorola radios such as the MU21CV, come equipped with a NiCD rechargeable battery. This battery when fully charged should operate the radio a full 8-10 hour business day. The batteries have a life expectancy of 18-24 months.
The original Motorola battery has a date code in the white box above the stop sign on the back of the battery. The first digit is the year, and the next two are the week of the year. Example: 919 would be 2009, the 19th week. (Unless very old and it could be 1999)
When replacing the battery it is important to install the battery correctly. Put the top of the battery into the radio first, then slide the bottom into place. This method will cause the least pressure on the internal battery contacts.
If you battery's contacts are dirty or filmed, simply clean them with a pencil eraser. Do not use solvents or a knife blade on the contacts. The radio's contacts can also be cleaned with a pencil eraser.
The wall adapter style charger which came with the M series radio can burn out over time (much like a lightbulb). Replacement chargers are available. If your charger light is flashing, you most likely have a bad battery. If your charger light does not illuminate, you have a bad charger.
Replacement batteries and chargers are available, as is repair of this style unit.
Best regards,
eradiostore
on May 08, 2009 | Motorola MU21CV (1 Channel) 2-Way Radio
Cant sync radios
The MU21CV radio is user programmable. Hold in the PTT button while turning on the radio. It will announce the frequency. Use the PTT button to count it up to the frequency you desire. Press the smaller monitor button to lock in your freq. Then the radio will announce the code number. Once again using the PTT button count it up to your desired code or the word OFF if you are not wanting a code. Then press the monitor button to lock in the code. At this point you can turn off the radio and turn it back on normally (without holding in the PTT). Your radios should be programmed to match one another. If you are still having trouble you may have a radio which needs repair or a bad/low battery.
Best regards.
Aug 05, 2013 | Motorola MU21CV (1 Channel) 2-Way Radio
Where can i buy battery terminals for my spirit mu21cv walkies
Your local Motorola radio dealer should be able to help you with this.
Mar 23, 2012 | Motorola MU21CV (1 Channel) 2-Way Radio
I have a Motorola MU21CV with a overly sensitive 'push-to-talk-switch'. Sometimes even though you press it and get the "red" transmit indication - it's not transmitting. Is there anyway to...
  • You can open the radio up and clean the switch up a bit but it sounds like the switch may be worn. It's a simple on off push switch. You may just go to your local hardware store or electronics store and get a switch and solder it in.
Regards, Tony
May 03, 2011 | Motorola MU21CV (1 Channel) 2-Way Radio
Will the MU21CV radio's work with the talk about radios?
Short answer, maybe. It depends on whether you have a 14 channel or a 30 channel Talk-About. The Motorola Talk-Abouts operate on the FRS frequencies (14 channel) or FRS & GMRS frequencies (30 channel). The MU21CV does cover a few of the GMRS frequencies. (see bold numbers)
GMRS Frequencies
462.500, 462.575, 462.600, 462.625, 462.650, 462.675, 462.700, 462.725, 467.550, 467.575, 467.600, 467.625, 467.650, 467.675, 467.700 & 467.725
FRS Frequencies
462.5625, 462.5875, 462.6125, 462.6375, 462.6625, 462.6875, 462.7125, 467.5625, 467.5875, 467.6125, 467.6375, 467.6625, 467.6875, 467.7125
MU21CV Frequencies
464.500, 464.550, 467.7625, 467.8125, 467.850, 467.875, 467.900, 467.925, 462.575, 462.625, 462.675, 464.325, 464.825, 469.2625, 469.500, 469.550, 462.7625, 462.7875, 462.8125, 462.8375, 462.8625, 462.8875, 462.9125, 464.4875
Nov 01, 2010 | Motorola MU21CV (1 Channel) 2-Way Radio
Is the motorola MU21CV a UHF or VHF??????
MU21CV is a UHF radio.
MU= UHF
MV = VHF
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/Spirit_M_Series_E.pdf
You can find a frequency chart on page 10.
Best regards.
Jan 11, 2010 | Motorola MU21CV (1 Channel) 2-Way Radio
Compatability
would a MU21CV be a VHF or UHF????
Aug 12, 2008 | Motorola MU21CV (1 Channel) 2-Way Radio
Motorola spirit mu21cv
The problem of failing to power on can be caused by:
1. dead battery (may no longer hold a charge);
2. corroded battery terminals or connectors;
3. open wiring from the battery casing to the internal circuitry;
4. defective on/off switch; and/or
5. defective regulator component(s) on the main PCB.
On the other hand, problem on receive can be caused by:
a. defective or worn out volume control (if manual/rotary);
b. defective or worn out squelch control (if manual/rotary);
c. mismatch in PL or CTCSS code; and/or
d. defective internal speaker.
Most can be checked with the use of a continuity tester or a DVM. Repairs involve knowledge and familiarity with electronic components and circuitry and perhaps even the use of a soldering iron. Should you not be comfortable doing it yourself, perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 05, 2008 | Motorola MU21CV (1 Channel) 2-Way Radio
Motorola MU21CV (1 Channel) 2-Way Radio Logo
89 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
