Biostar M7VIG-400 (M7VIG 400-COMBO4) Motherboard Logo
Posted on Nov 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a M7VIG-400 Motherboard and want to upgrade the processor, so I purchased an AMD Athlon 2600, but it doesn't work. nothing happens when I try to boot up. Is the processor faulty? Or do I have the wrong one? The one I have is AXDA2600DKV3C. I was under the impression that any AMD Athlon chip up to 2600 would work on this motherboard. What is the fastest CPU this motherboard will accept?
Alun Cox
Level 3:
President:
  • Master 2,679 Answers
  • Posted on Nov 27, 2010
Alun Cox
Master
Level 3:
President:
Answers
2679
Questions
0
Helped
689753
Points
8444
It should work provided the CPU is seated correctly and is a working processor.
Support processor for upgrade to higher processor
This are the comptible processor that you can use for this motherboard if you plan to do a upgrade on it. AMD Athlon 64, AMD Sempron, AMD Athlon 64 FX, AMD Athlon 64 X2
Here is a link that contain all the details about this motherboard.
http://www.dealtime.com/xPF-ASUS-Asus-M2N-MX
1helpful
Yea i need to purchase a new processor chip the motherboard is a 754 socket my pc takes a 3100+ amd sempron processor my pc is 1.8ghz im just not sure what to buy some say they are 64 bit and this one is...
please purchase the processor that is compatible to your motherboard. if the motherboard can be upgrade to a higher speed of processor then purchase it. if not, stick to the required specs. if you still want to upgrade, replace the motherboard, processor and the memory.
I need a m7vig400 supporting prossers
You can see the supported CPU list from Biostars web site;
http://www.biostar-usa.com/cpusupportA.asp#M7VIG%20400
Listed under Model. Scroll down the CPU list untill you come to M7VIG 400. Highest CPU supported is, AMD Athlon XP, 3000+ (333MHz)
Main web site for the M7VIG 400;
http://www.biostar-usa.com/mbdetails.asp?model=M7VIG+400
List of possible CPU's; AMD Athlon XP 3000+ - AXDA3000DKV4D;
http://www.google.com/search?hl=en&q=Buy+AMD+Athlon+XP%2C+3000%2B+333MHz+CPU&btnG=Search&aq=f&oq=&aqi=#
Hope you find this helpful.
Cheer
Mike
Chip up grade options!
That
is a socket 754 motherboard. It will support AMD Athlon processors up to Athlon64 3400+. It is a bit long in the tooth by today's standards, and only uses DDR memory, not DDR2. You may get more of a bang for your buck by buying a "barebones" system, which can consist of a motherboard with processor and memory, depending on how much you want in the barebones package.
Typically you use the case, power supply you already have with the new motherboard and processor and ram (memory).
At any rate, if you only want to upgrade your processor, keep in mind that your board only supports up to the Athlon64 3400+. It will support up to DDR 400 ram. You would probably benefit more by buying 2 sticks of 400 DDR ram at 2 gigs each, if you don't have much ram now. If your processor is close to the 3400+, then another processor in that board isn't going to change things much.
Good luck, and write back if you'd like more help.
Sirwriter
Socket754 Supports AMD Athlon64 upto 3400+;
Finding compatible motherboard for new CPU.
Hi kaufam7.
this motherboard will work with your AMD CPU
Biostar M7VIG 400 Socket A+ Athlon 2600
you can check it on this website below
best of luck
magpi
2helpful
2answers
Maldonado223
best processor
AMD Athlon, Athlon XP, Duron, and Sempron processors
200 / 266 / 333MHz front side bus
for further information visit the link
How to upgrade
Here is the list of compatible processors for your motherboard:
AMD Athlon 650, 700, 750, 800, 850, 900, 950, 1.0G, 1.1G, 1.2G, 1.3G, 1.33G, 1.4G (Thunderbird)
AMD Athlon MP 1.0G, 1.2G, 1500+, 1600+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon MP 2000+, 2200+, 2400+, 2600+ (Thoroughbred)
AMD Athlon MP 2800+ (Barton)
AMD Athlon XP 1500+, 1600+, 1700+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon XP 1600+, 1700+, 1800+, 1900+, 2000+, 2100+, 2200+, 2400+, 2600+, 2700+, 2800+ (Thoroughbred)
AMD Athlon XP 2500+, 2600+, 2800+, 3000+, 3200+ (Barton)
AMD Athlon XP 2000+, 2200+, 2400+ (Thorton)
AMD Sempron 2200+, 2300+, 2400+, 2500+, 2600+, 2800+ (Thoroughbred)
AMD Sempron 2200+, 2400+, 2500+, 2600+, 2800+ (Thorton)
AMD Sempron 3000+ (Barton)
AMD Duron 600, 650, 700, 750, 800, 850, 900, 950 (Spitfire)
AMD Duron 1.0G, 1.1G, 1.2G, 1.3G (Morgan)
AMD Duron 1.4G, 1.6G, 1.8G (Applebred)
You motherboard uses a "Socket A" CPU and therefore has limits to how high you can go.. I would recommend the XP 2200 or 2400+ as a good choice, but you can make your own choice.
2answers
CPU model not recognized correctly
Any multiplier settings in bios? try using something like CPUID in your OS to see if it clocks faster then what bios tells you?
1helpful
2answers
Processor
hi, from your reference i could get the info that your pc is running with the mainboard similar to FIC - am37,and with that the below mentioned processors are supported. Recommended Speeds: AMD Athlon? XP 2600+ (266 FSB) AMD Athlon? XP 2400+ (266 FSB) Model 10 w/ 256K Cache AMD Athlon? XP 2400+ (266 FSB) AMD Athlon? XP 2200+ (266 FSB) Model 10 w/ 256K Cache AMD Athlon? XP 2200+ (266 FSB) AMD Athlon? XP 2100+ (266 FSB) Model 8 AMD Athlon? XP 2100+ (266 FSB) Model 6 AMD Athlon? XP 2000+ (266 FSB) Model 8 AMD Athlon? XP 2000+ (266 FSB) Model 6 AMD Athlon? XP 2000+ (266 FSB) Model 10 w/ 256K Cache all the best.. sreejith
Top Biostar Computers & Internet Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
