Question about Dishwashers
Balay dishwasher Hi My dishwasher is broken.When I switch it on nothing happens.I have checked that the dishwasher is plugged in and the water is turned on.I used some hot water to try and get the dishwasher going.It mamaged to activate the sprayers and drain the remaining water.I suspect the water inlet solenoid is faulty! Can you please help me? Thanks, I look forward to hearing from you soon! Regards Alan
2 Suggested Answers
  • 71 Answers
SOURCE: no water enters dishwasher (Kitchen Aid KUDS25SHBL1)
usually 120 volts
Posted on Dec 12, 2008
I need dishwasher instructions in english for a balay.
If you send me an email to, I will send you the manual that I have. I do not believe that Balay puts out a specific manual, but the one that I have is in english.
Mar 26, 2012 | Dishwashers
Dishwasher won't start
Try resetting the unit by shutting off the circuit breaker first for 1 minute then try the reset button. If nothing happens, then i would recommend having someone take a look at it.
Feb 09, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
My Asko Dishwasher D1976 on the main panel all of the top lights are on and in the display window it flashes F2. The motor is on but nothing else is happening can you help. I have checked that drains are...
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be ther when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now.
Hope it helps...
Apr 22, 2011 | Asko D1976CSTM Built-in Dishwasher
Dishwasher doesn't get enough water , checked the lines and nothing is plugged. is there another filter to check?
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
Sep 05, 2010 | Whirlpool Dishwashers
Water will not drain
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
May 31, 2009 | GE Nautilus 24" Built-in Dishwasher
Can hear motor running but nothing happens in dishwasher
Hi, you need to test voltage to the water inlet valve. If you are getting voltage (120V) replace the valve. If you are not getting voltage check the water level switch located in the front corner of the tub.
If I can assist you any further with parts or part #'s, please let me know.
May 16, 2009 | Dishwashers
My BEKO D3421F dishwasher wont start?
hi there......sounds like the door switch on your apliance has given the door close it firmly lidstening for an audible click as the door switch makes...
regards SirGalahad
Mar 15, 2009 | Beko 24 in. D3421F Free-standing...
My Bosch Dishwasher doesn't run
double check power to your plug socket ( use bedside lamp)
check fuse in plug
check water supply ( run the water supply directly into pot/bucket)
make sure door closes properly (if built in )
if built in remove and then check!
Feb 09, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Maytag dishwasher wont start
Drain the water out of the dishwasher. The high water switch ius engaged, lowering the water will disengage.
Sep 10, 2007 | Maytag MDB7100AWB Dishwasher
Dishwashers Logo
384 people viewed this question
Top Dishwashers Experts
