Question about Canon PIXMA MP830 All-In-One InkJet Printer
Mp830 shows paper output slot jam
I only use the machine for faxing since it can fax legal size papers. It doesn't have any paper loaded in cartridge. It says paper output slot jam, clear paper and press ok. There is no paper to clear. It won't turn off so I have unplugged it several times and plugged it back in. The output slot jam message does not go away when it is powered back up What can be the problem?
  • 5 more comments
  • Anonymous Jul 12, 2008
    Pixma MP600; same exact problem; there is NO PAPER JAM and yet the message will not go away and the untit will not print.
  • Anonymous Jul 19, 2008
    I have the same problem with the i4300 printer!!!
  • Anonymous Jul 30, 2008
    Same problem here
  • Anonymous Aug 23, 2008
    ditto
  • MoCoGirl Sep 16, 2008
    I have the same problem! I Need HELP!!!
  • mickbren Jan 27, 2009
    I am having the same exact problem. There is no paper jammed and cannot turn machine off. Have to unplug from electric outlet.
    Before I got the paper jam message I got an error code of 6A00. That went away and now can't get rid of the paper jam message.
  • Anonymous Mar 12, 2014
    My printer says that it has a paper jam in the output slot but there is no paper in it at all not even a little piece. How could I fix this
I cannot receive faxes or print anything.
The message says that "there is no paper in the machine". There us plenty of paper in the machine and I push "OK" and get the same message
Posted on Jun 27, 2008
How do I clear the in use alarm on a canon mx340 printer?
The in use alarm appears to be related to fax reception and printing. There are some options below that you could try:-
Memory Reception If the machine receives a fax under one of the following conditions, it will not be able to print the received fax and will store it in its memory. The In Use/Memory lamp is lit and Received in memory is displayed on the LCD. When the problem is resolved as described, the fax stored in memory is printed automatically.
  • Ink has run out: Replace the FINE Cartridge.
    i_green_arrow.gifRoutine Maintenance
    i_note_e.gifNote
    • You can set the machine to forcibly print a received fax even if the ink has run out.
      However, part or all of the fax may not be printed since the ink has run out.
      Also, the contents of the fax will not be stored in memory.
      If the ink has already run out, we recommend that OFF be selected for Auto print in FAX user settings to store the received fax in memory and print the fax manually after replacing the FINE Cartridge. After you replace the FINE Cartridge and select ON for Auto print, the fax stored in memory will be printed automatically.
  • Paper has run out: Load the paper and press the OK button.
  • A different size of paper from that specified by Page size is loaded:
    Load the same size of paper as that specified by Page size, then press the OK button.
  • Page size is set to other than A4, 8.5"x11"(LTR), or Legal (or 8.5"x14"):
    Set Page size to A4, 8.5"x11"(LTR), or Legal (or 8.5"x14").
  • Media type is set to other than Plain paper:
    Set Media type to Plain paper.
  • You pressed the Stop button to cancel printing of a fax:
    Press the FAX button
Alternatively turn the printer off, open the devices and printers section of Control Panel, right click on your printer and select "see what's printing" and left click on this. A window will pop up which may or may not contain a list of documents. If it does these must be cancelled (Menu - Printer - Cancel all documents). Once all documents have gone from the list turn the printer on and try to print.
Other than the above suggestions I would need to know more about your OS and exact problem. Hope this helps.
Aug 06, 2014 | Canon PIXMA MX340 Wireless Office...
How to put the paper in the printer?
Loading Paper
1 Adjust the guides to the position for the paper size you are using.
2 Fan the paper well.
Push down the paper lever. Load the paper (with the lever down). Make sure the print side is toward the fax machine and the paper level is stacked below the paper mark. The feeder can hold up to 200 sheets of paper, or up to 10
envelopes.
Acceptable Paper
The FAX/MFC can handle paper that has the following specifications.
But please note that you can receive fax messages only on Letter, Legal and A4 paper. If you use legal or A4, change the Paper Size setting: (Menu/Set, 1, 1.)
Paper Type Paper Size
Cut sheet Letter, A4, Legal, B5, A5, Executive,
Custom size 2.75-8.5 × 5-14 inches (70-216 × 127-356 mm)
Envelopes DL, C5, COM-10, Monarch
Post Card 2.75-8.5 × 5-11 inches (70-216 × 127-279 mm)
Organizer Day-Timer® J, K, L, M 2.75-8.5 × 5-11 inches (70-216 × 127-279 mm)
Labels and Transparencies 2.75-8.5 × 5-14 inches (70-216 × 127-356 mm)
Dec 20, 2010 | Brother IntelliFAX 3800 Plain Paper Laser...
I am getting the alarm "check paper size" and then it jams.
set the select paper size of user data fax printer setup to the size of paper loaded in the paper cassette.
Mar 15, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
Can't send or receive faxes after fixing error code problem
your printer CHANGE PAPER TO
A4/LTR/LGL PLAIN
The paper size setting is set to a size other than
A4, letter or legal in fax receive mode.
The paper type setting is set to a type other than
PLAIN in fax receive mode.
Set the paper size setting to A4, letter or
legal and load paper of the same size.
Set the paper type setting to PLAIN.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon B820
please confirm that no foregin object droped inside like (stapler-pins)--confirm that paper jam switch in good condition and it is lever not broken and can move in free motion.-chek for small pieces of torn paper and clean the paper path.
Mar 12, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Paper Size
Have you tried placing legal size paper in your machine?
Also check the user settings. I am pretty sure there is an option to shut down the automatic reduction for legal size paper.
Check your user manaul if you still have it. If not, then let me know and I will see if I can look it up for you.
Good luck.
Mac
Feb 29, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Canon LaserClass 7000 - Receiving problem
Make sure the rear guide is pushed up tight against the paper.
Remove all legal size paper and make a copy.
Dec 13, 2007 | Canon LaserClass 7000 Plain Paper Fax
Lexmark F4270 Paper Jam Problem
Go to the menu and make sure it is set to Letter and not Legal size.
Oct 29, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
Canon PIXMA MP830 All-In-One InkJet Printer Logo
607 people viewed this question
old marine
old marine
