Question about Jl Audio 13W7 Car Subwoofer
Sub help 13w7 not working at all amp puts out power sub doesnt work.
  • 1 more comment
  • Anonymous Jan 24, 2009
    I have a 13 inch as well and recently found that it stopped working.... i checked everything and the only thing that was left to guess was that the sub i spent 860 f.....g dollars on is now blown bc the voice coil burnt up. like the other guy said, its is a flat rate of like 550 dollars for any repair on a w7. p.s. if u push down on the sub and it makes a crunching sound...... then its def. toasted
  • ecoop56 Apr 22, 2009
    BRAND NEW SUB AND AMP SUB NOT WORKING AND PISSING ME OFF
  • Seth Bourne May 11, 2010
    what were you powering them off??
There no point getting it fixed cos it wiil do the same thing again later on down the path.
Posted on Apr 05, 2009
My 12w7 has like a springing sound inside it, what is it?
Blown voice coil,,,,it was connected to a JL AUDIO amp correct? w7`s can ONLY be powered by JL amps due to ohm load.Advice buy a better quality sub,w7 is over-rated
Feb 07, 2013 | Jl Audio 13W7 Car Subwoofer
To hook a 1000/1 amp to 13w7 do i run positive to positive and negative to negative to the speaker
Yes yes never try to bridge this sub no reason if you had the money to buy this sub then you should have the right amp so.
Dec 24, 2011 | Jl Audio 13W7 Car Subwoofer
Why doesnt my jl 1000.1 pick up my 13.5w7
ohm load check the way you wired it if the amp can handle 1ohm make the sub 1 ohm dule 2 ohm subs hook the neg from one coil to the pos on the other then take the empty neg hook it bridged to the neg on the amp and empty pos to the pos on the amp also check to see if you hooked it up bacwards subs dont hit hard when they are beating in and not out
Feb 06, 2010 | Jl Audio 13W7 Car Subwoofer
JL 13w7 & 1000/1 Settings
There is no "perfect" setting that can be placed in a manual. It's all done by ear. Your settings will vary depending on the vehicle you are in, the type of enclosure you have, the type of music you listen too, how much voltage your deck put's out. There are many variables, but I can try to give you a basic guide.
First of all you need to know your enclosure. If you have a ported enclosure tuned in the mid to low 30's you may want to set the low pass to around 70-80 hz with your sub sonic set at 30 hz. this will give you the higher bass frequency you need for the loud bass you want, and protect the sub from going too far below the tuned frequency of the enclosure, and losing it's composure.
As far as the gain, and bass boost are concerned, you just have to adjust them by ear. First adjust the radio volume to normal listening levels, by that I mean as loud as it can go without the speakers in the car sounding like ****. Now you adjust the gain first. slow turn the gain control, carefuly watching and listening to the sub.. Adjust the gain to the point of the woofer getting a lil sloppy then back it down a bit until the sound is clean again. Now do the same with the bass boost. if there is a bass boost frequency adjustment, set that as close to the tuned frequency of the box as you can.
If you are in a sealed box the adjustments are a bit easier, and are all about taste. Adjust the radio as described before, and put on your favorite song. Next start udjust thing lowpass frequency to taste, not too high tho, try not us higher than 100 hz in your sub's for better sound. Sub sonic is not quite as important in a sealed box, as there is much less danger of the sub losing control.
Well good luck, and hope this helps!
Jul 13, 2009 | Jl Audio 13W7 Car Subwoofer
JL Audio 13w7 & 1000/1 Amp Settings
that depend on how you wire the speaker my friend and the performance of you am and u have to use jl -dclass series amp for the best performance of those speakers
Wheres the power.. No bump
it might be that your subs are too powerful for the amp, check the model of the sub or subs online and check out how many watts they can take, because you might need to upgrade your amp or downgrade your subs
Jul 03, 2009 | Alpine MRP-M450 Car Audio Amplifier
Kickers dont beat like they should
try to check and clean the wiring as clean as possible to avoid messing up on your connection. Check the polarity of you subs to yuor amp if you have it connected on the outher way around it would not give you a good result. check the polarity this will solve your problem. Over powering your sub will fry it easily try to tune it a 10" sub wont give you a 15" performance..
Jan 20, 2009 | Jl Audio 500/1 Car Audio Amplifier
Subs dont beat like they should
you've spent alot of money on **** by the sounds of it!!. you should only ever run multiple subs the same brand, power and resistance you can just connect any old subs to a system you need to wire them depending on the load that the amp needs to see. first thing is to try the amp/s on a individual sub to check your amps still work once done check the subs 1 by 1.
My amp was bad so i replaced it now my sub does not work i checked the wiring that goes from the amp to the speaker and everything seem to be ok then i put another speaker thinking it might be the sub and...
It doesn't sound like the wiring from amp to sub is your problem.
Is your amp getting a power light ?
Are you sure your remote wire is hooked up properly ?
Check both ends of your RCA cables
Jan 05, 2009 | JBL GT150 Car Subwoofer
Popping
If you Wire the 13 w7 in parallel you get 0.75 ohms which this amp is incapable of handling, that's why your speaker is popping. Be carefull cause this setup could ruin both your amp and sub. You have to wire that sub in series so that the amp "sees" a 3 ohm load which it's best suited for.
May 28, 2008 | Jl Audio 13W7 Car Subwoofer
Jl Audio 13W7 Car Subwoofer Logo
147 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
