Westinghouse LCD TV SK 26H59OD
Hello I sm in the need of a code to program my remote. I have an LCD Westinghouse SK-26H59OD and I recently got an HD Receiver, but I have to use both remotes vs using the one for the receiver only. Is there any way possible you could guide me or give a special code to program the TV?
Thank You, in advance!!
4 Suggested Answers
Sparky-UK
  • 129 Answers
SOURCE: One for all universal remote model URC-3220 Attempting to program direct Tv receiver to remote. Need Receiver code number
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3220
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Posted on Dec 30, 2007
SOURCE: remote control code for westinghouse sk-19h210s television
I just tried a Sony code for my Westinghouse tv after reading other sites, and it worked. The code that worked for me was 10000
Posted on May 05, 2008
SOURCE: the sharper image jumbo touch
The instructions that came with my remote were COMPLETELY incorrect. I made note in pen in my jumbo remote manual. After hours of searching the web and piecing together various blogs, I wrote these easy-to-use instructions:
  1. Place the jumbo remote and your old remote on a flat surface, head to head, with a 1" to 2" space in between (the remotes should be aiming at eachother).
  2. Press and HOLD the device button on the jumbo remote (eg. TV) until the jumbo remote's small indicator light turns solid red.
  3. Press the LEARN button once on the jumbo remote. The light will blink rapidly.
  4. On the jumbo remote, press the button that you want to perform the learned action (eg. If you want the jumbo remote to turn your TV on and off, press the POWER button on the jumbo remote).
  5. Press the same button on your old remote (eg. POWER button on my old tv remote control). When the jumbo remote's light changes from rapid flashing to slower flashing, press ENTER on the jumbo remote.
  6. You're done! Try the jumbo remote out (eg. Aim the jumbo remote at your TV, press the jumbo remote's TV button, then press the jumbo remote's POWER button). Your television should turn on or off with your jumbo remote.
You can program any jumbo remote button this way (eg. MENU, EXIT, MUTE). Just make sure you press the same button on each remote in steps 4 and 5 (eg. MENU on jumbo remote, MENU or LIST on old remote).
Posted on Feb 18, 2009
  • 4856 Answers
SOURCE: I need the code for a Westinghouse T.V. model
For Westinghouse TVs, try the codes: 11712, 10451, 10885, 10889, 11300, 11577. Since the TV was announced in 2006 and the remote code list has a copyright of 2010, the remote should control the TV. However, I can't tell which of the 6 codes will work for your TV.
The manual and code list for the RCRN04GR are available from http://www.rcaaudiovideo.com/remotes/4-5-devices/?sku=RCRN04GR . Click on the Support/Manuals tab.
I hope this helps.
Posted on Aug 24, 2011
Testimonial: "Cindy is the best"
My RMT-05 remote will not operate my w32001 westinghouse lcd
This remote control have no setup codes with Westinghouse brand TVs. If you wish to get more, check the sites linked here. It has setup code list to many popular brand remote controls.http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Aug 31, 2013 | Westinghouse Original Rmt-05 Rmt05 Hd Tv...
I need the code for a Westinghouse T.V. model number SK 26H59OD
I hope this helps.
Aug 23, 2011 | RCA RCRN04GR Remote Control
Need the code to program remote to tv remote is a sru2103 tv is westinghouse
Hello
Codes for Westinghouse is:
0000, 0451
Code for White Westinghouse is:
0463
OK.
Jul 17, 2011 | One For All URC4220 Remote Control
I have a Samsung Blu-ray remote (AK59-001041R). I need a programming code for a Westinghouse LED TV.
I have a Westinghouse LTV-32w3 HD that I am able to operate with a Samsung AK59-00104R remote. To activate this, press and hold the TV Power button on the upper right of the remote while simultaneously typing "3" and then "5" in succession. This code (35) works for these Westinghouse TVs.
Mar 07, 2011 | Samsung Ak59-00104l Remote Control
I need the programming code for a universal remote and a westinghouse tv model number sk26h570d
Hello, the Westinghouse TV's are able to use only the Sony codes for the universal remotes, other than that I would recommend emailing the Westinghouse parts department at parts@wde.com and requesting an original remote for your unit, the price on the remote is $15 plus shipping and handling.
Nov 22, 2009 | Philips PM3S Remote Control
Living soluttion codes for my westinghouse tv
The remote codes for a Jumbo Remote Control and a Westinghouse TV are 097, 100, 130, and 155.
Oct 10, 2009 | Innovage Jumbo Remote Control
Codes for living solutions remote + westinghouse lcd tv
The codes for your Jumbo Universal Remote to control a Westinghouse television are 097, 100, 130, and 155.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
I hope that helps.
Direct TV remote, need code for Westinghouse Flat Screen 32" itsdon458@yahoo.com
Try these codes listed for Sony.  10080 11100 10111
 One of these should work.
Jan 06, 2008 | Westinghouse 16093 Remote Control
Remote code
DirecTV offers a remote code lookup tool, which I just used to find possible codes for my Westinghouse TX-42F430S; its first suggestion (the "most popular" code) didn't work. Clicking the "It's not here" button showed seven more codes, and one of them (11577) worked perfectly. Here is the full list of Westinghouse codes for DirecTV from that tool (as of 11/27/08):
Most Popular Code: 10885
Other Possible Codes: 10889 10890 11577 11282 10451 10000 11092
Nov 10, 2007 | Westinghouse 16093 Remote Control
Remote control code for westinghouse sk-19h210s television
Oct 21, 2007 | Televison & Video
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Electro Med Services...
