Question about Intel Motherboard
Hi sir my computer has a sata opation, but when i try to instiall new operating system, but it says windows didnt found any hard disk drive in it, so i have tried a lot but i couldnot solve this problem, so please help me...
Check your bios setting, you will find an option of harddisk priority, set the sata harddisk as the first boot device
Posted on Jun 24, 2008
My Sony Vaio laptop has no operating system because my hard drive died. I have a brand new 160 GB SATA hard drive. Tried reinstallation of Operating System with Sony's recovery disks, did not work. Also...
new hard drive needs to be formatted before software can be installed on the hard drive. you need to use advanced setting on the software installation, and then format hard drive.
Jul 31, 2017 | Sony VAIO VGN-AR190G Notebook
Ok i have two hard drives and the computer is not finding them
poss windows has fallen over you need an operating system check hdd are master and slave master first one from board go to bios set the cdrom as the default 1st boot device put operating system into cd rom should start to load operating system
Apr 06, 2012 | Dell Inspiron 530 Desktop Computer...
New hard drive operating system not found
The reason why you cannot install Windows on your hard drive is this model Sony has a SATA disk controller.
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 17, 2012 | Sony VAIO VPCEA36FX PC Notebook
Hello, i have sony vaio VPCEB46FG laptop & i have windows 7 64bit operating system & i want to install windows XP 32 bit but im getting following error "a problem has been detected and...
It is required to install the hard disk SATA drivers in the computer first. Download and extract the SATA drivers in a floppy drive, hard drive or CD on a different computer. Then, retsrt the computer by having the Windows XP disc inserted and beging the setup. During the setup process press the F6 key and enter>enter and then install the SATA drivers. Then, continue with the further setup process.
http://www.sony.co.in/support/product/VPCEB46FG
Select Windows XP Operating System and install the SATA drivers. Once, the SATA drivers are successfully installed you can continue with the further setup process with out errors.
You can also view a complete set of instructions on downgrading to the Windows XP Operating System and installing the SATA drivers.
http://esupport.sony.com/US/perl/support-info.pl?info_id=337#
May 31, 2011 | Sony VAIO VGN-S460 Notebook
My Acer Aspire T650 Computer came with Windows XP Home Edition installed on it. However, viruses invested the operating system and I had to do a fresh installation. Because the computer did not come with...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 26, 2011 | Acer Aspire T650 (AST650UC3601) PC Desktop
Hard disk Recognition problem
U are actually facing the same problem as "jackwilkinso". As my previous post: Windows XP does not come out to support SATA hard drive, because inside do not inclued the SATA driver, that why u cannot see the harddisk during the setup. What u can do is try to install the SATA supported OS like Windows Vista or Windows 7, or maybe can "forcely" put in the SATA driver in ur Windows XP setup CD.
YBC (/\)
Mar 29, 2009 | Western Digital Caviar 500GB Internal SATA...
Updat to new sata hard drive from old idie hard drive.wont reconi
Hi, you will need to load the sata raid drivers when installing the OS. Some off the older versions of xp will not have these, when windows is installing it will ask if you need to install a 3rd party raid driver press F6. later on it will ask you to insert the raid driver disk. which you may have to do/make yourself if you haven't already got one.
Mar 01, 2009 | Computers & Internet
2 hard disks
Because you have a dual boot system, you have two 'C' drives, which in fact is a good idea if you get a system failure on the drive you are using, you can select the other and still view any files on the other drive through my computer.
f using XP, right click my computer, then properties, then click advanced tab, then startup and recovery listing click settings, at the top system startup, select the default operating system, then click EDIT button, then delete the value that points to the other hard drive more than likely listed as disc1, disk 0 will be the one you have connected as master boot hard drive
Aug 29, 2008 | Microsoft Windows XP Professional With...
Istalling windows
Windows Setup cant find hard disk ?????????????
Does the BIOS on your system see the drive and show it's model information? Is this the only drive on the system? If the answer is yes for both, then you can download free utilities from the web to wipe the drive clean. This will result in the loss of all existing data on your drive. You can search for "Wipe Disk" and will get several hits for free software. Once you have cleaned the drive, try instlling XP. If the BIOS does not see your drive, the XP can't see it. You may want to try other SATA ports on your motherboard, or try changing the IDE configuration in the BIOS. Let me know if this works.
Aug 29, 2007 | MSI K7N2 Delta-ILSR (MS-6570-030)...
Intel Motherboard Logo
63 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
