Question about Stoves 23 in. Q60DW Built-in Dishwasher
Zanussi ZSF 6161 Dishwasher error codes
We have a Zanussi ZSF 6161 dishwasher with a problem. When the unit is switched on and a program selected, the diswasher powers up for a couple of seconds, then the digital dispplay shows an error code ".50" and the dishwasher stops. Pressing the reset buttons on the front of the unit does nothing.
Can you help?
Thanks,
James My Q60DW dishwasher seems to complete only the PO1 rinse cycle. If I program PO2, PO3, PO4,PO5, PO6, PO7, or PO8 it runs for approximately 12 minutes -- filling with water and pumping out -- then stops and an 'E3' appears on the program. I try turning the power off and reprograming but to no avail. Can you help?
  • kilbrackan Jul 06, 2008
    The suggestion by Maanusi to unplug the unit for a couple of hours didn't work. After replugging in and retrying all cycles after the rinse cycle we were still getting an "E3" on the program viewer -- four beeps as a signal -- and after running & pumping. Is the brain/computer suffering?
  • Anonymous Mar 12, 2014
    Zanussi Dishwasher ZSF 6161 is tripping electric during cycle
    Genius:
  • 1,142 Answers
Did you try a hard reset
Posted on Jun 24, 2008
  • Maanita Chadha
    Maanita Chadha Jun 24, 2008
    Unplug the power cord and leave the machine for 2 hrs than reconnect and tell me the status on the same post
Zanussi zsf 6161 dishwasher - won't start program cycle
follow this steps and fix it. God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control
May 28, 2013 | Washing Machines
Replace bulb zsf6161
see your instruction manual, and go to the section troubleshooting.
however is very simple, unplug the power and proceed taking the first wire and make note for color wiring, and replace.
If you do not i.manual download from www. retrevo.com
God bless you
Jun 18, 2012 | Zanussi Dishwashers
I have a Zanussi ZSF 6160 dishwasher which is not heating the water. I've checked the PCB and visually it appears ok. How do I change the heating element?
measure the heating element resistance it should be around 25 ohm.
otherwise it is the problem.
You can replace the relay, sometimes it stop working with no external damage signs
Jan 08, 2010 | Zanussi 24 in. ZSF6160 Free-standing...
I have a Zanussi Electrolux Jetsystem Progress ZSF 6161 Dishwasher which, no matter what programme I use, stops after 2 seconds and a -10 flashes.
I have a Zanussi Jetsystem Progress ZSF 6161 Dishwasher stops after a few seconds and flashes -30 Any ideas? thanks!
Jul 28, 2009 | Zanussi Dishwashers
Zanussi ZSF 6161 Dishwasher with Error 30 Code
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
Mar 22, 2008 | Dishwashers
i have got an zanussi des 959 and showing falt code 5 could u help me out
Jan 19, 2008 | Dishwashers
Problems! zanussi zsf6120
You can check the heating element with an ohmmeter and it should read a few hundred ohms. Don't know about the thermostat but it should be inline electrically with the heating element and should ohm as a short when cold.
Nov 23, 2007 | Zanussi 24 in. ZSF6120 Free-standing...
Stoves 23 in. Q60DW Built-in Dishwasher Logo
946 people viewed this question
Top Stoves Dishwashers Experts
Owen Barnes
 Russ Hill
Russ Hill
Bill Boyd
Are you a Stoves Dishwasher Expert? Answer questions, earn points and help others
