Question about Samsung Televison & Video
Ihave a problem with samsung monitors. it is powe directly by 240ac not via a adaptor. What we are seeing is that on the top of the screen we are seeing picture shift..,.,i.e left an right movements. AND if we change the settings to under scan we actualy see the picture bent,,,about inch from the top. The left and right movements are not continuous. Any ideas as to what might be causing this problem. Other than the monitor itself.. thanks
Consult a professional person from the company
Posted on Jun 24, 2008
How to connect laptop to external monitor
Your HP laptop should have a video out port somewhere - it might be a VGA or HDMI, see the manual for your laptop.
If you are lucky your Bush will have a matching connector
Buy a cable of the correct type to connect your laptop to the monitor. If the connectors 'match' this is easy, or else you will have to seek out adaptors/adaptor cables.
Use the cable connect the laptop to the monitor.
There is one more thing you have to do, and that is direct the laptop's video output to the correct output port. On my HP laptop, and a number of other laptops, there is function button for this: press it once and the screen will appear both on the monitor and the laptop, press it again and your laptop screen will go off but the picture will be displayed on the monitor, press it again and the picture will appear on your laptop's screen but not on the monitor
1.September.2014
Sep 01, 2014 | HP Computers & Internet
Hi, I have an LG Flatron L227WTG monitor. I have 2 computers on my desk. When I plug the monitor directly into my home computer, the monitor works just fine. When I plug it into my work laptop (via a...
Hello, maybe you've got to switch the output from your laptop screen to the external screen, if so, it will be by pressing and holding down the Function button and at the same time pressing one of the Function keys (at the top of your keyboard). On mine, (an HP) it's F4, but you'll see a symbol on the correct key that looks like a screen. Regards, nicam49
Jul 13, 2011 | LG 22" FLATRON LCD Monitor
I just hooked my lap top to my Samsung hdtv with a vga display cable - what do i need to do to get the picture to come on the screen
Most computers have a function key that allows the screen to be viewed via monitor or projector. Most PC computers are Function f5 but some are f8. if it is not one of those check your keyboard for a monitor screen on one of the keys or your manual to see which function key your laptop requires.
Apr 23, 2011 | Samsung Televison & Video
Hi, I bought my samsung 2333 syncmaster in the U.S. but moved to New Zealand where the voltage is 230, can I use the monitor with a converter plug or with a NZ compatible cord?
Samsung 2333 have switching power supply and it can work from 100-240VAC 50/60Hz with out any modification or adaptors. Feel free to use it in USA or New Zealand. You need only to arrange plug converter. Check specifications on Page 49 of 2333SW user's manual available on: https://www.manualslib.com/manual/201694/Samsung-Syncmaster-2333sw.html?page=11#manual Samsung SyncMaster 2333SW User Manual Your Monitor Initial Settings
Jun 03, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Monitor Blank screen,
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
May 02, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
Screen on first start doesn't work
I have a SyncMaster 931BW which I duel Screen with a analogue montior.
There are Three things that I would check:
  1. Connection: if you are using the DVI adaptor, try using just the analogue (VGA) connection into your PC. You may have a faulty DVI adaptor which the PC cannot detect an output device.
  2. Drivers: If you have a standard monitor connect that to the PC and see if there is any output, if so, you may need to install the drivers for your monitor. You should have a Samsung Drivers Disc, or visit the Samsung website: http://www.samsung.com/uk/support/download/supportDown.do?model_nm=930BF&mType=DR&vType=L
  3. Cable: ensure that the cables are not knotted, and that within the adaptors the pins are all there and not bent as there is not a proper connection with the device.
Try them.
Jan 01, 2008 | Samsung SyncMaster 930BF 19" LCD Monitor
Samsung SyncMaster 191T
Sounds like the invertor board in the monitor is bad or the LCD screen has had it and needs replacing.
Jun 04, 2007 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Televison & Video Logo
Henry  Thomas
Henry Thomas
