Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Bizhub c 250
We have frequent paper jam. We have tried replacing the papers with fresh rims, but the problem persists. Tried to get a technician to service the machine and yet nothing improved. It hardly prints a page or two before it jams at various places. The machine is only 14 months old.
  • Bipin Agarwal Jul 02, 2008
    Hi Kevin,
    We are using 80 gsm standard A4 (Fuji Xerox) paper. It jams at all 3 spots. At the feed tray, in the roller, and at the exit point.
    The technician could not figure out the reason for jamming and left saying that its the design fault.
  • 167 Answers
What type of paper are you using?
What is the gsm?
What did the Technician say about the jamming?
Posted on Jul 02, 2008
Adf konica minolta bizhub 350. theres adf working good but no printout. a few minute machine says jam paper at adf. actualy original it was throw out.. help me please...
Konica Questions answered here ' FixYourOwnPrinter
Aug 22, 2008 - Am working on a Magicolor 2300 DL that sometimes fails to lift the paper tray ... good afternoon I have a konica minolta bizhub c550 when I open the ... I'm no printer tech, but in most other lasers (HPs, etc) the paper tray lifts, .... It seemsthere is a "waste toner sensor" which only lets the printer print out a few ...
Konica Minolta paper jam adf scanner Questions & Answers ... > Forum > Tags > paper jam adf scanner
Question about bizhub 350 All-In-One Laser Printer ... Konica Minolta bizhub 250 jammed but no paper ... Good luck. ... ...paper is there if the switch is working the adfboard is fualty or the cable between the machine and adf broke from all the ...
Konica Minolta bizhub document feeder not working ...
Jan 23, 2016 | Konica Minolta Office Equipment & Supplies
Frequent paper jamming, occasional false paper jam indication, black shade on the right side of the paper in my 10 months old (counter-64000 prints) Kyocera fs-1024 MFP photocopier. Cleaned the glass,...
Myself able to solve the issue, by replacing the drum yesterday. The drum is damaged due to non-removal of waste toner! Misguidance, improper service from Abhishek Enterprises, Shimoga.
Sep 22, 2013 | Office Equipment & Supplies
At power on, my bizhub 222 immediately gives me a paper jam error in the top feeder every time the machine is turned on.
If you have verified that there is no jammed paper, then I would suggest taking a can of compressed air and blowing the doc feeder out as best you can. Often times dust or paper scraps and debris can become lodged in the paper path, frequently blocking a sensor, thus creating a jam (despite the lack of paper.) As well, you might try running a thick piece of card stock through the feeder, as this will act to dislodge any stuck paper bits.
Let me know how it turns out.
David R.
Dec 09, 2010 | Konica Minolta Bizhub 222 Black and White...
My brand new machine Bizhub 211 have paper jam problem
COF32 means the ATDC sensor has detected some unusually high or low readings.
The ATDC sensor measure the toner lever inside the developer unit.
Try swithcing on/off, open/close the front door to clear the code.
If this doesn't work, you'll need an engineer to reset the ATDC level.
Good luck
Apr 12, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub 250. error c2152
Check and make sure there are no jams by the fuser ie: bits of paper in the paper path.
Sep 22, 2009 | Konica Minolta bizhub C250 All-In-One...
Please check the sensors and actuators ,open & close front door to reset nisfeed.Clarification Top feed = Automatic Document Feeder?If YES,please verify misfeed paper beetween coverplaten and feedbelt(Yellow).Is necessary disassembly the ADF.Good luck.You will find a little paper.
Jul 31, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Frequent paper jam
Where is it jamming?
In the feed tray, along the paper path, in the imaging unit or at the exit/finsiher?
The first thing is to be 100% SURE you are entering the paper settings correctly.
Jun 24, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Frequent paper jams.
Heavy cardstock and certain types of slick or coated paper can cause frequent paper jams. To better isolate the cause of your problem (machine or paper), try a new ream of regular 20 lb copy or laser paper.
  • Don't Overload
    Overloading your paper tray can cause paper jams. Your manual may say that your input tray can hold 250 sheets -- but if you keep getting jams, try loading 225 sheets instead.
  • Check the Paper
    Check the minimum/maximum paper weights that your printer can handle. Paper that is too thick, or too thin, can cause jams.
  • If you still get paper jams after this may be its time to clear the internal of the machine..You might want to have a look at the following link..
Nov 04, 2007 | Samsung ML 1710 Laser Printer
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
226 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
