Question about SanDisk Sansa Clip MP3 Player
Cant transfer songs from the computer to the player
Hi guys, look, my computer was back from a fix yesterday, and when i insert the USB cable, my computer didn't show me the sansa clip file in "my computer" and now i can't transfer songs from my computer to the player.what im doing now? please help!
  • 1 more comment
  • 31188 Jul 25, 2008
    i cant find the sansa clip in windows explorer. ther's no option of "open device".
    there's no description of a new usb connected.
    but i am able to transfer songs thru widows media player.
    the problem is the clip shows me there is a decrease in memory, but i am unable to find those songs in the player.
    wat can i do ?
  • oswaldjude Jul 25, 2008
    Bought a brand new one. Plugged it in XP, said found new hardware and when i later opened my computer, wasnt there..
    Also indicated charging the moment i plugged it in but then stops auto after a few seconds
  • ramana50690 Sep 01, 2008
    Could not see the device on my computer after connecting the player to the computer through usb port (using XP)
Chiquititas and oswaldjude sound like they have a similar problem. Try disconnecting the Clip, turning it off, setting the slider switch on the left to "Hold", and then reconnecting to USB while holding the center button down. Continue to hold the button for about 5 - 7 more seconds before releasing.
For 31188, what version of Windows are you running? Depending on what version of WMP you have, there are different ways to see the songs on your Clip in the interface.
Posted on Aug 06, 2008
I want to download music using my usb
Hi,you can transfer music to nokia 5800 from your computer(pc or mac). There are different ways of transferring music.if you have a PC, you can use PC Suite to transfer music files.the nice software that comes with the phone. If you have a Mac, you can use Nokia Multimedia Transfer (free download) and sync it with your iTunes.
how to put songs on nokia 5800-nokia pc suite
To transfer music as data files, make the connection with a compatible USB data cable. You also need to have a compatible memory card inserted in the device. View your nokia 5800 on a computer as a mass memory device. follows these steps: firstly, connect nokia 5800 with computer via USB data cable. then select Mass storage as the connection mode. A compatible memory card must be inserted in the device. then view the device from the computer file manager as a mass memory device. now you can fansfer the music files. after transferring songs, you can close the connection by remove the USB device safely from your computer.
Hope it helped.
May 24, 2011 | Nokia 5800 XpressMusic Smartphone
Tip
Connect MP3 Player To Computer and Transfer MP3 Songs From Computer To MP3...
To successfully transfer songs either MP3 or WMA files to your MP3 player follow these steps.
1) If your device came with a CD insert this into your computer and follow the on-screen instructions.
If the device has no CD most PCs will recognise the device and update the drivers automatically once you have connected it via USB cable.
2) Connect the device to the PC using USB cable. With many players this is the only means of charging the device.
3) On your computer go to 'Start' - 'My Computer' and you should see the device listed as a USB Mass Storage or Removable Disk.
4) Click and highlight the songs you want to transfer to the MP3 player. You can either drag and drop them directly into the USB Mass Storage Folder shown in Step 3 or you can right click the song file and select 'Send To' USB Mass Storage Device.
5) The songs are now on your MP3 player.
6) Disconnect the player from the USB cable. The player will take a moment to update and you can now play the songs on the player.
Note: In order to transfer music files from a CD these must first be converted to MP3 in order for the player to be able to play them. To do this you can use Windows Media Player to 'Rip' the songs onto your computer in MP3 format. From here use the steps above to transfer them onto the player.
If your MP3 player has video capability these files will need to be converted in to a format that the player can handle. To do this, use the software that came with the device on the CD or you may use a free converter like this one if the original software is lost.
Hope this Tip has helped.
Please do reflect this and indicate your rating using the Yes/No buttons below.
on Jan 01, 2010 | Audio Players & Recorders
How to put on the songs on it
How to Add Songs on Samsung YP-U3 MP3 Players
The Samsung YP-U3 is an MP3 player that comes in various colors. This device has a built-in USB plug, so it's not necessary to have a cable to transfer songs from your computer. To transfer songs to your device, you will need to use a PC. If you don't have the Samsung Media Center installation disc, you can download the software from the Samsung website.
Instructions
Install the Samsung Media Center if you have not done so. This is the software used to transfer songs to the YU-P3. The installation disc comes with the device. Simply insert it and follow the on-screen prompts.
Insect the bottom end of your device. You'll see a hidden USB plug on the end. Push it outward to extend it. Plug the device into your computer's USB port. This is usually on the front of the tower. The Samsung Media Center will automatically start after a few seconds.
Locate the file you want to transfer to the device. The Media Center's screen will display the MP3 (and other audio) files currently on your computer. When you find a file you want to add, click on it.
Click on the "Right Arrow" button. This transfers the song to the device. Repeat to transfer more songs, if desired.
Right click on the green USB icon on the right-side of your taskbar. Select "Safely Remove." Unplug your Samsung YP-U3 when prompted.
Hope it helped..
Have a nice day...
Feb 22, 2011 | Samsung YP-U3 MP3 Player
How to get songs back in the coby mp3?
On the MP610 you could use either Windows Media Player 11 or Coby Media Manager for transfers of songs.
Next steps are important for adding files onto the player:
1. The player should be detected in the software for transfers, when connecting the USB cable.
2. Setup your library in the software (Add to library): There has to be a list of folders in the software manager, where your music is located on the computer.
3. Create a playlist in the software: make a list of songs, you want to transfer onto your player
4. Sync the playlist onto the player.
When needing more help, just add text in this reply.
May 11, 2010 | Coby MP-610 MP3 Player
I am trying to put more songs onto my mp3 player. The songs show that they're on there on the computer, but when i unplug it the songs aren't shown on there. It says i have plenty of space, so that's not...
Hello.
Welcome To Fixya.
In order to have a succesful Transfer of songs from you computer to your mp3 player follow these Steps:
1/ Install:
  1. Insert the CD supplied with your product into the CD ROM drive of your PC.
  2. Follow the on-screen instructions to complete the installation of Philips Device Manager and Philips Media Converter. The Philips Media Converter converts video clips and JPEG pictures into suitable formats for the player.
2/ Connect and charge:
  1. Connect to PC:
    When you connect the player to the PC, it automatically charges.
  2. Connect the supplied USB cable to the mini USB port at the bottom of the player, the other end to your PC.
3/ Transfer:
Your player appears as a USB mass storage in Windows Explorer. You can organize files, transfer music and picture to your player during USB connection. Use Philips Media Converter to transfer video file. See Media Converter for details.
Transfer music:
  1. Click and highlight one or more songs to transfer between your player and your computer.
  2. Use drag and drop actions to complete your transfer.
Tip : To transfer music CDs to the player use software such as Musicmatch Jukebox or Windows Media Player, rip (convert) the songs on your music CD into MP3/WMA files. Copy the files into the digital audio player via Windows Explorer. Free versions of these programs can be downloaded from the internet.
Also you can Transfer Video:
The Philips Media Converter converts video clips and JPEG pictures into suitable formats for the player. You can install the software from the supplied CD.
Thank You For Using Fixya.
Good Luck.
Nov 06, 2009 | Philips SA3025/37 Flash MP3 Player
Just got my computer back from shop and i can`t put songs on M230
Check to make sure you stll have your driver for the player on your computer. If that does not work try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings. After doing this if you still cant add music on your player try loading it this way: 1. Free a USB port on your desktop computer. Now, grab the USB cable for your SanDisk Sansa MP3 player and connect the player to your computer. 2. Wait for your computer to find and recognize the player. This may take a few moments. Once you receive a confirmation message, open your computer and scan the icons for the SanDisk MP3 player. 3. Open the SanDisk Sansa MP3 player on your computer. The music files that you currently have saved to the player?s memory are displayed. 4. Open a folder containing music files that is stored in your desktop computer?s memory. Scan the files for songs that you want to transfer to the SanDisk Sansa MP3 player. 5. Left-click on a song file and drag to the SanDisk Sansa window. Drop the file and let your computer complete the transfer. The transferred file appears at the bottom of your music list. 6. Unplug your SanDisk Sansa player from your computer. Turn the player on and allow the file transfer to update to the internal memory of the MP3 player.
Oct 01, 2009 | SanDisk Sansa m230 MP3 Player
Cant connect to pc
  1. Connect the USB cable to your computer.
  2. Press and hold the menu[0].jpg button while plugging the other end of the USB cable into the YP-Z5.
  3. When the display shows USB Connected, release the menu[0].jpg button.
  4. The device is now in USB mode.
  5. When through, you must safely remove the USB device. Note: To safely remove the USB device, right click the USB icon ( usb_icon.jpg ) in the bottom right of your screen, and then click Safely Remove Hardware.
  1. Upon disconnecting the device, it will return to MTP Mode.
Dec 07, 2008 | Samsung YP-U3 MP3 Player
Cant load songs
the best way for that is to read your manual.
MINIMUM SYSTEM REQUIREMENTS
Windows XP SP1
Windows Media Player 10
Intel Pentium class PC or higher
CD-ROM drive
USB 2.0 port required for hi-speed transfer
CONNECTING AND TRANSFERRING
Connect to your Computer
1. Connect the small USB Cable Connector to the USB port on your computer, and then plug the larger
Cable Dock Connector in to your Sansa c200 port.
2. Once connected to computer, it should be detected by the operating system automatically and is
shown as an additional drive called “Sansa c200”.
SANSA MEDIA CONVERTER
You will need to use Sansa Media Converter to transfer photos to your Sansa c200. Insert your SanDisk
CD and select Sansa Media Converter to install it to your PC. Then you can load your personal photos
onto your Sansa c200 by using Sansa Media Converter.
TRANSFER MUSIC
To transfer music to your Sansa c200:
1. Connect Sansa c200 to the computer.
2. Drag and drop files from your computer to Sansa c200 by using a variety of music software
programs to transfer/synchronize your files.
3. In MTP mode as long as the files are WMA or MP3, they can be dragged into the Media folder.
Otherwise, they can be dragged into the Data folder (these files will not appear on the player).
4. In MSC mode, files/folders can be dragged/copied to the device.
Jan 27, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Using Windows Media Player 11 or Real Player 10.5 to Transfer Music
make sure to use the applet in the system tray (bottom right corner) that when left clicked, opens a list of available usb devices to stop before disconnecting.
Jun 01, 2007 | Samsung Napster YH-920 MP3 Player
Insignia 4MB MP3/video player
File allocation table on your player is corrupt. try to use the following method to transfer files from your player to your c drive... else... all is gone...
You can use Windows Explorer to transfer files to and from your insignia sport player. First, in the settings on your player, go to Settings, USB Mode, Connection Type and select File & Folder. Then, plug your player in to your USB cable. Windows XP should automatically find your player and make a new drive letter in Windows Explorer. Simply drag and drop your files to/from your c drive to the new drive for your player. You'll notice that when you use Windows explorer to delete the files on your new drive for your player that it doesnt remove them from your Music Library on your player. You'll need to use your player (settings, system, erase internal) to erase internal (and external), but after that when you add new files, they will be added to the player when it does the profiling after you disconnect the USB cable. Dave@OgleServices.com
Mar 13, 2007 | Insignia IN-MP3256 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
54 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
