Question about Panasonic PT-56TW53 56" Rear Projection Television
Removing kft7aa334f1 How do I remove cables from kft7aa334f1; there is 1 thick red cable and 1 thin red cable, keeping my board attached. Is this a transformer?
  • vet2viper1 Jul 23, 2008
    My set is the Panasonic PT-53WXD63G . First sign of trouble appeared with double image of channel numbers and then the squeezed picture, and finnally lost picture, but have sound. Now when I power up unit, it clicks once with several beeps after (maybe 5 or 6 times). It continues this with an on and off cycle untilI I power off the unit.
  • Panasonic Master
  • 8,617 Answers
Yes thats the flyback or HV transformer.
Posted on Jun 24, 2008
My microwave says "SE" or "5E" and won't work. What does this mean?
The problem lies with the mylar ribbon cable that connects the Keypad to the circuit board. The Mylar ribbon cable folds back onto itself and are touching. Over time the mylar 'breaks down' electrically and the wire traces in the mylar will 'arc' onto the other mylar ribbon cable. The solution is to separate the two mylar ribbon cables using paper and electrical tape. I've done this on several microwaves (not just Samsung) and it has worked every time. Patience and about 20 minutes is all it should take to fix it. I've described below how I did it for the SMH9187ST Microwave Good luck to all.
1. UNPLUG THE MICROWAVE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2. 1. Remove the top front cover by removing the (2) screws that are along the top edge (phillips).
3. 2. Slide the cover to the left about a half inch (there are tabs holding the cover in place) and remove.
4. 3. Remove (1) screw from the top of the Keypad Housing (phillips). Lift the Keypad Housing upwards about half an inch (there are tabs holding the Keypad Housing in place) and remove. Be careful of the metal grille that is just above the Keypad Housing as this may fall out since it is being held in place by the Housing.
5. 4. Be careful not to pull on the wiring harnesses that are attached to the Housing. Carefully unplug the wiring harness that has the RED connector on it from the circuit board. Carefully unplug the small white connector that has the mylar ribbon cable on it (this cable is see-through and you can see thin, flat wires in it).
6. 5. Remove (4) screws that are holding the circuit board onto the Housing.
7. The Housing should now be free of the circuit board and wiring harnesses. It's safe to let the wiring harness/circuit board hang free, but caution should be used anyway.
8. 6. Remove the thin metal frame from the Housing. There are (4) plastic tabs holding the frame in place. Using a small screw driver pry one side of the frame away from the housing (try to do this to the side that has smaller plastic tabs). When this side of the frame is free of the Housing you have to lift the frame out at an angle to remove. It might put up a fuss, but be patient and be gentle with it since the frame is thin and fragile.
9. 7. With the frame out of the way you will see the mylar ribbon cable that is coming out from underneath the Keypad assembly. You will notice that the mylar ribbon cable folds back onto itself as it re-enters the Keypad assembly. This 'touching of the two ribbon cables' is where the trouble lies. The ribbon cables may be stuck together. Carefully separate these two and then insert a small piece of paper between them (paper can be 1/2 x 1/2 ) and work the paper all the way down into the Keypad assembly as far as it will go.
10. 8. Using electrical tape, apply a small piece between the ribbon cables to hold the paper in place. Next, use more electrical tape and put it between the mylar ribbon cables enough so as to keep the ribbon cables separated.
11. 9. Re-attached the thin metal frame making sure to press it into the Keypad assembly enough so that the (4) tabs click into place.
12. 10. Use electrical tape and apply it to the raw metal edge of the thin metal frame to prevent the mylar ribbon cables from rubbing on the metal edge.
13. 11. That's it. A final word of caution. Be careful when inserting the ribbon cable connector back on to the circuit board. The connector is loose and you need to gently place the ribbon cable into the circuit board connector.
14. 12. Reverse the order of assembly from above.
15. 13. Plug in the microwave and then it should reset and ask you to set the time.
Best of luck to you
Dec 29, 2014 | Maytag Appliances Over-the-Range Microwave...
Unable to re-cable Autochlor SM30 saltwater cell
check where you bought it or email company they might have upgraded cable they will steer you in correct direction
Jan 30, 2014 | Pool & Spa
How to remove starter from 06 honda civic
- Remove the ignition key and place it out side the car.
- Remove Negative battery Cable.
- Remove the Positive battery Cable.
- The starter is located under the intake manifold. On the back of starter motor there are two wires which need to be removed prior to removing the starter. One is the thick wire (White) which is attached to the solenoid on starter by mean of a nut and the other thin auto wire (Black/ Red) attached by means of a slip thimble.
- Remove both the wires.
- Remove the two main bolts holding the starter motor and take it out.
Apr 13, 2013 | Honda Civic Cars & Trucks
Samsung microwave shows SE on display
16. Hope this works for you !!
Jun 13, 2012 | Samsung SMH9187ST Microwave Oven
A creative speaker SBS A200 connector pin was damaged. we need to connect that cable directly into the board.so we need that pin details.
Hi, I hope this helps,
Pins look like this: (Top view, not copper side)
1 2 3 4 5
6 7 8 9
1 = Thin white wire from thick white cable (Left input)
2 = Gray (Speaker out)
3 = Orange (+V return from volume unit to bass unit)
4 = Not connected
5 = Thin Red wire from thick red wire (Right input)
6 = Blue (+V power from bass unit to volume unit)
7 = Black (GND - if socket removed, solder 3 socket shield holes to each other or solder black wire directly leftmost hole)
8 = Not connected
9 = Shield copper from thick red wire
Shield copper from thick wire : Solder to GND or Left unconnected
Jun 23, 2011 | Creative Technology SBS A200 2 Speakers
The microwave display shows "--SE--" I have not
This fixed mine.
Jun 11, 2011 | Samsung SMH9187ST Microwave Oven
My smh model is less than a year old -SE- appears on the display screen does this mean the keypad needs to be changed?
If memory serves me, -SE- means system error which indicates a keypad failure, the microprocessor ic is mounted on a circuit board along with other componants directly behind the keypad and controls the oven vital functions. If you have any warranty of any kind, now is the time to use it.
Jan 28, 2011 | Samsung SMH9187ST Microwave Oven
How do you put a starter solenoid in a 1988 ford f150?
Ford does not put the solenoid on the starter itself, so then it is just a relay, usually on a fender. It will have 4 wires. Two thick ones from the battery and to the starter. And 2 thin ones from ignition switch and to ground.
Oct 31, 2009 | 1988 Ford F 150
How do i open the cd player on e182h? no diagram
If you know to remove your side cover of the cabinet(tower) i will help you to remove the cd drive, you have two cables in your cd drive 1 is power cable which has red, black and yelow wire if you unplug it will plug out, same as you have another cable which is data cable it will be like thick single red cable or it wll like flat cable . if you remove both this cable you can remove the player by removing the side screws and push the player towards outside.
Oct 21, 2009 | E-Machines eMachines Desktop PC
What cables are what
black is ground red is power with key on yellow is power all the time blue white is amp remote wire you dont use this if you dont have amp.
Sep 23, 2008 | Kenwood KDC-3024 CD Player
Panasonic PT-56TW53 56" Rear Projection Television Logo
266 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
