Inspect/Replace
If it is necessary to remove the heater assembly, the cooling system must be drained before removing the heater core.
When a heater core leaks, a new heater core is installed or the old one repaired.
Heater Housing
The heater housing is disassembled to get to the heater core.
Heater Core
When the heater core leaks and must be repaired or replaced, it is a very difficult and time-consuming job primarily because of the core's location deep within the firewall of the car. For this reason always leak test a replacement heater core before installation.
For heater core replacing procedure. I suggest you to go through
this related help links.Its all complete step by step procedure: ----How to replace heater core for All car models? Click the link below: --- http://technoanswers.blogspot.com/2011/11/how-to-replace-heater-core-for-all-car.html -------------- http://schematicsdiagram.blogspot.com/2011/12/how-to-flush-heater-core.html --------------- http://howtobyme.blogspot.com/2011/12/how-to-remove-heater-core-on-2008-honda.html http://howtobyme.blogspot.com/2011/12/honda-heater-core-replacement.html ------------ How to replace heater core?http://technoanswers.blogspot.in/2012/02/how-to-replace-heater-core-on_10.html
How to Flush Heater Core?
How to Remove Heater Core ?
Heater Core Replacement?
To replace heater core?http://technoanswers.blogspot.in/2012/02/how-to-replace-heater-core-on.html------
----------This will help.Thanks.
