Question about Samsung HCM4216W 42" Rear Projection Television
Samsung Rear Projection Problem (not convergence)
Hello, I have searched the internet for days and I have yet to find a solution to my tv problem. I seem to have a blurry image from the red lamp, but the green and blue are sharp. There was a convergence problem earlier, but I completely replaced the convergence board. The Blue and green are aligned, but the red is still blurry. Its not that the red cannot converge, but rather it seems as if the red lamp is out of focus or lacking sharpness. (similar to the blurriness when not wearing glasses.)
I ran perfect focus in the customer menu, but it hangs at 20% because the red crt is not bright enough/light output is too weak and washed out.
So I'm convinced its not a convergence problem, but i cant seem to diagnose the problem.
Can someone please lend me a hand or some sort of direction.
p.s. - the tv was moved around in January (remodeling basement). It had a convergence problem then so I didnt power it on. Once the remodeling was completed (June), I replaced the convergence board, but found the blurry red images. Is it possible that the moving caused the red crt to misalign?
Any help is greatly appreciated, Thanks!
    Novelist:
  • 132 Answers
The tv has 2 focus adjustments for each tube, mechanical and electrical.
1. Mechanical focus is set by looking at screen from back (through inspection plate on back of most samsungs) and rotating the lens assembly on CRT. loosen wing nut and turn lens assembly to go through focus and back to best position.
Put convergence pattern on screen and manually misadjust bottom red and green lines convergence so they can be seen through inspection hole.
With back cover of TV off you can usually reach your hand up beside the lens assembly to loosen the wing nut then rotate to adjust. Green is in the middle. The focus will be obvious when you rotate and look
When you are finished make sure the foam dust protector is not over any of the lens assemblies and the wing nut is tight.
2. Electrical focus - located at front of unit. the front grille/speaker cover is removed and maybe a cover over the front crt inspection hole.
In the inspection hole there is a black plastic "Focus/screen adjust Assembly" with 2 rows of 3 controls.
One row is focus and the other is screen. The middle controls are for green with R/B on either side. Usually the controls are labelled as "focus" and "screen". You want to adjust the focus controls, one for each color. Look for the focus or screen label imprinted in the plastic. Don't play with the screen settings.
With the same misadjusted convergence pattern you can see a red, blue and green line. Adjust green focus and watch green line for best focus. Do same for other 2.
Screen adjustments are very exact and delicate. The easiest way to deal with them is to turn color off in Customer adjust menu. Put any color tone adjustments in the middle (low, med, high, put at med).
You should have a b/w picture if there are no crt or other color related faults. If it is close to B/W leave screens alone.
If the pix is too green, then the green screen setting must be reduced a small amount. Do not play with these adjustments as most TV repairrers have a difficult time adjusting them.
If focus adjustments don't help then focus control or CRT may be defective. Needs expert to determine.
easyab
http://calgaryconvergencerepair.weebly.com/convergence-ics.html
Posted on Jun 25, 2008
Samsung PCL545R 54 in. Rear Projection Television
Ur tv have a problems known as a convergence problems,it dead.The tv covergence board must have it 2 STK Convergence ICS and some or all resistors be rreplaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 05, 2010 | Samsung PCL545R 54" Rear Projection...
Hello my rear projectioin tv picture is now red and covered in lines . What could be wrong
Convergence is dead.Must know how to solders?Tries Tv repair World.com,Tvrepairkits.com buy a convergence kit replaced what in that kit.The shop will cost u $300 for parts and labors.
Jan 13, 2010 | Samsung HC-P4752W 47" Rear Projection...
Samsung HCN5529W 55in Rear Projection can't Perfect Focus
hello What you have is a convergence problem. There is 2 modules inside your set that aligns the colors to have the same geometry and superposed . It is a common problem in rear projection tvs ,
You don`t have to worry about your blue tube , i`m sure it is perfectly fine, it just needs to be aligned through the convergence circuit.
Most often the problem is with those convergence modules that are faulty and need to be replaced.
Hope this will help good luck
Dec 07, 2009 | Samsung HCN5529W 55" Rear Projection...
Coloring is off and there is a ghosting effect
Part # BP95-00142E is the correct convergence amp board for a model # HCN4226W. Part # BP94-00155A is listed as a "CG Amp assembly board" also, but is not correct for a model # HCN4226W. They are both basically convergence amp boards. Here's a link to order the original Samsung covergence amp board for this model (HCN4226W) from a major parts distributor:
Samsung HCN4226W Replacement Part Convergence Amp Board
Jan 30, 2009 | Televison & Video
Can't figure out the model of my Samsung Rear Projection TV
Most of these issues can be solved by resoldering the convergence ICs. Resolder the convergence ICs first and if it still doesn't work then look for a board. I bet you fix it...
Jan 12, 2009 | Samsung PCN5425R 54" Rear Projection...
Samsung HCN4226W Rear Projection TV
You can get the convergence board by clicking here.
The service manual you might buy it from the same place.
May 23, 2008 | Samsung HCN4226W 42" Rear Projection...
PCL542r convergence
Samsung part number AA95-00706C its available at www.partsstore.com
Mar 13, 2008 | Samsung PCL545R 54" Rear Projection...
Mixed colors and separation of colors
Common problem known as convergence. The most common reason is the failure of convergence ics. these ics fail all the time because there big and get fairly hot. there is a possiblity that it can be reconverged if the convergence cuircit is not damaged
Jan 05, 2008 | Samsung HCN653W 65" Rear Projection...
Samsung hcm4216 rear projection
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Aug 24, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HCM4216W 42" Rear Projection Television Logo
938 people viewed this question
Henry  Thomas
Henry Thomas
