Question about Acer Aspire 3680 Laptop
No sound I installed a camera on my laptop and had no sound, so I uninstalled it and still no sound. I also keep losing my recycle bin desktop icon. Thanks a lot!
  • lizandbaz Jul 03, 2008
    Hi, everytime i use msn, i try to use earphones, and they don't work, i really struggle to hear the person on the other end without them. if anyone has a solution, i would be grateful.
  • Blake Fletcher
    Blake Fletcher May 11, 2010
    Did the sound work before you plugged in your camera for the first time? This might also help, hit (and hold the Window Logo Key) and press the "R" key. when the run box comes up, type "devmgmt.msc" (minus the quotes). Now your device manager should pop up. If you see anything that says, "Unknown Device" or has any "?'s" anywhere let me know what it says.
Well, you could go to the hp update if you have it, this happened to me ,i had to reinstall confax sound speakers :)
Posted on Jun 24, 2008
Keep getting message message memory full how do i
the message is a virtual memory message.Too many programmes running at the same time usually.Adding more RAM if possible,closing programmes etc will help.You are probably using W8 which I have found opens programme after programme as you try to access different things,so you will have lots of apps working unseen using memory.This is not about the recycle bin.If you have an icon on the desktop right click on it and choose to empty it.
Aug 29, 2014 | Computers & Internet
How to install back the recycle bin icon how to erase download files in recycle bin
  1. Click Start, and then click My Computer.
  2. On the Tools menu, click Folder Options.
  3. Click the View tab, and then click to clear the Hide protected operating system files (Recommended) check box.
  4. Click Yes when you receive the warning message, and then click OK to close the Folder Options dialog box.
  5. Click Folders on the toolbar.
    Note If Folders is not visible on the toolbar, point to Toolbars on the View menu, and then click Standard Buttons.
  6. In the left navigation pane, under Folders, locate the Recycle Bin folder, and then drag the Recycle Bin folder to the desktop.
  7. On the Tools menu, click Folder Options.
  8. Click the View tab, and then click to select the Hide protected operating system files (Recommended) check box. Click OK.
Feb 26, 2010 | Computers & Internet
The recycle bin icon is gone
Right click on your desktop, select "Personalize", click on "Change deskop icons" from the left pane. and check Recycle Bin or
  1. Goto Start->Run and type in Gpedit.msc and press enter.
  2. Navagate to USER CONFIGURATION >ADMINISTRATIVE TEMPLATES >Click on DESKTOP.
  3. On the right hand pane find ” Remove Recycle Bin icon on the desktop ” , double left click on it to disable it.
Jun 26, 2009 | HP Compaq Presario CQ50-110US Laptop
I can't access my recycling bin
Go to desktop
Right click > Personalize
On the Left Hand Side, there would be an option for "Change Desktop Icons".
Click and then check the recycle bin and enter.
Any further help, let me know.....
Thanks.
Jun 11, 2009 | Dell Inspiron 1525 Laptop Midnight Blue
Go to desktop
Thanks.
Jun 11, 2009 | Dell Inspiron 1525 Notebook
Windows Vista Ultimate: Recycle Bin
If you find that when your Recycle Bin does not refresh but shows the same icon, irrespective of whether it is empty or full, here are some trouble-shooting steps you can try. Hopefully, one of these 5, should help you. 1) Check if you have installed any Theme or an Icon Package, and see if uninstalling it makes the problem go away. if so then the problem is in the Theme or Package. Also try switching the theme to Windows Classic theme and them back to Vista Aero default. 2) Right-click Desktop > Personalize > Change desktop icons > Disable / Uncheck Recycle Bin. Then click Restore Defaults. Click OK. Reboot. Now using the same method Enable /Check Recycle Bin, then restore defaults. Click OK. Refresh Desktop. 3) In the 'Desktop Icons settings' Dialog Box, check on Recycle Bin.
Then click on the ‘Recycle Bin Empty’ icon.
Click on 'Change Icon' tab.
rom the new box which opens, select the icon that shows the 'Recycle Bin Full'.
Do the same for 'Recycle Bin Full' icon.
Change it to 'Recycle Bin Empty' icon.
Now click Apply.
Now check whether, when the Recycle Bin is full, the empty-icon show. And vice versa.
If it does, go back and again change back the icons, to what they should be, using the same procedure, mentioned above. 4) Use the Group Policy Object Editor.
Type gpedit.msc in Vista's Start Menu Search bar and hit enter.
User Configuration > Administrative Templates > Desktop > Remove Recycle Bin icon from desktop > Double click on it > Enable > Apply Reboot.
Next, follow the same above-mentioned steps. But this time instead of 'Enable' select 'Not Configured.
See if it helps. 5) Repair or Re-build the Icon Cache. For this the easiest way would be to download and use TuneUp Utilities or Stardocks Icon Packager. They are not freeware, but you can use the trial versions to get your job done.
Apr 04, 2009 | Microsoft Windows Vista Ultimate Edition
I deleted the recycle icon by accident i would like to get it back please?
Assuming you didn’t turn off all your desktop icons (right-click your desktop, choose View from the menu, and choose Show Desktop Icons if it doesn’t have a check next to it, which will turn them back on), it’s easy to get back, so stop your sweating and follow these simple steps.
  1. Right-click on your desktop and choose Personalize
  2. Click on the Change Desktop Icons link in the upper left hand corner
  3. In the Desktop Icons Settings window, check the Recycle Bin box and click OK
WORKAROUND in case the above does not work loadTOCNode(1, 'workaround'); If you cannot restore the Recycle Bin by using the resolutions that are listed in this article, work around this issue by creating a shortcut to the Recycle Bin: 1. Click Start, and then click My Computer. 2. On the Tools menu, click Folder Options. 3. Click the View tab, and then click to clear the Hide protected operating system files (Recommended) check box. 4. Click Yes when the warning message appears, and then click OK to close the Folder Options dialog box. 5. Click Folders on the toolbar.
Note If Folders is not visible on the toolbar, point to Toolbars on the View menu, and then click Standard Buttons. 6. In the left pane, under Folders, locate the Recycle Bin folder, and then drag the Recycle Bin folder to the desktop. 7. On the Tools menu, click Folder Options. 8. Click the View tab, and then click to select the Hide protected operating system files (Recommended) check box. Click OK.Note This procedure does not re-create the original icon. However, this procedure restores most of the features of the Recycle Bin, including the following: • Delete a file by dragging it to the Recycle Bin icon on your Desktop. • Retrieve a file that you deleted by double-clicking the Recycle Bin icon on your Desktop, right-clicking the file that you want to retrieve, and then clicking Restore. • Empty the Recycle Bin by right-clicking the Recycle Bin icon on your Desktop, and then clicking Empty Recycle Bin. When you use these step to work around the problem, you cannot right-click the Recycle Bin shortcut to access the Recycle Bin Properties. To set properties for the Recycle Bin, follow these steps: 1. Double-click the Recycle Bin shortcut on the Desktop. The Recycle Bin folder opens. 2. In the upper left corner of the Recycle Bin folder, right-click the Recycle Bin icon, and then click Properties.
Aug 20, 2008 | Gateway Computers & Internet
Windows host process(rundII32)has stopped working.Also I have lost my recycle bin and cannot retrieve it.I am running Vista Home Premium.
Greetings,
If you still can, go Control Panel & perform a System Restore.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 22, 2008 | Computers & Internet
Recycle bin
Mar 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
Recycle bin got deleted
Acer Aspire 3680 Laptop Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
