Question about Maytag MSD2454G Side by Side Refrigerator
Ice in bottom of frost free freezer - Maytag MSD2454G Side by Side Refrigerator
  • 5 more comments
  • Anonymous Jun 24, 2008
    The coils inside my freezer get frozen. When this happens my refridge compartment stays warm
  • Michael Kruper Sep 28, 2008
    water collects and freezes in bottom of freezer compartment. leaking in from grill at back of freezer in bottom compartment
  • debbipardoe Oct 14, 2008
    I am having exactly the same problem. Does anyone have any suggestions?
  • rlgparker Nov 16, 2008
    We have this problem too! Help!
  • debeliades Dec 28, 2008
    Having same problem...sheet of ice forming on bottom of freezer every 3-4 days. Leaks water out the front after the ice becomes thick if you don't chip it away. Help!
  • itsandre56 Mar 31, 2009
    Ice is forming in bottom of freezer. Ive turned off the water to the ice maker to see if this was my problem and still continues to form ice in the bottom.
    I can see the heater eliment glowing and hear the water sizzle as is drips on it. Is this dangerus? Where is this water coming from? And how do i fix it?
  • Anonymous Apr 13, 2009
    I have water on the bottom left hand side around were the water lines connect is my connector bad or some thing else, Sims to leak when the ice maker fills
Water in the bottom of the freezer indicates that the drain in the bottom is preventing the excess water from defrost from draining. If you have the time you can empty you unit and let it sit for several days to completely thaw (unplugged and doors open), or you can unplug the drain in the freezer. Typically either of these two methods will fix the problem...
Posted on Apr 28, 2009
    Problem Solver:
  • 10 Answers
Drain pan is frozen up, Remove cover from back wall of frezzer compartment down to the grill openings. You will see a overflow tray backed up with frozen water. use hairdryer to free ice dam from drain hose -- That'LL fix ya!!
Posted on Mar 07, 2009
The heaters to defrost the coil may not be working
Posted on Jun 26, 2008
I have ice in bottom of the freezer as well... but water is coming from underneath the refrigerator. Is there a drain pan that needs to be emptied. Bought used from a friend and don't have manual.
Thanks
Posted on Nov 29, 2008
Rotu
  • 175 Answers
SOURCE: Icing up in bottom of the freezer
I don't know the particulars of your brand, but if it is frosting up Most fridges will have a bad heater element, a bad defrost timer (or controller if it is electronic) or most likely a bad defrost limit switch. This is a switch mounted on the inlet line of the evaporator with a clip and senses when the evaporater is defrosted so that it does not get too hot and start melting parts. This switch should have zero ohms of resistance when cold (below 40ish) and be completely open when above 40 or so. The easiest way to test it is take the wall covering the evaporater off and locate the plugs for the swiths. Test continuity through it. If it is sitting in ice, it should have no resistance. If it is open and in ice (infinite resistance) then it's bad.
Posted on Oct 05, 2006
Krazytech
  • 725 Answers
SOURCE: frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Posted on Mar 30, 2008
  • 1073 Answers
machine has a defrost issue, defrost mi metal or defrost timer
Posted on Apr 12, 2008
App King
  • 55 Answers
SOURCE: excessive frost/ice buildup near bottom on freezer
Hello.
If you remove the bottom drawer in the freezer you will be able to see the back of the freezer. You will notice a large build up of ice in the bottom of that panel. If this is the case, you will need to empty the freezer up to the icemaker bucket. There is a panel with several screw in it that you will have to remove. Once removed you will want to defrost as much of the ice as you can with a hair dryer. Once you get the ice down to the hole you will want to heat some water up in the microwave and pour it into the hole repeatedly until it clears the line and drains on its own. This will remove whatever bug of ice particle that blocked it. Put everything back together and you will no longer have this problem.
Posted on Jul 16, 2009
  • 842 Answers
SOURCE: maytag msd2641kew fridge side is
Sounds like a defrost problem, is there ice on the back wall of the freezer? If so the defrost system has failed. The most common repair is a Part# 67004757 defrost thermostat and adaptive defrost board Part# 67004704. Even with the parts in your hand, you will need to de-ice the freezer to replace the thermostat in the freezer section, then unplug unit to replace the adaptive defrost board located in the controls of the refrigerator section. Normally it can take about an hour to complete.
Good Luck
Posted on Jul 13, 2011
ICE FORMS IN FREEZER BOTTOM,
Keep the bottom of your freezer free from ice. ... The water from the melted ice and frost drains through a short tube and into a pan beneath the refrigerator, where it evaporates. Should the drain line become clogged, the water has nowhere to go and it freezes, forming a layer of ice in the bottom of your freezer.
How to Fix an Iced Freezer Bottom ' Home Guides ' SF Gate
homeguides.sfgate.com/fix-iced-freezer-bottom-42777.html ICE FORMS IN FREEZER BOTTOM Google Search
Oct 23, 2017 | Refrigerators
Why does my freezer build up with ice in the bottom
is it a frost free model? if it is the defrost timer may be out or the defrost element may be bad. but if this is not a frost free model the door seals may be bad and need replaced
Aug 24, 2014 | Amana ABB1922FEB (185 cu ft) Bottom...
Frost free freezer with ice in the bottom and water dipping off bottom door hinge
Frost Free Freezer have an automatic defrost, which is essentially a heating element which melts any ice. If your door seals are in poor condition or something is preventing the door from sealing the ambient air may be melting the ice more than the drain can accommodate. Check the drain in the bottom of the freezer. Humidity can also cause more water to accumulate, especially if the door seals are not sealing.
Jul 10, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
Jul 01, 2009 | Freezers
Refrigerator is barley cold, still makes ice, condensation inside of frostless freezer
Hi: The fact that it still makes ice tells me the freezer is a zero degrees. When you said condensation in the freezer did you mean frost? If your defrost heater fails it will cause the frost free freezer to build up frost. The frost will build up and block the vent that supplies the cold air to the fresh food. The defrost heater is behind the metal wall at the back of the freezer, at the very bottom. A glass tube with a metal coil in it. The coil can break and stop the defrosting. Replace that. Use a hair dryer to melt the frost from behind the panel. All of it top to bottom. You need to remove all the frost to free up the airways. I hope this helps, Jeff
Jun 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Build up of ice in bottom of freezer compartment
During the defrost cycle heaters in the wall of the freezer are turned on to melt the frost build up. This melted frost "water" is supposed to run out a drain in the bottom of the freezer and collect in a pan under the refrigerator/freezer where it will eventually evaporate. If this drain is blocked it will cause a lot of water to collect in the bottom of the freezer and that water will eventually turn back into ice. I recommend defrosting the freezer manually, removing all the ice/water buildup in the bottom, and trying to unplug the drain line to the pan underneath. Also check the seal on the freezer door. If it's not sealing well it could be letting a lot of moisture enter the freezer which would lead to more frost buildup and more water during the defrost cycle.
May 22, 2009 | Hoover HCA390FFK Bottom Freezer...
Maytag model MQU1556AEW, frost-free freezer forms ice in bottom.
I'm not sure if this will help but the freezer that is located on the bottom of my refrigerator started forming ice on the back part where the cold air was supposed to be coming out. I kept hearing a hissing sound like water dripping on a hot surface. I called the repair man in and he had to replace the defrost timer. Once he did that it worked like a charm.
I am not an expert by any means although removing ice from a frost-free freezer is a pain and this took care of the problem for me. Good luck!
Apr 07, 2009 | Maytag Freezers
Fridge wont stay cold in the bottom.
Your frost free is not defrosting properly. There should be no ice buildup in the freezer section. Frost in the freezer section stops air circulation to the refrigerator section.
Jun 28, 2008 | GE Refrigerators
Apr 12, 2008 | Refrigerators
Is the frost build-up in my freezer normal? Why do I have ice in forming the the bottom of my frost free freezer?
The drain has most likely frozen over. It is at the bottom behind the back panel inside the freezer. You will need to remove all of the ice and run hot water down the drain until it is clear.
Nov 16, 2007 | Freezers
Maytag MSD2454G Side by Side Refrigerator Logo
259 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
