Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Older Bissell Proheat 12 amp black shampooer, BLADDER separate / LEAKS
Water witholding container, the BLADDER separates / colapse in container, so that water leaks out quickly before I can start machine.
Is it possible to order a bladder replacement? L
  • 1 more comment
  • captiv1326 Aug 21, 2008
    I have the same problem and unfortunately all of the forums that I have read say that the "Bladder" is uncapable of handling HOT water it can only handle WARM water or the neck of the bag will deform and you will have to purchase another one at a cost between $25 - $40 + S/H . So for this I give Bissell a BIG NEGATIVE for this product, I wish they would have never gotton away from the older models that connected straight to the kitchen faucet for fresh water !
  • Anonymous Feb 15, 2009
    flex hose has low to no suction/model 3910
  • Anonymous Mar 03, 2009
    bladder leaks no matter how I try to fix it. I only used the machine 2 times before the problem started
    New Friend:
My bissell does not spay out water
Posted on Feb 08, 2013
Depending on the model yes:
Google turned up several sites -
http://www.svcvacuum.com/bissell/tanks.htm
You can also look at Bissell www.bissell.com
Posted on Aug 17, 2008
Took inner bladder out now won't hold water
Inner bladder is needed to hold the fresh water for spray. Make sure the bladder is pulled through the bottom of the tank and that the black cap with a red rubber seal on the bottom of the tank.
If the black cap is missing you'll need to purchase a new one. Here's a quick link.
http://www.bissell.com/parts/?id=9143&sc=product&productid=2813&cid=ccsocial
Here's a quick link to locating a BISSELL Authorized Service Center if you need more assistance.
http://www.bissell.com/service-centers/?cid=ccsocial
Nov 13, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
Not sure where water goes ? in bladder and with solution on back
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
qwewr
Apr 25, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Whare does the dirty water go in the bissel 12 amp pro heat carpet cleaner
the clean water goes into a "Bladder Bag" that is located inside the tank. The way it is designed to work, as the clean water dispenses from the bladder bag, the outer part around the bladder bag fills with the dirty water. It never touches the clean water. Seems wierd, but it works! I hope this helps, if it does, please give feedback, as it helps me to gain ratings. Thank you! Remember to have your cleaners serviced every year by a qualified tech! Rene (The Vacuum Doctor)
Nov 06, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
I have the bissell x2 12 amp carpet shampooer
The water should be picked up fairly rapidly into the area surrounding the clean water bladder. Try checking the lint filter to fix your suction problem. It is located in the top clear plastic section (the one with the dial to switch from tool to floor use). One the under side of it there is a small (1 inch square) red filter with a little door on it. Flip open the door and it is probably clogged with hair, carpet fibre. etc.. Clean it out and you should have suction.
Jul 09, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 12 amp proheat power brush
heatman101
ety
Mar 04, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell carpet shampooer
First check that the top cover on the back side hasn't come loose. Sometimes the plastic around the screws break away and the top starts to separate, raising the tank, and no spray. Make sure that the gaket is on the valve at the bottom of the tank and not sitting loose in the hole. Check the pump belt. The pump may be bad.
Jun 15, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
1,281 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
