  • 100 Answers
Give details
Posted on Jun 24, 2008
Telescopic steering wheel wont tilt
Telescopic steering wheel stopped moving - Forums
Jan 9, 2008 - Telescopic steering wheel stopped moving ... If it won't move at all, and you don't even hear a motor, it could be a fuse; check your fuse diagram ... Steering wheel adjustment motor gone bad?
Jan 28, 2008
HOW TO: Fix power steering column that will not move up and ...
Jul 12, 2007
More results from
Fixing the Power Steering Wheel of a Lexus LS400 - YouTube
? 2:15
Jan 4, 2012 - Uploaded by AutoTech USA
If your power steering wheel is no longer working; moving up and down, back and forth, and when you attempt ...
telescopic and tilt steering not working - Cadillac Forums
Dec 01, 2015 | Cars & Trucks
Chevrolet Truck Steering Wheel Removal Instruction
1 Turn the steering wheel from side to side until it locks into place. This will make the process a bit easier, as the wheel won't be turning as you work.<br /><br />2 Remove the horn button in the center of the steering wheel by pulling it off towards you. This will expose the steering wheel nut at the center.<br /><br />3 Unbolt the center bolt from the steering wheel, using the 1/2-inch ratchet, extension and socket. This might free the steering wheel right away, but most likely you'll have to proceed to the next step.<br /><br />4 Position the steering wheel puller on the steering wheel such that the center bolt on the puller is on the center shaft of the wheel. Then thread in the bolts supplied with the puller into the two threaded holes on either side of the center shaft on the wheel.<br /><br />5 Tighten down the center bolt on the steering wheel puller using the 1/2-inch ratchet and socket until the steering wheel pops free. Then remove the steering wheel puller from the steering wheel.
on May 28, 2011 | Chevrolet 1500 Cars & Trucks
Steering wheel radio controls and horn not working - Jeep Wrangler ...
Sep 22, 2014 - 12 posts - ‎6 authors
... 2Dr sport and my step/reset buttons, radio control and horn all stopped working. ... Also the lights behind the step/reset and cruise control went out, but the ... Soundslike a bad clock spring ribbon cable in the steering wheel. steering wheel buttons not working
Jun 14, 2012
Steering wheel audio controls
Mar 5, 2011
More results from
Nov 23, 2015 | Cars & Trucks
Horn and steering wheel controls not working.
    images for 2004 Suzuki Forenza no controls on
    Suzuki Steering Wheels and Horns ' eBay
    eBayFind great deals on eBay for Suzuki Steering Wheels and Horns in Steering ... 2004Suzuki Aerio Grey and Black Steering Wheel with Airbag OEM 2003 ... 04 05 06 07 08SUZUKI FORENZA- Steering Column, Black with Key, NO AIRBAG ... 2006 Suzuki Aerio Gray Leather Steering Wheel with Controls OEM 05 06 07 Nice.
Sep 25, 2015 | 2004 Suzuki Forenza
Replace steering wheel of toyota corolla 1990 model
The steering shaft has splines that allow the steering wheel to be positioned correctly with the front wheels.
Try tapping behind the streering wheel with a hammer to loosen so you can pull the steering wheel off.
If this does not work then you need a wheel puller to pull the steering wheel off the steering shaft.
Jun 10, 2012 | 1990 Toyota Corolla
There is vibration problem when I drive over small bumps in the road. It is NOT a mettalic sound but more of a thud, thud thus sound. I changed the struts but it the sound is still there. We are not...
Gm has had issues with the steering colomn shafts and they get dry and cause this type of thud and vibration. Usually the mechanic just pumps the shaft full of grease to quite it down and that helps for a while. Have them check the sterring shaft for this condition as well as the ball joints. This condition is worse in trucks but it can be found in most GM cars as well over time.
Mar 26, 2011 | Buick LaCrosse Cars & Trucks
Took radio from car would like to put it back but dont have the instruction manual to imput the code properly car make and model renault clio authentique
It all depends on the radio make+ model.
Most RENAULT have the PHILIPS radio with a remote steering wheel control.
Here are the Code Entry Instructions
Philips Renault Code Entry (For cars with a Steering Wheel Remote Control.)
Note: If your car does not have this remote control, then please ask again for alternative instructions )
Turn on the radio and the display will show 'CODE'
Use the Steering Wheel Remote Controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
May 17, 2010 | Car Audio & Video
The controls on the steering wheel stopped working and the radio doesnt work either
Replace the clock spring under steering wheel, if applicable to your vehicle
May 06, 2010 | 1995 Buick Riviera
How do i get to the AUX function? i'd like to play my mp3 player thru it. Also, what is the hole/plug? in the back of the unit for?
you will need to turn unit off and press the function button for a few seconds this will take you to a settings menu here you can adj the clock, aux imput , sub and rear spk out put and dimmer and other options,the 3.5 jack at the rear is for the connectin of steering wheel controls .
Sep 03, 2009 | Pioneer DEH-P3800MP CD Player
Lc-42d62u 42in.
This is a common issue with HDMI. Try unplugging the TV for 2 monutes and also reset the cable box as well by inplugging.
Feb 10, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
