Question about Microsoft Ethernet MN-120 Network Adapter
Disconnected wireless When I first boot up my systems, I get a good connection with my wireless. After a short time I loose connection. After that, I can't get a connection. Even if I put the lap top within 5 ft of the base station. I've removed all security settings on the base station and laptop. I've changed channels and reinstall the software on both computers. Nothing helps. What now? I seen this post by someone else, but I need a solution for vista, not XP.
    Guru:
  • 377 Answers
Hi dear
try this
  1. Before you attempt to use any Wi-Fi network, find out what the SSID, Channel, Mode and WEP key are. Some Wi-Fi locations do not require a WEP key. Many Wi-Fi providers have this information on their web site or when you purchase access you will be provided the information.
  2. Ensure you have a firewall program installed and running. This will protect your data.
  3. Start up your laptop and once booted, look for the Wi-Fi network icon in the bottom right of the screen.
  4. Click on the Wifi Connection icon on bottom right of screen and you should see a window that indicates connection, strength and duration. Click on the Properties tab.
  6. The next window will show the type of networking card installed. Click on the Wireless Networks tab.
  8. Once the Wireless Network Connection Properties window is open you will have two options depending on how you set up your laptop.
    • If you do not see any networks listed in Preferred or Available networks, you will have to manually add the SSID. Click on Add. You will have to enter the SSID and WEP key (if required). Click OK and you should then see the network you just added in the Available networks box.
    • If you see the correct SSID showing in the Available Networks, then you need to click on Configure in order to enter the WEP key if that is required.
    • In the next window, enter the SSID for the Wi-Fi network you want to access. Make sure you do not have CAPS lock or NUM lock while entering the information. If a network key is required, click on "Data Encryption and then enter the Network key you have been provided with. Again make sure you do not have CAPS or NUM lock on. Click OK when entered. If you have entered the key incorrectly a message will pop up and you will nedisconnected wireless - fccfda9.jpgter the key.
    • Next go to Start - and where it says Connect To click on that and you should see choices like in the graphic below. Click on Wirelessdisconnected wireless - 34b0a7b.jpgonnection and it should work.
There are occasions when the connection doesn't work, in these cases check your firewall software and make sure it allows you to connect to the Wi-Fi network. To check this, disable your firewall software and check the connection again. If you can connect with the firewall program disabled, you change your settings. If your firewall program is not the problem check the SSID and WEP key information that you entered. Both of these are case sensitive. If you had obtained SSID information from the Internet, check with someone in the establishment to see if the SSID has been changed.
oke post in me back
i hope this usefull for you
thanks
cropp
Posted on Jun 28, 2008
2007 street glide won't start
Hi Anonymous, when checking for spark the CKP needs to measure the compression bump in order to send the correct signal to the ICM/ECM so always check for spark with either a third plug grounded or lift the end of the plug boot 1/2 " off one of spark plugs that are in the head. and the usual suspects are:
1. Fuel tank empty
2. Fuel supply valve turned off.
3. Fouled spark plugs.
4. Engine flooded with gasoline as a result of over use of enrichner.
5. Fuel valve or filter clogged.
6. Vacuum hose to automatic fuel supply valve disconnected, leaking, or pinched.
7. Discharged battery, loose or broken battery connections.
8. Loose wire connection at coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, spark plug cable connections loose,
or cables connected to wrong cylinders.
10. Ignition timing incorrect due to faulty ignition coil, ignition module, or sensors " Manifold Absolute Pressure" "Camshaft Position Sensor" "Crank Position Sensor" "Brake Apply Sensor
11. Engine lubricant to heavy ( winter operation )
12. Sticking or damaged valves or push rod wrong length.
13. Primary cam sproket spline sheared or missing spacer.
14. Security alarm system not disarming.
For a primary suspect please visit the website below: Good luck
Harley Diagnostic Codes 04 to Present
Sep 08, 2013 | Harley Davidson Motorcycles
1999ultra no spark replaced crank sensor still no spark
Hi Mike, when checking for spark the CKP needs to measure the compression bump in order to send the correct signal to the ICM/ECM so always check for spark with either a third plug grounded or lift the end of the plug boot 1/2 " off one of spark plugs that are in the head. and the usual suspects are:
1. Fuel tank empty
Good luck
Aug 15, 2013 | 2003 Harley Davidson FLHT Electra Glide...
1984 sportster will not start
1. Fuel tank empty
Good luck
Aug 14, 2013 | Harley Davidson XLS 1000 Motorcycles
Asus P8C WS error code 55
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
When a computer completely fails to boot or to provide any sort of power on self-test (POST) beep codes, the cause is either a hardware failure, lack of power or a bad connection.
To solve these problems, it helps to start with potential environmental causes first, such as a problem with the AC power being supplied to the computer.
From there, a good rule of thumb is to simply start disconnecting items from the computer one at a time until just the CPU, motherboard, RAM and power supply remain connected, and then swapping in known good replacements for them.
Test the AC power to make sure there is power to the outlet. Inspect the back of the power supply to ensure the power cord is fully seated, the power switch is on and the voltage setting is set to the right voltage, which is typically 110 volts.
Inspect the inside of the computer for any signs of burned components, such as capacitors or integrated circuits that are deformed or discolored, and replace the affected expansion card, motherboard, drive or other device if damage is located.
Verify a proper connection for each expansion card, cable, drive and stick of RAM by disconnecting and reconnecting each item without removing it from the system.
This can sometimes clean corroded or loose contacts and solve minor problems that prevent the system from booting.
Disconnect the drives and remove all of the expansion cards except for the video card, and try to boot with a bare system composed of only the power supply, motherboard, CPU and cooling fan, RAM, and video.
Attempt to start the computer again. If the system boots, reinstall the removed items one at a time until the system again fails to boot, and then replace the component that is causing the failure.
If the bare system fails to boot, swap in known good components for the motherboard, RAM, video card, power supply and CPU until the system boots.
Swap components into a working computer one at a time until that system fails to boot in order to locate problem components.
Hope this helps.
Nov 22, 2012 | ASUSTeK COMPUTER ASUS P8C WS - Motherboard...
06 street glide won't start when hot
1. Fuel tank empty
May 08, 2012 | 2006 Harley Davidson FLHX Street Glide
1988 1200 sportster starting problems
1. Fuel tank empty
Harley Davidson Sportster error codes and how to access them
Jan 03, 2012 | Harley Davidson XL 1200 C Sportster Custom...
2001 1450 fat boy wont fire. changed the coil but still no spark. fuses are good no codes
Hi Everett, when checking for spark the CKP needs to measure the compression bump in order to send the correct signal to the ICM/ECM so always check for spark with either a third plug grounded or lift the end of the plug boot 1/2 " off one of spark plugs that are in the head. and the usual suspects are:
1. Fuel tank empty
Good luck
Oct 13, 2011 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
My 2006 sportster won't fire and back running lights won't work back blinkers will sometimes not others. Seems to b a short
Hi Timsledge, when checking for spark the CKP needs to measure the compression bump in order to send the correct signal to the ICM/ECM so always check for spark with either a third plug grounded or lift the end of the plug boot 1/2 " off one of spark plugs that are in the head. and the usual suspects are:
1. Fuel tank empty
Harley Davidson Sportster error codes and how to access them Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Harley Davidson Wiring Diagrams and Schematics
Jun 04, 2011 | Harley Davidson XLH Sportster 883...
Will not start getting gas and spark and coil has tested good
Hi Snowaerty, when checking for spark the CKP needs to measure the compression bump in order to send the correct signal to the ICM/ECM so always check for spark with either a third plug grounded or lift the end of the plug boot 1/2 " off one of spark plugs that are in the head. and the usual suspects are:
1. Fuel tank empty
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Apr 20, 2011 | 2000 Harley Davidson FLTR-FLTRI Road Glide
Can't get wireless to connect
Depending on your OS, you could check the device mang. and if your 802.b wireless is not found, look for other flags or problems.
Turn off your wireless switch and remove and re-install your network system.
If after completed, you do not see the wireless install when loading, remove the wireless card and try again, removing from device mamg., re-booting and re-installing wireless card.
Sometimes the wireless card looses connection and needs to be physically removed, system re-booted and re-installed to work.
If that does not work, try exchanging the wireless card for another.
Removing the entire network from the system and re-booting is the best way. Shoot down after re-booting and re-install wireless card.
Restart unit, if it see's the wireless card, it will show loading network device. If it does not see the card, it will not load it.
Hope this helps
Jul 27, 2009 | ASUS Eee 4G Notebook
Microsoft Ethernet MN-120 Network Adapter Logo
198 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
