Question about Canon PowerShot SD870 IS Digital Camera
Bad pixels on LCD screen
Near the center of the LCD screen there are a few rows of pixels that aren't working. Problem suddenly appeared for no apparent reason.
  • 2 more comments
  • hittnerb Jul 04, 2008
    Several row of bad pixels lower center of the screen. Appears as a bright spot on display. Just happend at start of camera. Purchase 11/07.
  • Anonymous Aug 11, 2008
    center of screen bad pixels
  • Anonymous Sep 03, 2008
    HAve same problem with mine and it's only two months old. I called Canon and they suggest to send the unit to theri service deparftment in Elkgrove Village, Ill
  • guy_mk Sep 24, 2008
    problem with screen oof my canon SD870 IS:
    2 rows of pixels on the screen are not working...what can be done? I have no warranty. has anyone paid for a repair? what is th eprice and where has it been done?
I had a problem with my PowerShot A300 where the LCD screen looked as if the image was "melted" with a reddish tone. I checked many different websites and finally got to a link on the http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=257&modelid=13390&keycode=2112&id=29819 website and indicated to contact the company directly to send unit in to be repaired.
Problem: Internal wiring may become disconnected, especially if the affected products are stored or used in high-temperature and high-humidity environments
Posted on Sep 22, 2008
Per Canon support website, LCD problems require sending the camera in for repair.
Posted on Jul 04, 2008
Accordingto the Canon support site the camera will have to be returned for repair with this LCD problem.
Line top to bottom of screen 4 inches from left side; whole area distorted. appears after tv is on 15 minutes. does not go away. tv is 2-3 years old. was not dropped.
A TV does not to be dropped to get errors. The screen is build up with a a few million pixels. they are switched on and of in lines and rows.
Bundles of rows and bundles of lines have a combined "switcher" If one bundle gets a poor supply (bad contact or defective electronics) a band of pixels will act different or not at all.
I'm afraid it is a normal defect and you need a tech to solve the problem.
Before you order someone to repair, ask what it will cost, because in 3 years TV sets became much cheaper. Perhaps a new one is cheaper than a repair.
Mar 25, 2015 | Hannspree ST42DMSB 42 in. LCD TV
Milk white screen.
HELLO!!!
Try updating the display drivers ... Hope it turns goos after the update ...
Jan 03, 2008 | Dell E151FP 15" Flat Panel LCD Monitor
I have a red dot on a Coby TF-TV2001. What can I do to repair this?
If you mean you have a pixel that is stuck on and is always red, there's nothing you can do. The only cure is to replace the display. LCD displays sometimes will have a pixel (sometimes several pixels) that doesn't work properly. The manufacturers know this, and as long the display falls within their specifications for what's acceptable, they don't see anything wrong. These specs include the total number of bad pixels, the number of bad pixels that can be clustered together, and where they can be on the display. If you have just one or only a few bad spots, they won't do anything for you. If other problems develop, such as a whole row or column goes bad or a section of the display fails, then you can see about having them fix it if the warranty is still in effect.
Dec 28, 2010 | Coby 20" Flat Screen TFT LCD TV Monitor
Black line (strip of pixels not working) horizontal across screen
If a whole line of pixels is dark, you've got a bad transistor in what's called a "Passive Matrix" display. For your future purchasing decisions, while an "Active Matrix" display costs a little more, it has individual transistors for each pixel, rather than one per row and column, so when a transistor goes bad, it only turns one pixel black rather than a whole row or column.
Sep 12, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
Black spots appeared on 17" LCD Monitor-SyncMaster740N
you might have what you call "dead pixels" or a "stuck pixel" try a simple test like this one now it is not the most creative one, but it does help to see if that is the case. u might be able to Fix a STUCK pixel, but unfortunately you can not fix a "DEAD pixel" simply because it is DEAD.
try this website for simple fix instructions.
if is dead pixel what you have, if u can live with it, great, if not , it might be a good reason to get yourself an another monitor.
Good luck
Jun 17, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Vertical line of dead pixles on Olevia 237T LCD HDTV
Replace the screen. It is faulty and is covered by your extended warranty. Any problems, contact your Trading Standards Office.
Mar 20, 2017 | Olevia LT37HVS 37 in. LCD HDTV
(what appears to be) color pixels on computer screen
try a different video card , if you have one.
Mar 30, 2008 | Computers & Internet
Green Spots on the Screen
you have pixels going out my friend. No fix
Dec 01, 2007 | Sony KDF-E50A10 50 in. LCD HDTV
Two light lines have just appeared
Your driver transistors are failing on those "Rows" of Pixels.. a common problem .. you could try "Pixel Reviver" software from here http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor see if that helps.. but it possibly is on the way out sorry..
May 22, 2007 | Sony SDM-HS75/B 17" LCD Monitor
Canon PowerShot SD870 IS Digital Camera Logo
222 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
