Question about HP DeskJet F380 All-In-One Printer
Cd drive is not visible
Dvd drive showing in bios. but in my computer it is not showing.
    Problem Solver:
  • 9 Answers
If your running Vista, it might have been related to iTunes (if you use iTunes, it used to cause this problem). Take it to your local Best Buy and they should be able to run a quick fix for you. Depending on the store though, they might charge, or they might not. If they do, it will probably be $29.
Posted on Jun 24, 2008
Battery dead & BIOS reset. CD & DVD drives lost.
first you will need to replace the cmos on the system board(or have a qualified computer service tech. do it). then you will need to access the bios settings by Pressing F1 immediately after powering on the computer. once in the bios, you can set the correct date and time. Also, you will need to check the drive settings to verify that the hard drive and any CD/DVD drives are recognized. once done, then exit the BIOS being sure to chose "save and exit", then allow your PC to boot normally. this should fix your date and drive issues. if not then the motherboard may be defective.
Dec 29, 2013 | Computers & Internet
My Cd drive not see in my computer & Cd Icon is not show in my Computer pls help me out for this problem urgently
You might have disabled the CD/DVD ROM in your Device Manager or in your BIOS.
In Device Manager:
1) Right click My Computer and choose Manage.
2) A window will appear. Go to Device Manager.
3) On the right side of the window, find CD/DVD and right click on it and choose enable.
4) Check if your CD/DVD drive is present already.
If you cannot find it still, try the BIOS:
1) Restart your laptop and go to your BIOS set-up
2) Look for CD/DVD drive and enable it.
3) Restart your laptop.
Hope it helps.
Thanks!
Feb 03, 2011 | Computers & Internet
My cd reader in my hp pavilion dv6000 is not reading properly. when i put in a cd i see the little green light blinking and i hear the cd spinning but thats all it does.
sorry to tell you but your Cd drive is bad it is fairly cheap and easy to install usually two screws and give the drive a little yank and it should pop out you can purchase the CD drive online try ebay good luck but make sure first im not sure if maybe you think that something is supposed to happen every time you insert a cd it does not insert your CD go to my computer and try to access the drive if you can browse the files then your drive is ok sounds like you need to enable Autoplay a feture that enables something to happen when you insert your cd but you probaly know all that ...
Nov 03, 2009 | HP Pavilion dv6000z Notebook
Vostro 1510. CD/DVD-R doesn't show up in the BIOS or 'My Computer' Is this a bad drive or can it be fixed?
If it is a normal IDE type of CD/rom drive it may not show in your BIOS. It may just need to reinstall the driver once up in W**dows.
Oct 31, 2009 | Dell DVD-rom DVD Drive
DVD drive not working
check dvd drive if detected in bios
1. test any media dvd and cd, if fails
2. uninstall / reinstall firmware if fails
3. check if dvd drive icon is visible from my computer window, if not
4. donwload the fix here http://support.microsoft.com/kb/314060/en-us
5.replace dvd drive
Oct 08, 2009 | Dell Inspiron 1545 Notebook
No upper and lower filters visible in registry
boot your computer into the bios and check to see if the drive shows there , if it does then dissconected the drive ( with power off ) and reboot the computer , let it fully boot , then turn off and reconnect the drive and windows should pick it up
Oct 02, 2009 | NEC ND-3550A DVD±RW Dual Layer Burner
My dvd rom does not show up in" my computer". i cannot play any dvd or cd. my driver agent says that HL-DT-ST DVDRAM GSA-T40N ATA DEVICE is disconnected.
Best thing to try, take out the dvd drive completely from the laptop. Then go ahead and reseat the drive back into its slot and put the screw back into place. Do all of this while the laptop is turned off.
Now go ahead and turn the laptop back on and go into the bios. Once in there it should show you the dvd drive, if it does show it to you then reboot into windows and then the drive should show up into my computer and you should be able to play dvd and cd's again.
If your drive doesn't show up in the BIOS then reset defaults and then reboot the laptop back into windows. If it still doesn't show up in there then you have a bad dvd drive.
Jun 21, 2009 | MSI VR420 Notebook
Laptop not show cd or dvd when i put it
Well, for starters, is your cd/dvd turned on in the bios.  Some but not all computer have a setting for this.  If your cd/dvd drive is removable, shut down the computer, remove the drive.  Reboot the computer and shut it down again.  Then reconnect the drive and start the computer back up.  This will make sure that if your drive is working, windows will redetect it.  You can check device manager to make sure it is not disabled.  If none of this works, you may have a bad drive.  If you really must reinstall windows, you can get an external cd/dvd drive pretty cheap on Ebay.  Just make sure you go into your BIOS setting and change the boot menu to external drive.  I hope this information helps.
May 30, 2009 | HP Compaq Presario C700T
Cd/dvd drive installed and it was working but suddenly the drive is not shown in my computer/control panel and not working if cd is inserted.How to find the drive/ make show the drive in my...
Try to find it in BIOS. Press F2 or F10 or Del when power your pc on. These keys depends on your bios brand. After entering try to find cdrom drives menu maybe it is disabled. Or there are disabled IDE or sata controller
Mar 19, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
My windows XP home edition wont find my CD drive
I'm not sure if you've already done these things or not, but this is what I would do:
Reboot and enter the BIOS setup. There should be an indication on the screen of how to enter the BIOS setup during the startup. It's typically something like the Delete Key or Function Key.
Check to see if the BIOS recognizes the CD-RW drive. If it does then your problem is most likely in Windows. If the drive is not visible in the BIOS then a number of things are possible. Is the drive set to Master, Slave, or Cable Select? Is it on the right setting? Have you tried both of the IDE connectors?
If you need more help with this just let me know. I also want you to know that I'm not getting paid, I just like helping when I can. If you've found this information helpful I hope you'll give a positive rating. If what I've offered has not been helpful please let me know so I can try to help more. Thanks and good luck.
Jan 01, 2008 | Computers & Internet
HP DeskJet F380 All-In-One Printer Logo
20 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
