Question about Gateway FPD2275W LCD Monitor
IC POWER CM2017 LCD MONITOR
The problem of this monitor is, when you turn on it shows a very clear picture then it turns black after like about 3 seconds but the power led indicator stays on. When you switch off and switch on again it does the same, shows clear picture then turns black after few seconds.
  • Anonymous Jul 15, 2008
    my moniter goes on when started up then goes blank after load icons on windows. then can turn moniter power off then on will come onm for a few seconds then go blank..
  • 52 Answers
Normally when this type of problem happens, the first suspect would be the inverter board, then the filter capacitors and lastly the mainboard.
A defect in one of the lamps and faulty inverter IC may cause the display to shutdown as well. If the lamp is defective, it will send a feedback and cause it to stop producing output signal thus the display just shut off once you switch in ON.
Posted on Jun 26, 2008
Vaio LCD problem
Periods.......Nice little items because they denote the End of a sentence.
See how this works?
"I have a vgn cs36gj, I was working with it, suddenly the LCD became pale black, I connected it to external monitor and it has a picture, sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
Now you try it.........
"I have a vgn cs36gj. I was working with it, suddenly the LCD became pale black.
I connected it to external monitor and it has a picture."
Okay, I got that part.........
"sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
WHICH LCD?
Laptop LCD?
External monitor LCD?
Man on the moon LCD?
1) If the external monitor LCD goes 'pale black', the problem is the graphics chipset.
This I do not believe
2) If the laptop LCD goes pale black, this I believe.
Post back in a Comment.
Regards,
joecoolvette
Apr 25, 2013 | Computers & Internet
Syncmaster 226CW showing picture only for a second + flickering
Call and get the RMA for your monitor, the problem is in the power supply and it will only get worse. This is a common problem with LCD monitors after 2-3 years of use.
Buddy
Corporate Computer
www.ccl-la.com
Oct 17, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Liquid Video monitor goes black after 30 seconds
Capacitors on the power board inside the lcd monitor have blown they can be replaced with new ones and the monitor should return to normal operation.
service center or if you feel capable you can do it your self with a soldering iron and the correct caps that have blown you need voltage and micro faradays usually 25 v at 470 mfd (u)however monitors use different kinds and voltages can be different it will be marked on the side of the damaged capacitors.
l8r
Nov 11, 2008 | Computers & Internet
X2gen 19" monitor
open the monitor there is a vertical ic which has small alluminium heat sink ckeck 12v supply to ic if present then remove ic & check 12v at same point if present then replace ic if absent then check 12v regulator ic if faulty replace it
Jul 20, 2008 | X2Gen MG19MY 19" LCD Monitor
Monitor only stays on for 3 seconds
There is probably a bad capacitor within the monitor that will not allow the picture to "hold" in the on configuration. This will need to be replaced. You can send it back to Phillips, or 17" monitors are pretty cheap these days. I would suggest a Samsung or BenQ. They both carry 3yr warranties.
Aug 17, 2007 | Philips 170S4FB 17" LCD Monitor
Power cord not working
If your power cord plugs in to the back of the monitor, then you can find one just about anywhere that computer stuff is sold, like Radio Shack and Wal-Mart. You might be able to be able to get one free from a locally owned computer repair place as they most likely have extras lying around. Doesn't hurt to call and tell them you need one. If you have to buy one, they aren't expensive, usually 5 or $10. Please let me know how it turns out!
Dec 29, 2006 | Balance CM2017 17" Monitor
Picture shows up for about 3 seconds then the screen goes black
XEROX 19" (XG92D) 5 MONTHS OLD...IT GOES TO WHITE WHEN WINDOWS TELLS IT TO TRUN OFF AFTER 2 HRS...IT GETS HARDER TO COME ON EACH TIME IT IS TURNED OFF. I TOLD WINDOWS TO NEVER TURN IT OFF. IF THE POWER GOES OFF I MUST TURNED IT OFF AND ON MANY TIMES, THEN IT COMES ON. I THINK IT MAY NOT COME ON NEXT TIME...
Sep 26, 2006 | Xerox XG-91D 19" LCD Monitor
Balance Monitor
Same exact thing has happened to me. We have determined that the monitor itself is good, but the DC adaptor is what went bad. Now I am on the hunt for the power adapter.
Sep 20, 2006 | Balance CM2017 17" Monitor
Gateway FPD2275W LCD Monitor Logo
593 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
