Question about Accutek AOJ-1601 Stand (Pedestal) Fan
Only works at high speed
I recently moved the fan from one room to another. Since I plugged it back in, the only speed that works is high, not low or medium.
Any idea what might be going on?
  • carioca66 Jul 18, 2008
    My 16" Accutek runs day and night, because I live in Florida. Yesterday morning it stopped working in low, but still worked in medium and high. By afternoon it only worked in high, and by last night didn't work at any speed. Do the motors wear out? It never felt hot to the touch, and I see no physical signs of damage or wear.
  • 75 Answers
The barector resistance would have worn out or would have broken in the rheostat so change that resistance then you would see ur fan working in low medium and high speeds
Posted on Jul 30, 2008
Reset a Honeywell HZ-709 portable electric oil room heater?
I'm going to ask the first "obvious" question: are you sure the socket you're plugging into is delivering power? (Sorry to ask but it's an Occam's Razor kind of situation) Have you tried a different socket in the same room? Next, does the main power switch for the heater have different settings i.e. high, medium, low, high-high, high-low, low-low and have you tried those combinations? Next, pick up the heater (if it won't hurt your back) and give it a robust shake. Try the power again. Any luck? Keep us posted.
Mar 06, 2015 | Honeywell HZ-709 Oil Filled Radiator...
Fan only wobbles on high....recently 'bumped'
Check all your screws especially the set screw at top of fan that goes into rod. Blades could be warped from the water. Ball of fan not set in bracket correctly. When your buying a fan, look for blade pitch.13 degree or better is best. You shouldn't have to use the fan on high unless it's a low-end fan with a low blade pitch. It's costing you more money to run the fan on high. Sorry to get so preachy, I'm a fan dealer .
Jun 19, 2013 | Dryers
1992 chevy C1500: Heat works on low speed, no medium, and high only works intermittantly.
On any other vehicle it sounds like the blower fan switch.
The fan switch provides power or ground to the resistor and there would be a high speed blower relay to bypass the resistor.
But in your case the fan switch is part of the controller.
I don't have a diagram for a 92 but the 94 model shows relays for low medium and high speeds. Each relay gets power from a fuseable link. The high relay gets power thru the low relay if the low relay is not engaged.
If you have the model with 3 relays you may need to check them.
Feb 01, 2013 | 1992 Chevrolet C1500
Have two codes 1490 and 1489 what are they and how do i fix them
It's most likely low speed fan control relay circuit trouble.
There are separate relays and control circuits for high and low speed for the fans. This way if one messes up the other one should still work. Relays are in relay/fuse block under the hood. There is a diagram under the relay box cover that shows the function of each relay. The relays just plug in.
1489 = High Speed Fan CTRL Relay Circuit - An open or shorted condition detected in the control
circuit of the high speed radiator fan control relay.
1490 = Low Speed Fan CTRL Relay Circuit - An open or shorted condition detected in control circuit of
the low speed radiator fan control relay.
Either the relays are gone or the connector isn't plugged in, probably the connector if both the low and high circuit is out.
May 06, 2011 | 1998 Dodge Intrepid
In the heating mode, blower will not com on in auto but will come on in on mode at tstat
The furnace uses two different speeds. High for a/c (which is the "on" position of the fan switch) and low speed for heat. You could either have low speed of the blower not working or something wrong in the circuit board (if it has one). On the blower motor you may have several plugs that you could change the fan speed and your heat may start working. You will have to access the blower motor to find this out. Red color is low and black is high. Move the Red wire to another speed on the motor and see what happens.
Apr 14, 2011 | Heating & Cooling
Kenmore over the stove microwave,model # 721.62629200,only low speed fan works on the keypad,no high speed fan.
The fan has a setting for high speed, low, and off. Fan only running at low speed.This indicates problem towards. 1) the fan motor. 2) The loose fan wiring. 3) The fan switch. IN the unit there is a motor for fan.If the motor gets weak or short. The fan will run but only at low speed.Because at high speed the motor will require more power to run.In this case motor needs to be checked and replaced. The other possibility is the fan wiring.There are two wires going from fan to motor and two going from motor to power board.If any of this wire is got loose or getting short then this will stop the fan to run in high speed.In this case the wires needs to be checked and reconnected properly. In the unit there is a switch internally.When you select the fan to high speed mode the switch goes up. when you select the fan to low speed mode the switch turns down.But if the switch is faulty or got worn out.Then it will not move properly up/down.In this case switch needs to be replaced.IN some brand models the High speed and low speed are directly controlled from front control panel.There is no switch in that models.In that case the control panel needs to be checked and replaced. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jun 10, 2010 | Kitchen Ranges
What do the different fan speeds indicate
The different fan speeds are different airflows across the coil and blows out into the room..
For instance speed
#1 is usually high speed
#2 is medium high
#3 medium low and
#4 low speed
Aug 17, 2009 | Heating & Cooling
Hunter fan with remote control was 3 speed, now only 2 speed
It sounds like fan motor is okay. There are two motor windings -- one low speed, one medium speed. Low winding gives you low speed, medium winding gives you medium speed, both windings give you high speed -- so I would say if you get high speed, both windings are good.
The remote (the hand held transmitter) controls the speed by raising and lowering the frequency of the current which is 60 cycle coming to the fan ceiling box. If the fan speed -selector switch (usually a pull switch) is set to high, when the remote (transmitter) signals the receiver to change speeds, the frequency of the current is changed by the receiver (the receiver is usually in the fan housing).
Sounds like you'll need to replace the remote system -- these come in sets, both transmitter and receiver, and cost about $30. If you're not experienced with wiring fans, you should get an electrician to do the job.
Apr 21, 2009 | Hampton Bay 24002 Ceiling Fan
High cool not working
Compressors on these units runs at only one speed. The change to high cool is only a change in blower speed moving air faster over the cooling coil. I would have the running capacitor for the fan motor checked. A bad capacitor can cause your type of problem. The other problem could be that the high speed winding in the fan motor is bad. Try it operation in the fan only position through the two speeds. If it works in the low and high speed for fan only your problem could be in the selector switch.
Jun 23, 2008 | Dometic Rooftop RV Air Conditioner
High speed only 60rpm
I too just installed a 68" Altura and noticed a huge difference in fan speed. I spoke to a rep for the manufactorer and found out that the high, medium, and low rpms are 70, 45, and 25. The typical 52" fan has rpm speeds of 190, 130, and 75. The kicker is airflow. The 68" moves 7,808, 4,417, and 2,953 cfms on high, medium, and low; the 52" fans move 5,503, 4,087, and 2,509 cfms.
Jun 10, 2008 | Hampton Bay 24002 Ceiling Fan
Accutek AOJ-1601 Stand (Pedestal) Fan Logo
402 people viewed this question
Top Accutek Dryers Experts
ray gallant
 Russ Hill
Russ Hill
Are you an Accutek Dryer Expert? Answer questions, earn points and help others
