Rinnai Convector 516TR Heater
Our two year old heater's not working on low temps, only works when crank up to 22 C plus. It's switching itself off and flashing 12 or I2. I've cleaned the filter at the back but it hasn't fixed the problem. Can't find my manual, can anyone help?
  • 1 more comment
  • westinvest Aug 09, 2008
    Keeps switching off, flashing 12, also cleaned the filter. Don't know what to do
  • tpl_l Aug 15, 2008
    We also have been having the same problems , it has been about 2-3 years.
    Tried cleaning the filter as well (both at the back ), moving all obstructions to the vents in the front. Still keeps doing it. Cant find the instructions. what does the "12" stand for???
  • munch642 Aug 25, 2008
    Thanks for your efforts. It was actually a filter problem. I didn't realise there were two and it needed cleaning, so it's working perfectly....
Hi, Here is the link to the manual. I think something like 'thermo coupling' probably means you need a technician!
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/installations/153.pdf
Posted on Aug 25, 2008
  • hello799r Aug 25, 2008
    How to check the thermocouple on a different but similar model:
    http://www.paulsupply.com/files/rinnai42...
Hi there im not sure whats wrong with my fireplace> when when i plg it in it keeps flashing on and off.
Posted on Apr 08, 2011
Flashing 12, is actually the gas pressure. I undid the heater from the wall, re-connected it and have had no problems. A gasfitter told me what to do
Posted on Aug 26, 2008
Instructions say "12" means incomplete combustion, check thermocoupling. anyone know what that means???
Posted on Aug 15, 2008
Converting rinnai 516tr from natural gas to lp
Try national energy they sell convestion kits It would need a gas fitter to do the work , you may need to a quote on this , they would be able to tell you if it is worth it ,its hard to tell with out looking at the heater .
Feb 24, 2012 | Rinnai Heating & Cooling
Rinnia 516tr gas heater cant change temp showing h10 or h11 or time
Check the secondary gas pressure change when the set temperature is changed
Aug 14, 2008 | Rinnai Heating & Cooling
I have Rinnai natural gas room heater 516tr. It's continuously showing filter light on indication. I have clean heater but still filter light kept on. What I should do?
Turn the heater OFF and unplug it from the wall. Remove the filter and reinstall it, making sure it's fitted properly into the heater. Wait 5 minutes and plug the heater back ion and turn it ON. You may have to reset the controls back to way you had them. Completing what you just did, should have allowed the heater reset itself and function as it should. If this sort of thing continues to reoccur, contact your local Rinnai Dealer for service.
Hope this helped you to solve the problem.
May 01, 2011 | Heating & Cooling
OUr Rinnai gas heater convector 516tr keeps on turning itself off and flashes 12 on the light panel. What does that mean and how to fix it? tks
Hi.
12 flashes means "Incomplete combustion". The code is prompted when the flame turns off because of a problem.
Check filter, check gas pressure and thermocoupling. Those are the problem that commonly trigger the code 12 error.
Here a manual.
Here Fixya thread on the problem.
Sep 06, 2010 | Heating & Cooling
Hi i have a rinni convector 516tr heater i put it on it switches off a few seconds later i think it has to do with the timers i have lost the book/
I am assuming this is a tankless heater. Are you turning the water on full throttle and is there full flow. First thing to check is the small filter screen on the inlet of the water heater. If the flow is reduced the water heat will not fire.
Sep 05, 2010 | Rinnai Heating & Cooling
How old is my Rinnai Convector 516 TR?
2000 is the year of manufacture
Nov 09, 2009 | Heating & Cooling
RINNAI CONVECTOR 417 Natural gas heater 17.5 MJ Wanting to know if this is a decent model. Anything that may cause you to avoid buying this model? And about how old would this model be?
The 417 service manual is dated 2003, so they're no more than 7 years old.  You can download the operation & service manuals here:
www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/installations/161.pdf
www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/161.pdf
May 06, 2009 | Heating & Cooling
Mt Rinnai convector 516tr will not start, have stored it away for summer got it out for this winter plugged all in after pressing start after about 20 seconds No 11 starts flashing
I have had this problem due to the heater 's combustion sensor concluding that all was not well. In my case, the heater had burned up too much of the available oxygen. I didn't notice the lack myself, so it must be very sensitive. I had shut the place up to keep the heat in and eventually it dawned on me to open a door for a minute or so every half hour or so to replenish the oxygen supply.
The situation is worst when the place is very cold as the heater will roar away trying to heat it up as quickly as possible. After I came back for a holiday in winter, I had to set the temperature down to "L" and "Economy" on plus run an electric fan heater for a day to warm the structure to the point where the gas heater could relax and not burn oxygen faster than it could heat the space.
Apr 30, 2009 | Heating & Cooling
Rinnai convector 516TR
Hi This is happening to us and I called Rinnai... they suggested that if anyone either in our apartment or an ajoining one has painted walls or varnished a floor that the convection heater picks up the smell and the only way to get rid of it is to burn it off by running the heater for several hours in a well ventalated room...
I am going to try it tomorrow.
will let you know
Jul 13, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
1,734 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
