'paper jam' error on canon pixma ip4300
My printer will not print as it keeps showing a 'paper jammed in outlet slot' message. i have checked this area and these is no paper jammed. when i turn the printer off and then back on it feeds a piece of paper through without any problems but then brings the paper jam message up again. can any one help I've only used this once for 2 8x10 photo's, came thru beautiful. Now can't feed anything thru, top or bottom. Tried roller cleaning, paper won't go thru. Pulled back off, no jam.
  • RLBTank Jan 21, 2009
    Pixma iP4300 is showing 3-blinks and indicating PAPER JAM. There is no jam. But I cannot print. I also cannot address the paper tray, only the sheet-feed.
    Is there a solution?
  • bexiebas Mar 08, 2009
    Have same problem, tried manually pushing through a sheet of heavy A4 card all the way through backwards and forwards - there is no physical jam - but the printer still thinks there is.
Ring canon support on 0844 369 0100
or try
support.canon-europe.com
they suggested i do a roller cleaning - but i cant find this option ?
Posted on Aug 20, 2008
Cannon Ip4300 - Orange light flashes on printer.
A possible paper jam has happen on the unit. Did you have an paper jam error before you have this problem?
You must clear any paper jam on the unit, check the unit for any stuck paper or object or check if there was misaligned parts inside.
Let me know for any clarifications.
Thank you for using fixya.
micro-
Dec 12, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Canon Pixma MP160 shows errors E3 and won't print
Error E3 : Check if the paper has jammed in the machine, reload the paper in the machine correctly and then press [Black] or [Color].
Paper Jams :
Cause : Paper jams in the paper output slot/ Auto Sheet Feeder.
Landscape Credit Card sized paper jams inside the machine.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn the machine OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will eject automatically.
2) Reload the paper into the machine and press [Black] or [Color].
* If you have turned OFF the machine in step , you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Important : You cannot load Credit Card sized paper in the landscape orientation.
Hope this helps.
Have a good day.
Dec 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My ip4300 printer shows - Service Error A600-
goes through this link and try.........
http://tricks-collections.com/solution-canon-pixma-ip4300-error-6a00/
Oct 07, 2009 | Canon Office Equipment & Supplies
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Canon ip4300 Error code 1300
u have to reset ur printer try to hold ur finger on power button for more than 15 sec then turn it on again
Jun 09, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
There's a small white light below the power light that's flashin.
In this case you may have to clear the memory of the printer or set the printer to default.
May 07, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
"Paper Output Slot Jammed" Canon Pixma iP4300
These printers are FULL of very sensitive sensors, and chances are that one of them may have a small piece of paper blocking them. If you can get the covers off by finding the "Triangle" arrow markers, you can inspect all these sensors.
Good luck!!!
Mar 12, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Service error 6A00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 01, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Will not function on front feed
check all paper paths for little pieces of paper
Apr 23, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
Aug 22, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
835 people viewed this question
jasbo
jasbo
