U-Line Icemaker
Problem for U-Line Icemaker
WH95TP-03, won't make ice
By mkletti on Jun 24, 2008
My unit won't make ice, it freezes fine, I can turn the wheel manually, but won't go on it's own
Same Problem
Nov 04, 2009
-   i need to rder the water supply line kit for my u line 95 tp icemakes..where do i go-   dennismillle
May 05, 2009
-   unit works fine...water is getting to the unit but...no ice. What am I to do? -   Guest
Jul 25, 2008
-   I am not getting water up to the Ice Maker, The arm works and I can hear it make contact. I changed out the water solenoid. It freezes fine when I pour water in.-   myersvette
Solution #1
posted on Jun 24, 2008
Somewhat Helpful)
jottin
Rank: Master
Rating: 76%, 24 votes
The machine in let water filter is block clean the filter and check the water flow
Was this helpful?
Yes
No
Solution #2
posted on Jul 10, 2008
Not Rated)
gojsasplit
Rank: Apprentice
Rating: 0%, 0 votes
heater is work continuosly, and fridge work good but water evaporator only is hot and produce only hhot water nothing more . ice maker on the and full of water but ice not coming.
best regards
Was this helpful?
Yes
No
Popular Solutions for U-Line Icemaker
Questions and Unsolved Problems for U-Line Icemaker
Do you recommend U-Line Icemaker?
Answer
Answer
U-Line ice maker fails to get cold.
Answer
only occasionally makes ice, arm is down so it should be making ice
Answer
the ice maker is running and the water is alson runing, however it doesn't get cold enough to make... (More)
Answer
I need a new thermostat. model 45-48 part # A22450670
Answer
black nipple that dispenses water to ice maker is frozen. How to unfreeze it. Water dispenser works... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For U-Line Icemaker:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
