Question about Gateway SL1450-30165297 Notebook
Dim screen my gateway laptop display screen stays dark. if I look really hard at it, I can see the cursor moving around. when I power down and restart, the screen may pop up for a second, then dim out to black again.
  • carnivore Jun 24, 2008
    it should still be under warranty. if I misplaced my best buy psp and receipt, will they dig it out using my credit card number?
    Problem Solver:
  • 9 Answers
If its very dark and you can barely see anything its probably a bad back-light. I'd suggest to take it to your local Best Buy. And yes, they can look up PSP#'s with your credit card, but even easier by telephone number.
Posted on Jun 24, 2008
I was wondering how to fix it because I have some important stuff on it. When I try turn it on it just gos to a white screen and gets really dim then black
Change the LCD screen, it can be solved there is no image on the screen, but the power light stays on Dark display but still readable computer problems, this should help you:http://www.lcdinverters.net/
Oct 08, 2012 | Computers & Internet
Power stays on but screen goes black on my Gateway laptop.
If the laptop appears to boot up and the hard disk LED flashes then you have a backlight problem.
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Nov 22, 2009 | Gateway 450ROG Notebook
The LCD screen on my Gateway M-6317 is dim. How
Press and hold the 'FN' key and tap the key that has the picture of a sun and an up arrow (or some other similar picture that dictates brightness - there should be two different keys that affect brightness one to increase and the other to decrease). Once you have the brightness set to your liking quit tapping the 'brightness' key and release the 'fn' key
Sep 29, 2009 | Gateway MX6447 Notebook
When I turn on my computer, the screen stays black
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Sep 09, 2009 | Gateway MX6956 Notebook
I have a Gateway M-6843 Notebook PC that won't power up.
Check out
www.lcdparts.net
Sep 06, 2009 | Gateway 7405GX Notebook
The screen on my Compaq Evo N610c is dim
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 11, 2009 | Compaq Presario Notebook
Gateway laptop- screen went dark but is still on.
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 31, 2009 | Gateway 450ROG Notebook
Adjusting screen brightness
If you hear the hard drive spinning and you think Windows is working but you can't see an image or a very dim image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
May 20, 2009 | Acer Aspire 5630 Notebook
Gateway 3522GZ display
Some searching on forums convinced me the inverter had failed. Picked one up for $65, removed the frame around the screen, removed the mounting screw for the inverter, and unplugged both ends of the old and plugged in the new. Put it back togeher and fired it up, bright again. Key here was that a remote monitor still worked which meant video card was OK. The lamp could have been bad, but apparently the life of lamps is pretty decent.
Aug 31, 2008 | Gateway 3522GZ Notebook
LCD goes dim within 1-2 minutes
You could have a bad "inverter" or flourescent backlight tube, or a problem in your power supply.The only way to isolate the problem is to check each component in sequence.If your hard disk and DVD / CD drive are still working when your screen goes dark, then I'd say it's the "inverter". You'll have to take it to a repair shop.
flipbooks
Jan 20, 2008 | HP Pavilion dv6000z Notebook
Gateway SL1450-30165297 Notebook Logo
233 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
