Question about Canon XL2 Mini DV Digital Camcorder
My audio from the mic is cutting in and out when i play tape back
The audio is cutting in and out whenever I play tape backwhat settings should i have the camera set to and what may be problem if that is not it
  • 1 more comment
  • phil1313 Jun 24, 2008
    where do find windblock setings?
    Ii has been pixelating and I have had issues with it not cleaning appropriately....has this been an issue you have seen in the past (dirty audio heads creating havok with the audio?) I did a fire safety video wit wireless mics a few days ago and they seemed to work better but not flawless the audio cut out less ....but when using the attached mic (I suppose it is the canon xlr mic it really cuts in and out...so I guess the answer has been yes I have had issues with dirty heads and the people that used the head cleaner last actually recorded on it rather than just cleaning it by pressing play. so what I am thinking correct me me if you know a better way is clean the heads with a brand new tape? Is there an alternative? A better way to get it cleaned? Thanks for your time!
    Thanks Bubba ...I will let you know this evening what happens with it ...I plan on goin' to "B Buy" and pickin up the long wooden Q tips ...and a tape cleaner...if that desn't work is there a cheaper alternative to buying a seperate recorder for sound...how can I do this also any methods for cleaning? which is audio one? Is it the one that looks like in a regular tape deck? and is the round silver cylinder the video play head?
    I really apreciate the help
    Also what buttons or switches should be turned on for just the front mic (the correct settings ...this is just a cautionary thing)
  • Canon Master
  • 2,794 Answers
There could be a short in the mic wire. Does that camera have wind block settings for the mic? If so either turn them on or turn them off. See if that works.
Posted on Jun 24, 2008
  • 2 more comments
  • Tim Babcock
    Tim Babcock Jun 24, 2008
    I was just looking at the owners manual here. I thought they had wind block circuit on the boom mic like the some Canon cameras have. I have questions here:
    Are you using the boom mic to record off of or are you using an XLR mic?
    Another thing you can try to do is run a DV tape cleaner in the tape heads and see if that cleans the audio heads.
  • Tim Babcock
    You try taking some qtips and some alcohol and running them across the tape heads as well as the rubber take up rollers. See if that make a difference.
  • Tim Babcock
    You can you use for any tape deck whether its video or audio. Make sure the power when you use it.
    Good luck.
  • Tim Babcock
    Tim Babcock Jun 25, 2008
    Theres a lot of buttons on that camera. I didn't see anything that turned it off. I think the front mic gets turned off if you plug in an XLR mic in the back jack.
The input levels of the left and right microphones are highly inequal, what can I do?
perhaps the left speaker is damaged
what i would do is load a known mp3 too the sdcard
and play it back on your unit
if its aok level wise
then the left mic has an issue
try an external input too the left mic
if it again records bad there is an issue with the input amp and alc circuit
if it records ok chances are the left electret mic has failed and will need replaced out usually these small mics have an amp built in then this output goes at line level to the input switched between line level in mic in or internal mic in as a mix....
Jan 10, 2015 | Yamaha POCKETRAK C24 POCKET RECORDER
There is a horrible echo whenever i try to record and then there's a loud noice that sounds like a very high-pitched whistle and i don't know what to do.
This type of audio feedback loop can happen on any mic if you are playing back audio at a loud volume on speakers that are close to the mic while the mic is on - which tends to happen on Skype calls. Try lowering your speaker volume or using headphones to hear the audio, then speak into mic, and the feedback should be reduced.
Apr 12, 2012 | Labtec Microphone Microphone
Set up audio mixer with PC
You must connect:
the main out of the 1202fx, or the ctrl room out of the 1202fx at your power amplifier's input (if there is one)
the line in 11/12 of the 1202fx at your pc's audio card line out. (for playing back)
the cd/tape out of the 1202fx at your pc's audio card line out. (for recording)
in case of a cd, connect it's line out at line in 5/6 (or 7/8, or 9/10) of 1202fx's
some mic at the mic 1 (or 2 or 3 or 4) of 1202fx.
That's the way you're going to have control for:
the mic level from channel 1 (etc).
cd level from channel 5/6 (etc).
pc playback from channel 11/12.
master speakers from main mix or ctrl room.
All the above connections are not absolute and may vary depending on your needs.
About freeware softwares for audio recording and editing I can suggest you:
Audacity (homepage)
Wavepad sound editor (homepage)
In case of a problem or clarification about the connection or the cables, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Oct 19, 2009 | Behringer F-CONTROL AUDIO FCA202 External...
No Sound When Recording
Video camera has built in microphone which is on at all time until you plug in different type of mic then camera is switched to new mic. Audio problem may be on audio head or circuit problem. You can test the system by playing pre-recorded tape to see if it play with the sound and go from there. If it play but does not record sound, you have audio recording problem. If it does not play, I would clean the video head and audio head area good. -James For further assistance, request help at www.camerarepairjapan.com
Apr 11, 2009 | Panasonic Video Cameras
A problem with my mic settings
Check CONTROL PANEL, Sound or Audio Devices. Usually, a check box to show Volume Control on System Tray or Notifcation Area. If you can launch VOLUME control from either Startmenu/Programs/Accessories or START..RUN..SNDVOL32, look for a menu item to select RECORDING DEVICES to hopefully find the MIC.
Within your program, there may also be options/settings to use the mic.
To restore defaults, try a System Restore (System tool from start menu, accessories) or as a last resort, uninstall/remove the sound or audio device from your Device Manager (risky if you don't have the driver readily available from CD or Download). After uninstall, reboot to allow Plug and Play to put the hardware back in---usually this can get your defaults restored.
Mar 18, 2009 | Microsoft Computers & Internet
Audio level Issues with Sennheiser Wireless MIcs
Could be your capture device.  Isolate this problem by monitoring the quality of the audio at the RF reciever, then monitor it at the camera.  I'm assuming you do not have a EFP mixer or other device that will actually measure your Dbm or Vu levels - what happens if you play the tape in the camera and monitor the output of the camera with an external device - even a TV or stereo? If it sounds good on your TV turn your attention to the capture card.
Jul 05, 2008 | Panasonic AG-DVX100B DV Digital Camcorder
Tape loop
You may need to purchase a cheap external mixer with both mic and line inputs, and use that to mix the mic with the DVD audio. In most receivers, you can only select one input at a time. The output of the mixer can then be plugged into any spare receiver input, such as AUX, CD, DVD, etc. When not using Karaoke, you can simply turn the mic input down to prevent it from interfering with the DVD signal, but will still need to have the mixer on to hear DVD's.
Jun 26, 2008 | Onkyo TX-DS797 Receiver
Mic port not working
1. Check the Audio I/O settings in Realtek Audio Manager in system Tray Icon on Taskbar,
2. Try to connect your Mic to Front pannel of system Unit.
or Reinstall audio Drivers.
Feb 22, 2008 | Intel D101GGC Motherboard
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Auidio drops
while your monitoring the sound when recording it cuts out or while you playback the tape it dropps out? if it's noticed during playback it's one 3 things. the heads are dirty, the tape tension is low or the heads are bad. send it to video tech service in sacramento. that guy is super cool.
Jun 20, 2007 | Sony Handycam DCR-TRV900 Mini DV Digital...
Canon XL2 Mini DV Digital Camcorder Logo
114 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
