Question about Sony Cyber-shot DSC-S600 Digital Camera
Lens only open partially
Nothing broke, I didn't spill anything on it or get anything in/on it. I tried to turn it on one day and noticed everything looked blurry. I then noticed the lens was only open about half way. No funky noises or anything. New batteries. What is going on and how can I fix it??? I need my camera!
  • flaca3 Jun 28, 2008
  • rpatton Jul 18, 2008
    Went to use the camera one day and the lens would only open partially, when I turned it on and off, it stayed in the same position. Have charged the battery, didn't drop it or spill anything on it. When it is turned on, it says ACCESS on the screen and then says to turn the camera off and then on again. Then the same thing happens, same message and lens is in same position.
    President:
  • 4,402 Answers
Lens mechanism isn't good to work properly so camera shut down the power. Try to tap the lens/ camera while power up.
If you have a memory card in the camera, take it out before turning the camera on
Posted on Sep 03, 2008
I dropped my camera on the lens while it was open, now it will not close. I noticed it was slightly blurry when i tryed to take a new pic. I turned it off and then back on and the lens didn't move
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Jan 23, 2012 | Olympus Software VG-120 Digital Camera
My nikkon coolpix is a month new and almost only 3 weeks used..my uncle bought it in states...when i am taking pictures i zoom it and a message "LENS ERROR " appear on the screen and because i...
1.Check if something block it (maybe sand or smt like that
2. Never pushed lens manualy (you may broke it completly)
3.Just try to shake or slap it jently while open or close it.
Jun 07, 2011 | Nikon Coolpix S3000 Digital Camera
I have a coolpix and I spilled orange juice on it. I imediatly cleaned and dried it off but when I would try to turn it on...nothing. It's been a few months I tried to turn it on and it says battery...
First off, are you sure that the battery is charged? It is definitely possible that spilling orange juice on it messed it up, but it might be all right.
Assuming the battery is charged, it is likely that the spill caused some internal damage. When you spilled on it, did you open the battery door, take the battery out, and allow the the camera to air-dry completely before turning it on? If you didn't, it is almost surely fried. If you didn't allow it to air-dry, it is likely that there was residual moisture and liquid on the internal components, and when you powered it on you likely messed them up. This is really a repair that is not worth paying for, as the cost of a new camera would be much cheaper.
May 07, 2011 | Nikon COOLPIX L4 Digital Camera
The lens opens then closes then partially opens
Maybe some of the lens gear is broken . change the gear or lens will be ok .
Aug 31, 2009 | Casio EXILIM ZOOM EX-Z70 Digital Camera
Lens Error on L18
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 23, 2009 | Nikon COOLPIX L18 Digital Camera
Camera won't turn on
Fixed! Several people I've described the problem to asked me if I dropped the camera, and I honestly did not remember dropping it, but I could've just forgot that it happened. Later, (after this was posted) it slipped out of my hand and fell to the carpeted floor. When I picked it up, I noticed that the lens shutter had moved (to be closer together). I turned it on, and after a few automatic adjustments, the camera was working like normal again! Perhaps the same thing that broke it, fixed it!
Jan 17, 2009 | Olympus Cameras
Oil Leak spilling oil on driver's side floor inside car
if it was an oil like substance it sounds like it might be freon from your a/c a line might have finally broke in the HVAC witch is in the dash and that sound like the problem hope this helps
Jan 17, 2009 | 1990 Toyota Corolla
Doesn't power up. Lens cover doesn't open, lens doesn't open
Well, I'm not sure if I can solve it but I did have a similar problem with my out of warranty TZ3. One day it just died - wouldn't power up, no display, nothing. I tried changing batteries, re-inserting them, recharging, checking contacts but to no avail. Nothing. I did some research online and found that there were a few others out there with the same problem and the fix was basically to throw it away and buy a new camera. The cost of having digital compacts professionally repaired these days is such that you may as well spend a little bit extra to get the latast model.
That being the case I figured I may as well dismantle it and see if there was anything obvious that I could do. It's not that difficult and if you are reasonably careful and comforable with components and printed circuit boards you won't have any problems. It turned out the problem with mine was one of the ribbon cables that connnects to the PCB that runs along the top of the camera - the connector is just below the on/off switch. It had come partially detached from the connector. I re-made the connection, re-assembled the camera and it all worked perfectly. And the good news was there were no components or screws left over - amazing.
More good news - I saved myself a few hundred dolllars. The bad news, I don't get to buy that TZ5 that I had almost justified purchasing. Good luck. If you need help dismantling the camera the service manual at http://tsn.pasc.panasonic.com/viewing/ALL/DMC-TZ3P/SVC/DSC0703019CE_PRINTB/DSC0703019CE.pdf
should help.
Good luck
Dec 28, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Nikon Coolpix L12 It has a constnat lens error screen
mine has that too....urgh i need to take pics cuz im going on vacation too....joy
Dec 31, 2007 | Nikon COOLPIX S9 Digital Camera
Canon eos 300d (digital)
your manual is the first place to look for an error code. then the canon site.
guessing it is a defective on board battery (the smaller of the two) or your main battery is depleted.
try removing and reinstalling the main battery first. then check the on board battery.
you may have a lens partially mounted, or some contamination on either the battery terminals or lens terminals, or a door partially open.
also, you should take out the mem card and check it in a card reader.
none of this will likely be needed if you can find the error code data. it might be that the code is specific enough to indicate the root cause of the problem.
good luck
mark
Dec 24, 2007 | Canon Digital Rebel / EOS-300D Digital...
Sony Cyber-shot DSC-S600 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
