Question about Microwave Ovens
Panasonic inverter my microwave shows H98 and will not function what should i do
  • 1 more comment
  • Anonymous Apr 19, 2009
    Same problem shuts off after 30 secs. Contacted Panasonic and waiting for response.
  • Anonymous Mar 26, 2014
    unable to close the door tight, it shows problem P10
    unable to close door tight, it shows problem P10
  • Microwave Ovens Master
  • 9,086 Answers
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 01, 2008
Trouble code H98
H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
R
Oct 03, 2014 | Panasonic NN-H765BF 1250 Watt Microwave...
Code H98
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
You can order Panasonic parts & accessories from Encompass here or you can call them toll-free at 866-779-5835.
Nov 30, 2013 | Panasonic Genius Prestige Inverter...
Our microwaze is shutting off after ~25sec saying H98
Your microwave generation system has failed and Panasonic recommends that you get it serviced by a qualified tech. Hope it is under warranty!
Sep 14, 2012 | Panasonic Genius Prestige Nnsd997s...
When I go to use the microwave h98 shows up on the screen and does not work it is the 1.6 cubic panosonic microwave with inverter technology
f it is displaying error h98, this generally means that the inverter(power supply Panasonic part number: Z606YM300BP,) is not functioning. The magnetron may also be faulty.
The microwave may also have a faulty magnetron. If you are unsure, then you should get someone to look at the unit for you before you go buying parts.
An inverter microwave oven is one without a high voltage transformer You will know you have one as it is not extremely heavy at one end. This type of microwave uses a high power DC converter, called an inverter, to produce the high voltage and filament voltage required by the magnetron.
If you purchase this item for replacement in your microwave then we recommend that you do this only if you are qualified and aware of the dangers of tampering with electrical equipment.
Failure of the magnetron is common and at times the inverter can fail as well. Sometimes the inverter fails on it's own. If your microwave blows the 10 amp mains input fuse as the cooking cycle starts then you probably need a new inverter. An instruction sheet with basic guidelines on fitting will be provided but please do not purchase this item unless you are confident about fitting it. We only accept returns if the inverter supplied is defective which is extremely unlikely.
If you have one of these ovens that is not cooking then it is worthwhile looking at the magnetron. It often shows signs of distress through overheating.
Dec 27, 2010 | Panasonic NN-SN657SMicrowave Oven
Microwave will not work...display reads H98
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
Dec 14, 2009 | Panasonic Microwave Ovens
Panasonic Microwave show H98 in window
Jul 03, 2009 | Panasonic Microwave Ovens
H98 error
Dec 31, 2008 | Panasonic NN-H965 Microwave Oven
My panasonic inverter microwave gets a fault code H98 and stopes working.
Nov 26, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
232 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
