Back to:
Tags:
Compaq Armada E500 PC Notebook
Security
posted by gembetty on Jun 24, 2008
I am trying to use an old armada laptop given to me. I need to install new software but am unable to because i don't have the old admin password. is there a way around this the formrer owner does not remember it.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 01, 2008
Helpful (85)
julian98
Rank:Apprentice Apprentice
Rating: 85%, 1 votes
Remove the CMOS battery for 3 minutes - then reboot using power adapter without main battery in place. No password required !
For Armada E500
To remove CMOS battery - remove main battery and any mains power adapter -turn computer so rear faces you with lid closed - undo top screw (T8 Torx driver) to hinge on right. remove screw - open lid - GENTLY prise up plastic switch cover. CMOS battery is just in front of screen about 3 inches from left.
Rating Locked! (?) gembetty has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on security:
I don't want to Accept this solution
Solution #2
posted on Jun 24, 2008
Helpful (85)
sushantxx
Rank:Wiz Wiz
Rating: 82%, 18 votes
go to tech support
Thank You!
Solution #3
Thanks for Trying (70)
altec1105
Rank:Wiz Wiz
Rating: 81%, 25 votes
go to tech support and get something called a recovery disk it will cost you some money though and there could be other ways to
Rating Locked! (?) gembetty has rated this solution as Thanks for Trying
Thank You!
Can you Help with these PC Laptops problems?
PC Laptops
My laptop has Windows Vista Ultimate x64 as its operating...
I have a Compaq Armada E500. 2 Batteries that both report...
PC Laptops
I don't really have any problem with the laptop now... I...
keyboard does not allow full range of characters to be...
hi there i have a laptop with a connnecting lead but it...
Loading problems.
Repair Service
Find PC Laptop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
