Question about Gateway 7330GZ Notebook
My gateway laptop won't come on
Laptop been off for a week. battery meter shows full charge, power adapter is working, no physical damage etc...
    Novelist:
  • 119 Answers
For a no power issue there are three major component that can cause it: defective memory, defective motherboard, defective processor.
components that could affect the computer in booting: external devices: remove all
hard drive and optical drive: remove it too
if there are any pci card or any card installed in computer remove it. after removing all component and only the motherboard is left alone you should be getting some behavious which will indicate your computer is still alive: you will get to hear a beeping sound, a display error message that no memory is detected. if it doesnt turn on then the motherboard is dead
Posted on Jun 24, 2008
No Power
Your laptop's power jack may be broken, which is why your laptop doesn't charge your battery at all, which is why it won't turn on now. I would take a look to make sure that the power supply is good, the battery is good, and then see if the power LED is even coming on when you plug the laptop to a power source.
Apr 10, 2013 | Gateway Computers & Internet
Battery won't hold charge
It most likely needs a new battery, but you could try giving the battery a full charge first:
1. Power off the laptop and disconnect the power adapter.
2. Re-seat the battery (remove/reinsert)
3. Reconnect the power adapter and let it charge overnight. (6 hr+)
4. Disconnect the power adapter.
5. Power on the laptop (run under battery power only)
If it doesn't boot up and shuts down immediately, it's probably time to see about a replacement battery.
2.
Jan 11, 2013 | Samsung Q430 Laptop
Gateway 7322 Notebook. Can't get the battery only
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 09, 2012 | Computers & Internet
Lap top Battery problem
POWER SUPPLY & BATTERY PROBLEM
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Aug 02, 2012 | MSI Computers & Internet
Gateway m460 battery will not charge
May 24, 2012 | Dell Latitude C640 Notebook
Gateway MT6840 won't power up
before checking ur mother board check for ur operating system.
Mar 08, 2012 | Gateway MT6840 Notebook
A320s battery has full charge , tested with volt meter. computer shows 6% battery
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
May 08, 2011 | Getac A320S PC Notebook
Battery is not charging.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced. Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Apr 14, 2011 | Gateway MX6453 Notebook
Hello sir i have gateway model md2614u .when i charge my battry and when it aharged full screen seen black but it shows power by red ight and it give no response.
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Oct 29, 2009 | Gateway MD2614u Notebook
Dell Latitude D600 won't power on w/ or w/out power adapter
the problem is really mysterious. because in most of cases the battery is the villain. and when it is replaced the issue should be over. there are no other components of a laptop which is directly or indirectly related with battery perfomance.
any way get back me with more details like the age of system and number of times taken to service center etc etc @ deepuunni1985@gmail.com
Aug 22, 2009 | Dell Latitude D600 Notebook
Gateway 7330GZ Notebook Logo
304 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
