posted by JanKatie on Jun 24, 2008
I cannot get my new scanner to work in HP Solution Center (software) in either XP or Vista.
Comment by JanKatie, posted on Jun 24, 2008
We were disconnected. What happened?
Comment by JanKatie, posted on Jun 25, 2008
I tried what you suggested (unplugging, uninstalling, etc) but I still get the same error message. I even updated the driver. Any other suggestions. This may be helpful. It works on my laptop with XP. It doesn't work on my pc which has XP on one drive and Vista on the main drive. I tried it on both drives on my pc. It doesn't work.
Comment by JanKatie, posted on Jun 28, 2008
We were disconnected from the live chat and the problem was never resolved. I never heard back from Maanita.
Best Solution
Hi Jankatie
You need to unplug the scanner cable from both the ends and then reconnect it back make sure the power is disconnected,
then reconnect the power too
Uninstall the existing software from add remove programs in control panel
reinstall the whole software with the cd you got with the scanner'
once the installation is over it should work fine
Its the driver software corruption which is creating the problem.
for further assistance please post here
Regards
Regards
Rating Locked! (?) JanKatie has rated this solution as Thanks for Trying
This Problem Also Relates To:
HP 4570C Flatbed Scanner
HP LaserJet Companion Path-Through Scanner
HP Scanjet 3400c Flatbed Scanner
HP Scanjet 4200c Flatbed Scanner
HP Scanjet 5400c Flatbed Scanner
Memorex MEM48U Flatbed Scanner
Panasonic KV-2025C
Can you Help with these Scanners problems?
Microtek ScanMaker i320 Flatbed Scanner
new pc dell inspiron windows...
need drivers for a microtek... Answer This...
Canon CanoScan LiDE 70 Flatbed Scanner
won't work with its software...
I'm not sure just when it... Answer This...
Symbol MC1000 Batch Barcode Scanner Single...
installation
installation
I don't know how to install it... Answer This...
Canon CanoScan LiDE 500F Flatbed Scanner
i need a user guide for canon...
preferably pdf file Answer This...
Canon CanoScan 8000F Flatbed Scanner
canon 8000F scanner
canon 8000F scanner
after being offline for some... Answer This...
Repair Service
Find Scanner Repairman Near You:
