Question about Dishwashers
Danby ddw497w will only be about 5 min into cycle when digital code E2 appears it then starts beeping 2 min after this it just stops the unit is only one day old it ran once yesterday fine now i get this code no matter what cycle it is on
  • AmberA Oct 18, 2008
    I am having the exact same problem. I have had my dishwasher for a few weeks. It has run fine until the last two runs. The last one the E2 code started flashing towards the end of the cycle. Today it start mid-way through. It also seemed to leak some water this time.
I just spoke with the Customer Service rep from Danby... She said tht an E2 error has to do with the hoses. Usually it means that the hose is too high to drain properly, there is a kink in the hose or the pump is faulty.
Hope this helps!
Posted on Feb 24, 2009
I have the same problem - I just called Danby - the answer is either the hose is kinked or the hose is too high for the runoff. If that is not it, it may be the pump. If you call and ask them, they will fax to you their entire list of codes.
Posted on Oct 28, 2008
My danby countertop dishwasher ddw497w turns on, drains the water in the tub, refills and right before it usually fires up. click and nothing. just sits there with no fault code. any ideas before i sm
Hey Derrick,
According to the manual:
http://www.danby.com/cms/documents/pdfs/en/DDW497W_EFSOM.pdf
The most likely cause is the appliance not being leveled properly. Apart from that, I have found no useful information.
If you have a smart phone, try using one of the various, 'Surface Level' apps which will allow you to set your phone on the top of the appliance and then adjust the level until the bubble is centered in the crosshairs.
Hope this helps.
Oct 03, 2014 | Danby DDW497W 22 in. Countertop Dishwasher
Starts to wash and it stops and i have E 2.
he e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
To fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen) (and neither with mine)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Apr 11, 2011 | Bosch WFMC 3200 Front Load Washer
I have a Danby DDW1899WP portable dishwasher. I just got it yesterday. I had a lot of dirty dishes so I did 1 cycle first and it worked perfectly, I was impressed. I then started a 2nd cycle for the rest...
I realize the above question is almost 4 years old, but I am sure others are still having this problem. My Danby was behaving the same way: drying cycle light would flash like it was having a myocardial infarction, and the cycle would stop. I could only get the light to stop flashing by turning the unit off. What you didn\'t say above is what happens then: everything most likely returns to normal-- or at least, so it seems. I have now had this happen to me two times in a row with my Danby 1899WP. Each time the machine has started up just fine, drains water out, loads in fresh water, and begins the wash cycle, only to freeze up with that damn flashing red light on the dry cycle and the dishes not clean. I have owned it for about two months, and so far this is my only complaint. I am running it again right now, for the third time, and we shall see what that light does now.... Will report back afterward!
Nov 14, 2010 | Danby DDW1899WP Portable Dishwasher
What does an E3 code mean?
hello,
what this mean is an indication of a problem detected b the sensor
Some models of washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
thanks
Oct 23, 2010 | Danby DDW497W 22 in. Countertop Dishwasher
What does error code E2 mean? I have a Bosch Maxx Classic.
The e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
to fix you must do a master reset of the washing machine.
5. Select any program and the message should not be appearing.
Nov 03, 2009 | Bosch Washing Machines
Cuts in and out
I suspect a bad compressor run capacitor. Take the unit to a service facility & have the capacitor & overload protector replaced. The overload will be weakened by the repeated cycling.
Jul 14, 2007 | Danby DPAC8020 Air Conditioner
Dishwashers Logo
413 people viewed this question
Top Dishwashers Experts
