Question about Samsung Computers & Internet
Unable to print using samsung print on Windows XP
Troubleshooting Steps Followed:
Printer was properly installed, when tried to print a test page : Windows explorer used to shutdown...
(http://www.samsung.com/us/support/guides/howToGuideSearchList.do?group=&type=&subtype=&model_nm=CLP-300N&dType=D&mType=UM&vType=R&prd_ia_cd=06010200&acc_ia_
fl=&disp_nm=CLP-300N)
Reinstalled printer from control pannel : Same error
Tried to print a test page using the Samsung s/w : success;
Tried to print from note pad : Failed...
Restarted the print spooler and tried to print : nogo;
Bypassed print spooler and tried to print : nogo;
Uninstalled Kodak easy share s.w and tried to print : nogo;
Uninstalled amyuni printer driver : nogo
Added a new printer using the samsung cpl 300 driver and tried to print : nogo;
Tried doing windows updates : nogo;
Did a clean boot and tried to print a test page : nogo
Post this the customer has been offered a call back after researching on the issue.
Any assistance would be highly appreciated.
    Novelist:
  • 119 Answers
To resolve this issue, follow these steps: 1. If you do not have a Lexmark printer installed, go to step 4. If you do have a Lexmark printer installed, go to step 2.
2. If the Lexmark print service is installed on your computer, turn off the LexBce Server service. To do this, follow these steps: a. Click Start, right-click My Computer, and then click Manage.
b. Expand Services and Applications, and then click Services.
c. In the details pane, right-click LexBce Server, and then click Properties.
d. On the General tab, in the Startup type list, click Disabled.
e. Under Service status, click Stop, and then click OK.
f. Right-click the Print Spooler service, and then click Start (if it is stopped).
g. Exit Computer Management.
3. Test whether the issue is resolved. If the issue is resolved, you do not have to follow the remaining steps. If the issue is not resolved, go to step 4, and then follow the remaining steps.
4. Start the computer in safe mode. To do this, follow these steps:a. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured to start multiple operating systems, you can press the F8 key when the Boot menu appears.
b. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
c. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Note For more information about how to start your computer in safe mode, click Start, click Help and Support, type safe mode in the Search box, press the ENTER key, and then click the Start Windows in safe mode topic.
5. Start Microsoft Windows Explorer, and then delete all the files and the folders in the following two folders (where C: is the drive where you have Windows XP installed): • C:\Windows\System32\Spool\Printers
• C:\Windows\System32\Spool\Drivers\w32x86
6. Start Registry Editor. To do this, click Start, click Run, type regedit in the Open box, and then click OK.
7. Locate and expand the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86
View the list of subkeys. There should only be the following subkeys: • Drivers
• Print Processors
8. If there are any subkeys other than the subkeys that are listed in step 7, follow these steps: a. On the File menu, click Export.
b. In the File Name box, type the name that you want to use for this key, such as WindowsNTx86regkey, and then click Save.
You can use this backup of the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86 registry key to restore the key if you experience any issues after you complete this procedure.
c. Delete all the subkeys other than the subkeys that are listed in step 6. To do this, right-click each subkey that is not on the list, and then click Delete. Click Yes when you are prompted to confirm the deletion.
9. Locate and then expand the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers
The registry entries for the printer drivers that are installed on the computer are stored in the Version-x subkey or subkeys, where x is a number (typically 2 or 3).
10. Export the Version-x subkey or subkeys. To do this, follow these steps:a. On the File menu, click Export.
b. In the File Name box, type the name that you want to use for this key, such as print driver, and then click Save.
11. Expand the Version-x subkey or subkeys, and then delete the printer driver entries. To do this, right-click each printer driver subkey, and then click Delete. Click Yes when you are prompted to confirm the deletion.
12. Locate and then expand the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Monitors
View the list of subkeys. There should only be the following subkeys for the default print monitors: • BJ Language Monitor
• Local Port
• PJL Language Monitor
• Standard TCP/IP Port
• USB Monitor
13. If there are any subkeys other than the subkeys that are listed in step 12, follow these steps: a. On the File menu, click Export.
b. In the File Name box, type the name that you want to use for this key, such as MonitorsRegkey, and then click Save.
You can use this backup of the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Monitors registry key to restore the key if you experience any issues after you complete this procedure.
c. Delete all the subkeys other than the subkeys that are listed in step 10. To do this, right-click each subkey that is not on the list, and then click Delete. Click Yes when you are prompted to confirm the deletion.
14. If you have a printer attached, disconnect the printer cable from the computer, and then restart the computer.
15. Verify that the Print Spooler service is running. To do this, follow these steps: a. Click Start, right-click My Computer, and then click Manage.
c. In the details pane, right-click the Print Spooler service, and then click Start (if it is stopped).
d. Exit Computer Management.
Note If you cannot start the Print Spooler service, follow the steps in the following Microsoft Knowledge Base article to start the Print Spooler service:
919750 (http://support.microsoft.com/kb/919750/) You experience problems printing, viewing printer icons, and adding printers, the Print Spooler service does not function correctly, and you receive print-related error messages on a Windows XP-based computer
16. If you have a printer attached, reconnect the printer cable to the computer, add the printer that you want, and then try to print a test page. To add your printer, follow these steps: a. Click Start, and then click Printers and Faxes.
b. Click Add a printer.
The Add Printer Wizard starts.
c. Follow the instructions in the Add Printer Wizard to install the printer that you want
Posted on Jun 24, 2008
Color ink problem
Solution one: Check the ink levels To allow for full use of the cartridges, some printers continue to print even after the cartridges are completely out of ink. Follow these steps to check the ink levels in the Toolbox . The Toolbox is part of the standard printer software. Depending on the version of Toolbox on your computer, the appearance of the Toolbox features might vary.
NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, consider having a replacement cartridge available to avoid possible printing delays. Print quality deteriorates as cartridges run out of ink.
  1. Click Start (c01827528.gif ), click All Programs , click the HP folder, and then click the icon for your HP printer (c02053172.gif ). The printer software opens.
  2. In the printer software, double-click Estimated Ink Levels . The Toolbox opens.
  3. Click the Estimated Ink Levels tab to display the estimated ink level of each cartridge. Figure 1: Estimated ink level indicator c02752297.gif Image: Estimated ink level indicator.
  4. If the ink level indicators show that a cartridge is low or empty, replace the cartridge.
  5. Try printing again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Reset the printer Resetting the printer might clear the issues and allow the printer to function correctly again.
  1. Press the Power button (c01602202.gif ) to turn off the printer.
    NOTE: Pressing the Power button might not turn off the printer. This might happen if the printer is in an error state. Continue with these steps regardless.
  2. Disconnect the power cord from the rear of the printer. Figure 2: Disconnect the power cord from the rear of the printer c01869581.gif Image: Disconnect the power cord from the rear of the printer.
  3. Disconnect the USB cable from the rear of the printer. Figure 3: Disconnect the USB cable from the rear of the printer c01850063.gif Image: Disconnect the USB cable from the rear of the printer.
  4. Wait 30 seconds.
  5. Reconnect the USB cable to the printer. Figure 4: Reconnect the USB cable to the printer c01868577.gif Image: Reconnect the USB cable to the printer.
  6. Reconnect the power cord to the printer. Figure 5: Reconnect the power cord to the printer c01869582.gif Image: Reconnect the power cord to the printer.
  7. Press the Power button (c01602202.gif ) to turn on the printer.
  8. Try printing again.
Solution three: Restart the computer Restarting your computer might resolve the issue.
  1. Save the latest changes to your files, and then close all your open programs.
  2. Click Start , and then click Shut Down . A dialog box opens.
  3. Select Restart . Most computers turn off, and then turn on again automatically.
    NOTE: If a dialog box opens with a message that it is now ok to turn off the computer, press the power button on the computer to turn it off. Then press the power button again to turn it on. After a few minutes, the computer is ready to print again.
  4. Reopen the file that you want to print, and then try printing again.
Solution four: Check for blank pages in the print preview If the printer prints all pages correctly, but it adds blank pages to the printout, check for blank pages in the print preview.
  1. In most programs, click File , and then click Print Preview . If the program you are using does not have this option, consult the program manufacturer.
  2. Review the print preview for blank pages.
  • If the print preview reveals blank pages, delete the blank pages in the document, and then try printing again.
  • If the preview contains no blank pages, continue with the next solution.
Solution five: Check the USB cable If the printer connects with a USB cable, a faulty connection might cause the issue. Follow these instructions to check the USB cable.
  1. Make sure that the USB cable inserts all the way into its port on the rear of the printer. Use some pressure to push it in all the way. Figure 6: Insert a USB cable into the rear of the printer c01868577.gif Image: Insert a USB cable into the rear of the printer.
  2. Make sure that the USB cable inserts all the way into its port on the computer. Use some pressure to push it in all the way.
  3. If the issue persists, try replacing the USB cable with a known good cable.
Solution six: Check the printer settings on the computer Issues with the printer settings on the computer might cause the printer to print blank pages. Follow these steps to check the printer settings on the computer. Step one: Check the default paper settings Make sure that the default paper size matches the width and length of the paper loaded in the tray. If the paper loaded in the tray is different from the paper size setting, the printer might print blank pages. For instance, the issue might occur if legal size paper (215 x 355 mm (8.5 x 14 in)) is in the tray, and the paper size setting is letter (215 x 279 mm (8.5 x 11 in)). Follow these steps to check the default paper settings.
  1. Click Start (c01827528.gif ).
  2. Click Printers and Faxes . The Printers and Faxes folder opens.
  3. Right-click the icon for your printer (c01532298.gif ), and then click Printing Preferences . The Printing Preferences window opens.
  4. Click the Paper/Quality tab, and then compare the settings in the Paper Size drop-down menu with the paper in the tray. If the size of the paper in the tray is not the same as the setting in the Paper Size drop-down menu, change the setting:
    1. Click the Paper Size drop-down list, and then select the size of the paper that is in the tray.
    2. Click Apply to save the settings, and then click OK to close the Printing Preferences window.
Step two: Print a test page Follow these steps in the order presented to print a test page. A test page might help determine if the printer installation caused the problem.
  3. Right-click the printer icon (c01532298.gif ), and then click Properties . The Properties window opens.
  4. In the General tab, click Print Test Page . The printer prints the Windows XP Printer Test Page. Figure 7: Example of Windows XP Printer Test Page c01532301.gif Image: Example of Windows XP Printer Test Page.
  • If the Windows XP Printer Test Page prints successfully, you do not need to continue troubleshooting.
  • If the page is blank, continue to the next solution.
Solution seven: Print from an alternate program Follow these steps to try printing from an alternate program, such as Microsoft Notepad or WordPad, to determine if the current program is causing the issue.
  1. Browse to the location of your saved document, right-click the file, and then click Open With . A window opens with a list of programs.
  2. Select a program other than the program you are currently using to print the document.
  3. Open the file in the program, and then check the contents.
    NOTE: Most files open in plain text applications, such as Notepad or WordPad, even if the contents include unusual symbols or text that does not make sense.
  4. Try to print the file:
    1. Click File , and then click Print . The Print window opens.
    2. Select your HP printer from the Select Printer drop-down menu, and then click OK .
    If successful, the printer prints exactly what displays in the program window.
    • If the document prints successfully in the alternate program, you do not need to continue troubleshooting. The issue is likely specific to the program you are trying to print from. Consult the program manufacturer for assistance.
    • If the document still prints blank pages in the alternate program, continue to the next solution.
    • here are a couple things you can try hope this helps you
Apr 19, 2013 | HP Deskjet 2050 All-in-One Printer
Tip
General Printer Troubleshooting
Printer does not have power indicator<br />First, make sure that the printer is on. When a printer is on it should have some light (usually green) indicating it's receiving power and is on.<br />If you do not have any indicator light make sure the printer is connected to a working power outlet by verifying each end of the power cable. Next, press the printer power button.<br />If after following the above steps your printer still cannot get a power status indicator it's likely you're encountering a serious printer issue and we suggest contacting the printer manufacturer for additional steps and instructions on repair or replacement.<br /><br />Cables not connected properly<br />Your printer should have two cables connected to it. The power cable and the data cable, the power cable should have already been verified as being connected if your printer has a power indicator light as mentioned above. Make sure the data cable (parallel cable or USB cable) is also connected from the printer to the computer.<br /><br />Printer error (orange or blinking light)<br />After your printer has completed its initial startup you should have a solid green light. If the light indicator is blinking or orange often this is an indication of a printer error. For example, this could indicate a paper jam, issue with the ink or toner cartridge, or other serious error.<br />Because there is no standard to what a blinking light or orange light means if you're getting either of these we suggest referring to the printer documentation for troubleshooting steps or methods of determining what the status indicator is reporting.<br /><br />No paper or paper jam<br />Without paper your printer will not be able to print. Make sure you have paper in the paper loaded into the printer paper cartridge or tray. Next, verify that no printer paper is jammed or partially fed into the printer. If you have one or more pieces of paper stuck in the printer these will need to be manually removed before the printer will print again.<br /><br />Inkjet printer ink related issues<br />Often when you're encountering an ink related issue you're printer status indicator light (mentioned above) should be flashing. If this is not occurring you may want to skip to the next section. However, if you've recently inserted a new ink cartridge you may want to try the below suggestions.<br /><br /> * Replacing ink cartridges and printer not working.<br /><br />Printer self tests<br />Most printers have a way of printing a test page. This page allows you to determine if the printer is physically working or not. This test is usually accomplished by holding down a series of keys. If you are not sure if your printer has this feature or how to perform it refer to your manual or visit your printer manufacturers web site.<br />In addition to testing the printer using the printer self-test Microsoft Windows users can also perform a software self-test to determine if their computer is able to see the printer and it's able to print. Follow the below steps to perform this test.<br />Microsoft Windows 98, 2000, ME, XP, 2003, and Vista users<br /><br /> 1. Click Start, Settings, and open Control Panel.<br /> 2. Double-click the Printers or Printers and Fax icon.<br /> 3. Right-click on the Printer you wish to test and click Properties. If you do not see your printer listed your printer is not installed.<br /> 4. In the Printers Properties window click the Print Test Page button.<br /> 5. If the printer is able to print a test page, you're printer is installed and setup properly. However, if you're unable to print in other programs it's possible that the program you're attempting to print from has issues.<br /><br />Older versions of Windows with older printers<br />If you are running an older printer and MS-DOS, Windows 3.x, Windows 95, Windows 98, or Windows NT, you can also attempt the below software test.<br /><br />Get to a MS-DOS prompt or Windows command line<br />Get to the root directory - Type: cd\<br />Reroute dir to printer - Type: dir &gt; lpt1<br /><br />The above should take the directory listing and print to the printer. If this does not print, refer to your operating system troubleshooting section. Extra Note: This will not paper feed, therefore press your FF or PP, or manually eject the paper.<br /><br />Printer drivers<br />If your printer does not have any flashing lights and is connected properly it's possible you may be encountering a driver related issue. We suggest visiting our printer driver listing, which links to all major printer manufacturer driver pages and downloading the latest printer drivers for your printer.<br /><br />Parallel (LPT) printers<br />If the printer you're connecting to the computer is an LPT (parallel port) printer we also suggest verifying the below suggestions if your printer is not working.<br />Parallel port in CMOS<br /> 1. Enter the computers CMOS setup.<br /> 2. Once in CMOS verify that your parallel port is enabled or installed.<br /> 3. Next, verify the printer or parallel port mode. This option will often have several different modes. If your parallel port is set to ECP mode, we suggest trying a different mode.<br /><br />Other parallel device<br />If you have a parallel printer with other parallel devices such as a parallel scanner or zip drive, temporarily disconnect these devices to verify they are not causing your issue.
on May 09, 2011 | Office Equipment & Supplies
Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Hi!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit epsonexperts.com site for more info.
Dec 24, 2011 | Epson TM-U220 Matrix Printer
HP laser jet 1100 will not print
Error indicating that:1.Paper jam.2.Cartridge missing or not seated properly.3.Cartridge access properly closed?action: Refix cartridge properly, check any paper jams in side. No result.. ***remove Formatter & power supply & clean as shown in snap shots.. 11_29_2011_4_30_29_pm.jpg11_29_2011_4_31_09_pm.jpg11_29_2011_4_31_33_pm.jpg11_29_2011_4_31_56_pm.jpgCarefully observe the snap shots..and do the trouble shoot.Best of luck.
Nov 28, 2011 | HP LaserJet 1100 Printer
After installing Hp photosmart C5280 driver on windows xp, i am only able to print blank pages
Before doing any troubleshooting on the printer, check the ink levels then print a test page using the front panel of the printer. If the print out is good try this website for additional troubleshooting.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01892627&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3204464#N46
tnx... =) Please rate this one. tnx...
Apr 09, 2011 | HP Photosmart C5280 Printer
Cant connect (or see) my LaserJet 5000 on Windows XP
In XP go to START > CONTROL PANEL > NETWORK CONNECTIONS > LOCAL AREA CONNECTION
you should see a menu showing your network card and a window that says stuff like Client for Microsoft Windows. Below that window is an INSTALL button. Click on that and double click PROTOCOL. Select IPX/SPX NetBios and hit OK. You'll probably need the WindowsXP CD to finish installing the protocol.
The LJ5000 is a very old printer and if I remember correctly, it uses the IPX/SPX Netbios language to communicate through a network. Netbios is not installed by default in XP.
May 08, 2009 | HP LaserJet 5000 Printer
Cant instal the printer to mi computer
Setting up or installing a printer in Microsoft Windows. Issue:Setting up or installing a printer in Microsoft Windows.
Solution:There are two different methods a user can install a printer in Microsoft Windows. Below is additional information about each of these methods listed in the order we believe a user should try installing their printer in Microsoft Windows.
Before being able to install your printer you must have the software that was included with the printer. If you've lost the software for your printer you can download the drivers for your printer and use the drivers to install your printer. A listing of printer manufacturers and links to their associated drivers pages can be found on our printer drivers page.
Setup a printer using printer software
Every printer should come with the software used to install a printer in Windows. Although not all installations are the same the steps for installing this software should be similar to the below steps.
  1. Connect the printer to the computer and a power outlet and make sure it's on.
  2. Insert the CD that was included with the printer. If the CD does not automatically start the install program open My Computer, double-click on the CD drive, and then the Setup or Install file.
  3. Follow the installation wizard and your printer and its associated software should be installed successfully.
Installing a printer only using the drivers
In addition to the above steps a users can install a printer in Windows only using the printer drivers. This is recommended if you only want the printer to be installed but not the additional printer software programs that are often included with the installation and/or you've download drivers.
A listing of printer drivers and software downloads can be found through our printer drivers page.
Note: if you've installed the printer doing the above steps these steps should not be necessary unless you encountered errors.
  2. Click Start, Settings, and Control Panel.
  3. In the control panel double-click the Printers or Printers and Fax icon.
  4. In the Printers window click the Add a printer icon.
  5. After completing the above steps the Windows Printer Wizard will appear. Click Next, to start the wizard.
  6. Windows will prompt you if you're installing a Local or Network printer. If the printer is connected to your computer choose Local printer attached to this computer and click Next.
  7. When prompted for the location of the drivers for the printer. Browse the computer to the directory of your drivers or point it to the CD that was included with your printer.
Testing the printer
After the printer has been installed in Windows you can use Windows to print a self-test page to make sure the printer is working by following the below steps.
  3. Right-click on the Printer you wish to test and click Properties. If you do not see your printer listed your printer is not installed. Seedocument CH000939 for additional information about installing a printer in Windows.
Mar 23, 2009 | Office Equipment & Supplies
Problems with HP deskjet f380. Will not print... scans and copies
the system for vista and xp is near to similar. so just click the following links 1 by 1 and go through the instructions as you r missing any minor step to be followed in loading your printer How to load a printer on a pc step by step instructions
http://freepctech.com/pc/xp/xp00168.shtml
http://kb.iu.edu/data/aksl.html
Installing a printer on a Windows 95/98 network
INSTALL THE PRINTER on a PC
ENABLE PRINTER SHARING
MARK the NEW PRINTER as a "Sharable" Printer
INSTALL THE PRINTER ON THE OTHER PCs
Troubleshooting Windows 95/98 networking problems
http://www.mcgill.ca/ncs/products/soho/networking/printer/
How to install a printer driver locally for a remote printer in Windows XP/ Windows 2000-
http://support.microsoft.com/kb/282842
Jan 06, 2009 | HP DeskJet F380 All-In-One Printer
Unable to print
hmmm..well..sounds like drivers went in badly. if it's still an issue try this link.
http://tinyurl.com/6qcpgy
Jul 23, 2008 | Samsung ML 2010 Laser Printer
Dell a940 all in one printer
hmm..ok..if the test page is good, then it's in the drivers. get new ones, remove old ones first, re install try again.
Jul 21, 2008 | Dell A940 All-In-One InkJet Printer
Computers & Internet Logo
512 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
