Question about Sony PlayStation 2 (PS2) Console
PS2 - spins disk, stops spinning, won't progress
That is a little over my head.  Is that easily fixed or is it not worth the money - we can get a used one for $80 at GameStop store.
  • 38 Answers
It is easy to fit its just all the screws on the way to swapping the drive is connected to the board with a driver cable wich slots in and out. i have a old style ps2 works fine dont use it any more thow same is a uk version
Posted on Jun 24, 2008
My PS2 slim wont spin a disc it takes you to the game settings but nothing else
Well has it been dropped? If so more then likely the guide rail fall out of place and can easily be poped back in place. A good way to see if its your laser or guide rail is to fined the hole that when the lids closed this pin goes in the hole so the ps2 knows the lids closed and stick a piece of paper in that hole with lid opened. Now it should act like the lids closed. See if the laser produces a red beam or strange noises. Maybe even the little black piece at the back that stops the disc from spinning isnt working right. But dont get worried as theres a pin on the lid that makes the black piece pull back from the disc when lids closed so it might be stopping disc from spinng while its open. Several diffrent solutions need to know how you know its not spinning. If your just putting your head to it and cant hear it spinning then you will need to trouble shoot.
Nov 21, 2010 | Sony PlayStation 2 Slimline Console
The disc won't spin
Hi, It could be one of 2 things, either your laser is on its way out or the motor in the dvd drive has run out of lubricant. The latter is quite obvious as the drive will be noisy when spinning!!!, if ur tech savvy and are capable of doing so, remove the drive from the xbox and open up the drive casing, the motor is situated under where the disc sits on the little black disc.
There are 3 screws holding the motor in place, remove them and with gentle pressure pull the black section from the motor, clean thoroughly then place a couple of drops of wd40 or three in one oil onto the shaft. Re-assemble and that should fix your problem.
Apr 12, 2010 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slim disk only spins if door is a little bit open, I even put something on it so that it won open or shuts completely, because if it does, then it doesn't work,for reference, it was...
tray problem can be solved by opening the ps2
1. unscrew all the screw open the body
2. on the upper body u can see a spring on the tray
just clean the spring (dust particles)
3.cover the tray check whether it is working
Mar 22, 2010 | Sony PlayStation 2 (PS2) Console
What do i do if the thing that spins the disk is not spinning?
see if there is anything stuck in the spinning thing any little thing
Feb 15, 2010 | Sony PlayStation 2 (PS2) Console
My sons ps2 fell on the floor now the disk wont spin how can i fix it
quite honestly with todays advancing technology fixing a ps2 is not worth it. buying a new or preowned one could in fact be cheaper. so i would opt for that as fixing it is more or less an unviable option
Nov 16, 2009 | Sony PlayStation 2 Slimline Console
PS2 stopped spinning.
Laser issue is a commom problem on the ps2.The laser actually is controlling the spinning as well on ps2 machine and on the new ps3 too.
When the disk start, the spinner receive a kick back from the laser and after then that start the normal operation.
If the laser don`t send any impulse to the spinner the machine recognize a danger situation ang go on protection and stop the spinning process.
Replacing your laser will certanly solve your problem.
Don`t forget to rate your experience
Nov 29, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 Disk won't spin unless pressure applied
i had the same problem and i could fix it.
but you i'll have to open your ps2, and then you will notice a little black switch in the on the top of link image:
http://www.richspsxparts.com/howto/lidclosed.jpg
now, open the switch (you i'll see a little wire metal inside) clean the inside part of the switch, and "bend" a little ( til you can make sure that will make contact when the lid is closed) and then close the switch.
sorry for my bad english. =P
i hope this help.
Nov 19, 2008 | Sony PlayStation 2 Slimline Console
many ps3 fail with the lens replasing the drive would be a good way to go
Jun 24, 2008 | Sony PlayStation 2 (PS2) Console
Slim model - spins disk, but does not read.
if your not lay the console down and run a disk
My ps2 game disks won't spin
I can fix your ps2 for you for a fraction of the price of getting a professional to do it. My friend had the same problem its easy to fix
Feb 08, 2008 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 (PS2) Console Logo
53 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
