Question about Lakewood HV 18-c Floor / Box Fan
Need help troublshooting floor fan problem
I have a lakewood floor fan, it use to work normal then I would have to give it a minute to warm up before the blades will spin, now its to the point that it doesn;t even do that.I took a look at it and it seems like there's some type of transformer or converter box attached to it but it don't know whether or not to replace it. what shall I do?
  • gradyb Jun 28, 2008
    I have floor fan w same problem.
    I thought it was the thermostat defective.
    I have not used fan enough to think that brushes would be worn out.
    Ssurely a sharp fan repair shop should have a generic replacement brush.
    Very good fan while it was working.
    Champion:
  • 254 Answers
This problem is caused by worn brushes, these are probably not replacable. You could replace the motor but you will have more money tied up in that then replacing the fan.
Posted on Jun 25, 2008
Can I order new "feet" for Lakewood box fans
I searched for your solution. This is the closest I can find. This is customer service for Lakewood.
https://secure.jardenstore.com/ContactUs.aspx
Another solution if the above does not work. You could make a couple of feet from some wood as well.
Feb 06, 2011 | Lakewood 101 Floor / Box Fan
Are replacement motors available for these fans? Lakewood HV 18 Lakewood HV 21 Lakewood HV 21T
mcdevito75 here, If the fan is not too old I would figure yes, but a replacement motor will cost as a new fan, if not more, then you have to install and the blades are a presss fit to the motor.
Jul 27, 2010 | Lakewood HV-18 Floor / Box Fan
Need to rewire Lakewood Fan
wires should be color coded. You can go to the hardware store and pick up some crimp connectors
Jul 07, 2009 | Lakewood 007 Floor / Box Fan
Need help with fixing my lakewood floor fan.
try cleaning it and put oil especially at the base of the shaft.then try wiggling the shaft for bushing tolerance.if you feel the shaft wiggles to wide, then you'll need to replace the bushing and the shaft.but before anything else check the thermal fuse.it is found on the motor itself or try to borrow a tester with resistance measurement to check for continuity of the winding by connecting the probes with the plug, one each terminal.then turn the fan on.the pointer should move if its ok, unless burn out.if not.then the thermal fuse blow-out.
May 28, 2009 | Lakewood HV 18-c Floor / Box Fan
Cleaned a fan, now it's broken!!!
Is this the speed switch itself? These multi-speed fans have 4 or 5 wires which come from the motor which go into the speed select switch. The wiring may have the ends stripped, and this stripped end just pushes into the hole on the switch, and a little metal piece grips that stripped end.
Anyway, one possibility is to contact the manufacturer- look on their website or give them a call, see if a tech can give that info. Another poss. is to locate an identical fan and note the wiring locations on it. You can also experiment trial and error, though caution needs to be exercised here.
Jul 31, 2008 | Lakewood HV 18-c Floor / Box Fan
Lakewood floor fan
most likley the set screw that secures the blade to the motor is loose.
Jun 09, 2007 | Lakewood HV9 Floor / Box Fan
Lakewood 200I Floor / Box Fan
The fan blade just pulls off. I have a Lakewood 200/1PG and my grills are installed with phillip head screws.
May 27, 2007 | Lakewood 200I Floor / Box Fan
Lakewood HV 18-c Floor / Box Fan Logo
284 people viewed this question
Top Lakewood Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
