FixYa.com
Tags:
1999 Jeep Cherokee
Where is the crank sensor located on a 99 jeep... (by 2 users)
posted by 6e0r9e on Jun 24, 2008
havin problem findin the crank sensor..please help
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Aug 12, 2008
where is the cranck sensor on a grand cherokee laredo 4 L ENGINE 2001 thank u in advance
Best Solution
posted on Jun 24, 2008
FixYa! (100)
leetamara
Rank:Guru Guru
Rating: 88%, 251 votes
Your crank sensor is located between the engine and the trans. From the pass. side. look behind the engine and you'll find a wiring harness that goes to a sensor that is installed in the bell housing A 10mm bolt holds it in place. If you're replacing the sensor, make sure you look at the wiring harness that goes to it. The harness likes to come apart.
Rating Locked! (?) 6e0r9e has rated this solution as FixYa!
Can you Help with these Cars problems?
1999 Jeep Cherokee
Indicator light
One of my indicator lights is... Answer This...
1999 Jeep Cherokee
99 cherokee idle issue
I have a 99 cherokee with 4.0.... Answer This...
1999 Jeep Cherokee
blower motor
replaced blower motor and still... Answer This...
1999 Jeep Cherokee
98 Jeep Cherokee Laredo 4X2...
I am having problems w/ my 98... Answer This...
1999 Jeep Cherokee
DISTRIBUTOR CAP WIRES
plz help i replace the cap npw... Answer This...
Repair Service
Find Car Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
