Question about WatchGuard Technologies WATCHGUARD TECH FIREBOX SSL 20 TUNNEL PCK VPN GATEWAY TUNNEL PACK - WG018012 Firewall
Wireless Config for XP OS with Firebox Edge network firewall
I need help creating a connection from a laptop running XP to a nework that is being broadcast from my firebox edge firewall. It is a masked network. I have all the login info but my wireless settings aren't correct on the xp and it keeps showing a successful connection and then dropping it.
How can I fix this?
    Genius:
  • 1,142 Answers
Hi
Any help please let me know and sorry about the chat window not responding for me
Posted on Jun 24, 2008
I have a bsnl type 2 modem with wireless connection i want to block certain sites like orkut facebook in my laptop which has a redhat linux os.please help me
i don think there will be url filtering options on ur modem/router.
u can download sunbelt firewall to ur pc(Linux Platform)
using this u can block the url's u wish.
If u need to block the websites on the whole for total network, then u need to place a firewall appliance on the edge of the network after your modem/router
Jul 08, 2010 | Linksys WRH54G Wireless Router
Presonus Firebox doesn't sync up.
1. check the drivers update for you device
This is found at the manufacturers site.
2. See if your device is compatible with the OS (operating system) on your laptop.
3. Check the connecting cable to see if you have a broken wire inside the "strain relief".
The cord at this point will have a puffy part that indicate that there is a broken cable.
Apr 16, 2010 | PreSonus Firebox 6x10 External Sound...
I have a Watchguard Firebox x10e and i can not log into it
To recover your Firebox X Edge e-Series device, you must first reset the Edge to its factory default settings, and then FTP the Edge v10.x appliance software to the Edge.
To set the Firebox X Edge e-Series to the factory default settings:
  1. Disconnect the power supply.
  2. Hold down the Reset button on the rear side of the Edge.
  3. Connect the power supply while you continue to hold down the Reset button.
  4. Continue to hold down the button until the yellow Attn light stays on. This shows you that the Edge was successfully restored to the factory default settings.
    This process can take 45 seconds or more.
To FTP the Edge v10.x appliance software to the Edge:
  1. Copy the Edge v10 upgrade file (yakfw.sysa-dl) to the root of your C: drive.
  2. Edit the network settings on your computer so that it is part of the 192.168.111.0/24 subnet.
  3. Connect your computer to any of the LAN interfaces on the Edge.
  4. Open a command prompt.
    To open a command prompt, select Start > Run. Type cmd and press Enter.
  5. Type ftp 192.168.111.1 and press Enter. When prompted, enter the user name admin and the password admin. Press Enter.
  6. Type bin. Press Enter.
  7. Type put yakfw.sysa-dl. Press Enter.
  8. Type bye. Press Enter.
  9. Type exit. Press Enter.
    The command prompt window closes.
  10. Power cycle the Edge.
Oct 01, 2009 | WatchGuard Technologies WatchGuard Firebox...
Can someone help mee?? I just got a used laptop
Hi! some laptop have a built in wireless network card.. some dont have.. check first if the laptop have a built-in wireless nic. if there is one.. some of this wireless nic use the built in software so that you can connect wirelessly. you can just turn off that software and use the windows xp wireless zero config.. to turn on the windows xp wireless zero config, sometimes there is an option if you turn of the software for the wireless nic but if there is no option, you can click on start and then select run and from the box, type services.msc and it will show you all the services for the computer and scroll down to the button and you will see wireless zero config and its off or disable just right click and it will give you the option and enable it.. this will connect you wirelessly without any problem..
Jul 12, 2009 | Belkin (F5D5231-4) Router
How can i turn on my wireless capability, my lap top is aspire 2930z
there must be a wireless switch present on either the side of the laptop or near the keyboard.
another method is:
for windows xp: start->run-> type services.msc and press enter-> find wireless zero config-> right click on it and click restart.
for windows vista type the same command in search bar in the start menu and search for wlan szero config and restart it.
Jun 30, 2009 | Acer Aspire 4520-5582 Notebook
Unable to activate wireless lan
TRY GOING TO START, START SEARCH TYPE WIRELSS DEVICE
LOOKE IN DEVICE MANAGE FOR WIRELESS FOLDER
INPUT DEVICES
AS SO CHECK THE FOLLOWING FOLDERS ALLOWING COMMUNICATION BETWEEN THE LABTOP AND THE WIRELESS DEVICE AND THE COMPUTER.
NETWORKING AND SHARING FOLDER
PROBLEMS AND REPORTING
SECURITY FOLDER
SYNC CENTER IF YOU HAVE ONE
WINDOWS DEFENDER
WINDOWS FIREWALL
THE LAST 2 PROGRAMS IN THE LIST ABOVE CAN STOP THE DEVICE FROM WORKING.
YOU WANT MORE HELP I WILL HELP YOU IF YOU HAVE THE SITE CONTACT RODGANDYSR@GMAIL
ROD
May 12, 2009 | IBM TP R51 - P M715 1.5GHZ 256MB 40GB...
Remote Assistance Firewall Issues
Use Crossloop. Each session is encrypted and doesn't require turning off firewalls in your routers. You will have to give it permission to run in Vista and XP, but it works and I've used it many times.
If this is what you're already using, go to their help page to resolve the problem.
Hope this helps.
Mar 24, 2009 | Linksys Wireless-G WRT54G Router
Compaq Evo with wpc54g v.1 wireless adaptor
hello!
-- make sure that the wireless settings of your router match the wireless settings if you are using the utility of the linksys adapter
-- make sure also that you dont have any firewall or any security on your computer
-- you may also try disabling the adapter wireless utility and use the wireless xp zero configuration instead.
Apr 12, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Watchguard site to remote offices
What have you done to date, what is the Config on both sides.
Let me know
Aloha
Bob
Jan 19, 2008 | WatchGuard Technologies FireBox SOHO 6...
Setting up a VPN through watchguard
The key with any VPN solution is to make sure that the configurations on both ends match. I am not very familiar with this particular product, but it looks like you need to have the proper VPN licenses installed first. There are two types of VPN you can do. 1) Site to Site - This is where the are two static boxes that you want to create an encrypted tunnel between 2) Remote User access - This is where mobile users connect to a central site over an encrypted tunnel from their home or on the road. Next, take a looks at the User Guide PDF here: https://www.watchguard.com/help/documentation/soho6.asp Chapter 10 tells how to configure the VPN on the Firebox side. You would just duplicate your settings if your doing option #1. Chapter 11 tells how to configure the VPN on the client side. This section would tell you how to configure the client software for option #2. Hope this helps.
Aug 29, 2006 | WatchGuard Technologies FireBox SOHO 6...
Computers & Internet Logo
181 people viewed this question
Top WatchGuard Technologies Computers & Internet Experts
David Payne
David Payne
Are you a WatchGuard Technologies Computer and Internet Expert? Answer questions, earn points and help others
