Toys Logo
Posted on Nov 27, 2010
Problem is with sky player it says error occurred try reloading page, which I do but nothing works
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
322
Points
I had reset my computer to factory settings now i can not watch films on sky player or sky 1....?
Cant get sky email
red padlock is the web page is unsafe. you may have something blocking your internet access to sky. something like java not working correctly. try a different browser.
2answers
3helpful
3answers
Error code 0701/8000/4005 (sky player) sky movies on xbox
Yeah I'm now stuck to and the net has nothing coming up besides this query. Sucks
Every time i try to start ub funkeys i get an error message that says "error occurred at application start". Tried reloading and installing the patch, rebooting all to no avail
ub funkeys needs Adobe flash player installed, it could be your problem. It seems not a software itself problem since you have tried installing it several times.
HAve you tried in another PC? Which O.S. do you have?
Funkeys dont work under Windows seven, the software was developed for XP and there is no drivers for W7.
Recovery Tool not working
format player then use recovery tool you have a corrupted file that keeps affecting the rebuild.
2helpful
Creative zen microphoto v0.0.65
If a problem is occuring with the firmware, then just go onto the CREATIVE ZEN website /www.creative.com and select the model of your creative mp3 player.. once you have selected the modell it will then scan your mp3 player to check what it is required and then reccommends the downloads listed. However it is vital that your mp3 player is connected to your pc via usb lead.
3helpful
2answers
Rca m4204-a
Fatal error on RCA Opal:
What do I do if I experience a Fatal Error? How Do I reset my Opal?
The Opal has a reset hole on the back of the unit in which a toothpick (non metallic) can be inserted to reboot the player. If this does not work, I suggest that you reformat the player by using the Windows format command on the unit. To reformat the memory:
Right click on the device within the Explorer or My Computer window
Select the format command (full format) to reformat the internal memory of the device.
Reinstall the firmware from http://download.rcaaudiovideo.com/downloads/opal_fwutility_v2.3.0.exe
RCA Opal - Stuck on "Initializing"
Go to this website to reload the firmware:
http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=1415&p_created=1202430585&p_sid=CwOaz8ej&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTIsMTImcF9wcm9kcz0wJnBfY2F0cz0wJnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1pbml0aWFsaXppbmc*&p_li=&p_topview=1
Note: websites are subject to change - if you go to http://www.rcaaudiovideo.com and go to the page for the RCA Opal m series, you can also find the firmware reload on that page.
-Tha Mp3 Doctor
WINDOWS MEDIA PLAYER 10 WILL LOAD BUT WILL NOT RESPOND WHEN I WANT TO GO TO LIBARY OF STORED MUSIC. TRYED UPDATES, RELOADING, REINSTALLING , NOTHING WORKS , NO ERROR MESSAGES EITHER, PLEASE HELP...
Reboot system in safe mode. It will ask to restore to previous restore point. Try to select restore point before you have installed windows media player 10. Reboot the pc and then try to install media player 10. It will be better if you run scandisk to fix file system errors. Or you can use any tools for fixing file system & windows system registery error like System Mechanic, Symantec Windoctor.
Thanks,
Vksr.
Problems with turning on
Sounds like it may be the index in your Music Library. Try going into Recovery Mode the routine way; remove battery(are they charged and good?), hold power switch to ON, replace battery, release power switch when the Recovery Mode screen appears on the screen. Run Option 1 CleanUP, after it completes run Option 4 Restart/Reboot. You will get a Rebuilding Library screen when it reboots, that's normal, then it should go back to your startup screen. Good luck and let us know what happened
Top Sky Toys Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
NOEL
NOEL
Are you a Sky Toy Expert? Answer questions, earn points and help others
