Question about Pioneer DEH-P3100 CD Player
Volume boosts to 30 and all buttons become useless.
My Pioneer DEH-P3100 is malfunctioning. The volume started randomly boosting to max (30) and then all the button on the console would become useless. Now it seems permanently stuck this way and I can't do anything but connect it and have the music explode my eardrums. Can you help me?
  • 5 more comments
  • jetsfan01068 Aug 14, 2008
    My Pioneer DEH-P3100 is malfunctioning. The volume started randomly boosting to max (30) and the hole thing froze!
  • askate4food Sep 13, 2008
    My volume on my deh-p3100 randomly spiked to full blast when i turned it up once and wont go back down.
  • Andrew McCollum
    Andrew McCollum Oct 21, 2008
    Same problem, however, when I pull the head unit from the car and hook ip up to a battery on my workbench, no **** problem occurs. Ground loop or surge knocking out the faceplate IC perhaps?
  • rlancas Nov 02, 2008
    I have the same problem, one of the kids turned it up all the way and now none the Buttoms work. Can't tun it off, down, etc...
  • Anonymous Nov 25, 2008
    Same exact problem. Now my eardrums are practically dead...
  • Anonymous Jan 09, 2009
    I can do anything whith my radio the botton dosn't work.
    Please can you help me,teel me wath shoud I do.
  • 462 Answers
This cud probably be a blown up resistor or u must replace the sound IC.... not exactly sure if its the Amp IC.. if u have knowledge on the circuits then proceed..
Posted on Aug 03, 2008
My volume on my Galaxy core prime is set to max can I boost it to make it louder
the volume that you have is for the ear
try going to settings and boosting ring tone volume
Sep 07, 2016 | Samsung Galaxy Core Prime G360M/DS -...
Adjusting your gain for your amplifier, or amplifiers
I contacted JBL, and Pioneer about the RCA outputs of the DEH-P5800MP. I got a question answered by JBL that you should gain your amplifier, or amplifiers at half of the Head Units volume, in which case the 5800 model has a max volume of 62. I would assume that this goes for any unit since I didn't give JBL the model or brand, which indicates that they are giving a tip on every, or most units unless specified. You can e-mail the manufacture on what unit you have just in case yours is different. I found after a good conversation with the technical support guy at Pioneer that you should turn your volume up to 25-30 (25 for your loudest CD, and gain it from there. I told him that I was an audiophile and he suggested that I could gain it at 45 for my lowest recorded CD. I have been installing and gaining systems at 3/4 volume, or if the max volume was 62 then I would gain my lowest recorded digital CD at that volume. I was amazed that JBL had an answer for probably 90% of the head units, and I have learned something new. I was under the assumption that the higher the volume the more voltage the RCA's put out allowing you to be able to have your amp gain at a lower level. From my experience of 12 years, hearing both companies say roughly the same thing it is apparent that Pioneer units with a 2 volt output should be gained at the 25-30 volume range(probably for your lowest recorded CD. I have CD's that are pure digital and bass CD's and CD's that are recorded louder (like techno music, or alternative music) If you know what you are doing, and can hear distortion, like I can, the tech said that I could gain it at 45 for the lowest recorded CD. This allows your lowest recorded CD to be played at max volume at 30-45, and your loudest CD's would be at peak volume before 30, or 45 if you choose that route. Keep in mind that less power blows speakers before more power does. That is the best advice I can give, and I will adjust my system accordingly to there recommendations. Thank you
on Sep 08, 2007 | Pioneer DEH-P5800MP CD Player
How do I set the clock on my Pioneer DEH-P6200 cd receiver?
With the vehicle on, turn OFF the radio. Next, Press the Volume and hold the VOLUME knob. You should see LANGUAGE on the display. Scroll the VOLUME knob until you see CLOCK SET. Pres the VOLUME knob and the HOUR will start flashing. Scroll the VOLUME knob to set the hour then Press it to set the Minutes. When you're finished. Turn off the radio, then turn it back on. When the radio is in use, the Radio Station will scroll on the display, then the Artist information, then after a few seconds (20-30), the Clock will display.
Jan 14, 2011 | Pioneer DEH-P6200 CD Player
Audio settings for pioneer DEH-P3100UB
The q1w and all that- is a way to fine tune your eq settings: the q means "frequency" the w means wide and the n means narrow. if you choose to boost your lows at 125 hz which is a low midbass the q selection you choose will focus more on the frequencies very close(narow) to that frequency. if you choose a w setting it will spread the boost to frequencies further away(wider) from the center frequency(125hz) Dink around with it and you will notice the way it contours the sound a little. The different numbers associated with the lows mids or highs are the frequencies that you want to boost when you're adjusting your sound-example if you turn up the bass and it starts distorting your speakers = go into settings 2 and change the "lows" Q to a higher frequency(change 80 hz to 125hz) and that way it wont muddy up your sound quite as bad if at all
Jan 15, 2010 | Pioneer DEH-P3100 CD Player
My speakers shut off at high volume and I have to turn the unit off to get them to function again. What's wrong with my head deck? It's a Pioneer deh-p3100 and I've heard of someone else having the same...
Check speaker wires for short or touching. Try unhooking one speaker at a time then try it. If it doesnt do it on one that speaker/wiring is your pulprit.
Nov 15, 2017 | Pioneer DEH-P3100 CD Player
How do I remove a Pioneer DEH-P3100
Remove the plastic trim ring, and it reveals a slot on either side for pioneer chassis release keys.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 12, 2009 | Pioneer DEH-P3100 CD Player
Pioneer deh-p7500mp all butons quit working except volume
Is it a flip-down face, if so the contacts often become dirty, or out of line.
Jan 17, 2009 | Pioneer DEH-P7500MP CD Player
AUX input on Pioneer DEH P31000
There is a plug on the back called an IP-BUS. You should be able to hook the ipod directly up to that with a simple homemade adapter. I built one for mine and it works fine.
Oct 07, 2008 | Pioneer DEH-P3100 CD Player
Pioneer deh p2000
stuck up voulume buttons. you need to open the head unit and locate that defective volume switch. sometimes these micro swtches can be opened up and cleaned. but this is requires really steady hands.
Apr 20, 2008 | Pioneer DEH-P2000 CD Player
Check none of the buttons are stuck in. Try pressing the reset button. I think it is bottom right and recessed in a hole. The unit should be on and you'll need something pointy like a pen or toothpick. If you cant find the reset button, disconnect the car battery for a minute or two. If that doen't work, then it will probably need repair.
Sep 05, 2007 | Pioneer DEH-P4100
Pioneer DEH-P3100 CD Player Logo
200 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
