Removing/replacing dvd rom drive
How about removing the DVD-Rom drive from the same Sattelite laptop?
  • jerryill Jun 24, 2008
    Many thanks Bill..... both problems. I thought the hard drive was the floppy at first...... duh. appreciate all your help.
    best Jerry
  • jerryill Jun 25, 2008
    St. Bill............... LOL
    Problem Solver:
  • 10 Answers
Hi Jerry
I have written down steps on how to remove the DVD-Rom drive for you.
Toshiba notebooks most screws are marked.
F4 - flat-head screw 4mm long
B6 - button-head screw 6mm long
F16 - flat-head screw 16mm long
B8 - button-head screw 8mm long
When you are taking apart a laptop you'll have to deal with lots of screws. Keep everything organized. I keep them in small cups separated easier to find and don’t get lost.
1. Remove the laptop battery
2. Carefully lift off the securing strip at the top of the keyboard.
3. Remove the keyboard securing strip.
4. Remove all screws securing the laptop keyboard.
5. Disconnect the keyboard cable from the system board. Lift the edges of the connector first and then carefully disconnect the keyboard cable.
6. Remove screws securing the power switch board.
7. Disconnect the USB cable from the system board \motherboard
8. Lift off the power switch board.
9. Remove all screw from the support plate.
10. Remove the DVD drive securing screw.
11. Slide the DVD drive to the right and remove it.
12. Slide in the new DVD drive and follow this backwards.
Hope this helps it is not hard just have to take time an becareful when removing the securing strip at the top of the keyboard to get to screws.
Any questions I will be glad to help answer for you.
Posted on Jun 24, 2008
  • William Fyler Jun 24, 2008
    Dear Jerry
    No problem at all glad to be a help and if I can be any time again just email here or you can direct at
    And thank you for keeping posted here on how you made out I like to now how these turn out. Being I can see it in the works or do it.
    Take Care
  • William Fyler Jun 27, 2008
    Do not feel bad about getting floppy drive confused with harddrive, today someone called me with new laptop they brought at bestbuy last night and did not how to open the lid when they got home lastnight
How to repair dvd rom sir i have a problem with my laptop the problem is my dvd drive does not work and not read any dvd or cd plzz help resolve my problem i shal be very thankful to you my laptop...
Try to restore the laptop to prior date when the DVD ROM worked.
Try to delete the DVD ROM Drivers, and go to to download the latest drivers and install.
If this doesn't work, the DVD ROM may have to be replaced.
Feb 18, 2011 | Computers & Internet
My Toshiba Satellite 1805-S204 turns off when i'm trying to open DVD-ROM bay. Sometimes i can open it but than notebook turns off when i'm closing DVD-ROM bay. I want to disassemble 1805-S204 to find out...
I suspect, if you haven't got it working on the AC adaptor when this happens, that maybe the battery is low power. If it does it when the AC adaptor is being used then I think you are right, the DVD ROM is faulty.
Remove the battery and AC adaptor.
Remove the Memory cover.
There is a singel screw that holds the DVD drive bay in. Remove the screw and pull the drive out.
Replace the drive with and IDENTICAL model and that should be that.
Hope this helps.
Nov 06, 2010 | Toshiba Satellite 1805-S204 Notebook
I have a laptop that doesn't have eject button for slot cd player
go to Dektop / My Computer
right click
u will c all the drives....i mean..... c: d: etc
locate ur CD/DVD rom drive,..letter...d: or e: etc..
select ur CD/DVD rom drive
right click and chose option Eject...
u r set...
Dec 20, 2009 | Toshiba Sattelite A105-S2051 Notebook
My media player does open and play in my Sattelite M200 laptop
You need to install the codecs,
and dowload from there, use the codec packs (xp codec pack or vista codec pack) I used both on my 2 laptops and they work fine.
May 22, 2009 | Toshiba Satellite A100-S8111TD Notebook
My dvd/cd rom is not opening, checked hardware, not even listed
just check your dvd writer is open or not open because the some time not open the dvd driver then not detect
fist of all remove the dvd rom and reinstall because the some time remove the dvd drive and after reboot the laptop and check ..............ok
Apr 08, 2009 | Computers & Internet
Old DV-rom replaced and not working properly
do you have the software installed to watch movies ? and check dvd for scratches , and check lenses and everything on DVD-Rom
Jan 28, 2009 | Toshiba SD C2512 (SD-C2512) Internal DVD...
It sounds like you need to replace the DVD Rom itself.
They do go bad without warning.
A DVD Rom is not that expensive and should take about 5 min to replace rather easy job.
Happy Holidays
Dec 19, 2008 | Compaq Presario Notebook
A DVD-ROM problem
Find a technician who can do it for you - or if you are conversant with computers you get an eternal dvd rom Drive and use it. Have you tried the floppy drive if your computer has any? or the flash disk?
please try one these options.
Dec 31, 2007 | Toshiba Satellite A60 Notebook
Teac dvd rom
Dec 01, 2007 | Teac (DV28E) Internal DVD Drive
Removing the DVD-ROM drive
hi the removel of the dvd drive is easy as taking out the battry 1. Remove the battery from the bottom of the laptop 2. Make sure the laptop is NOT plugged in. 3. There is a release button for the CD/DVD ROM drive on the bottom of the laptop, simply press and hold the release switch and pull the CD/DVD drive out. replace it with your new 1 good luck
Apr 06, 2006 | Toshiba Satellite Pro A10 Notebook
Computers & Internet Logo
156 people viewed this question
David Payne
David Payne
