Question about Samsung LN-R328W 32 in. HD-Ready LCD Television
Samsung LA32R71B I bought a Samsung LCD TV 32" in Dubai, had it shipped to the phillipines, after 3 days of use the unit just died, it seems its on standby mode, red light will turn on then it will blink for five times and then just turn off. The unit itself will not turn on. I know basic electronics troubleshooting, I tried to troubleshoot the power supply but the power supply is working perfectly, Do you have any suggestion on this problem? pls heldp
  • MehrdadMirsa Aug 14, 2008
    i have the same problem
  • Samsung Master
  • 3,859 Answers
First of all what area are you living in in Philippines 220v as there is voltage rating differences in Dubai
Djibouti 220v Dominica 230v Dominican Republic 120v Dubai 230v
64 other voltages. 50Hz
the board will be set for country of origin, this could mean the power board can be getting more than the ratings need, there will be voltage regulating chips on the power board, main voltage can handed depending on the chip installed up to 600 volts but the other parts cannot handle low voltage or high voltage, this could mean a spike in voltage may not blow but it may weaken the voltage out. i.e capacitors- voltage regulators or even diodes. these have to be checked.
Posted on Jun 26, 2017
  • 3 Answers
SOURCE: samsung LE23R87BDX LCD TV turns off after a minute
clicking sound is coming from the relays in the power supply. definitely the problem is coming from the power supply, better change it
Posted on Jun 26, 2008
SOURCE: samsung lcd tv power problem
Fixya.com ROCKS!!! THANKS to billn352, lenmatin, joeymn62 and Samsung ownr for your advise and help in getting our 2006, $2,000 paperweight to work. The Geek Squad told us screen burned out and would cost over $1,000 to repair, not including labor. Although my husband builds computers he never worked on circut boards. We had nothing to lose, so per your direction we opened the back of the TV, saw the slightly bulging capacitors, ordered the new ones and replaced the old ones. Soldering was a little scary but we took our time and removed the old solder and installed the new capacitors and re-soldered. Oh, miracle or miracles!!! It worked. TV is now working as intended and not a papaerweight!!! Thanks again for all you help and guidance. Take that Geek Squad!
Posted on Mar 30, 2009
  • 304 Answers
SOURCE: I cannot get the tv to turn on. The red standby
You either have a bad T-Con bd or a bad Main bd. Have a trained samsung troubleshoot the set.
Posted on Jul 17, 2009
  • 92 Answers
SOURCE: My Samsung LCD TV will not turn on, it just clicks
A Replacement Power Supply.
Parts: £80 - £110 depending on the model.
Labour: £40 (ish) little bit more with a 90 day warranty etc.
Type your model number into www.chsinteractive.co.uk for the price on a PSU.
Good Luck.
Posted on Sep 07, 2009
SOURCE: Samsung LCD tv - Turns on and off by itself.
Not sure if this is the same problem, but I just moved and set up my Samsung 40" LCD and it has been going off and on by itself with the worst yesterday every 2-3 minutes. After speaking with a friend of mine who is not in the Tv business but just has good common sense, I determined it was likely a bad power strip. The bottom line is I replaced the crappy power strip (which was fully loaded with all 6 outlets in use) with the higher quality one I had in the other room. The problem is gone. I suspect the power strip was failing or real bad quality........try plugging the tv directly into the wall outlet first. hope this helped.
Posted on Sep 18, 2009
Hi! My samsung lcd LA-32A330 takes a few minutes to turn on. We bought it on July 8. 2008. Hope you could help us. Thank you
Had the same issue, your circuit board is dying. You will need to get it replaced it should be aroudn $150. Check angieslist for a reptuable tech.
May 03, 2011 | Samsung LA32A450 32 in. HD-Ready LCD TV
Why is my new samsung lcd 32 inch getting on and off again and again it self? and a voice it coming from the back part too.?
Under a year,this tv was bought?Tv still have warrenty,call Samsung for warrenty repair.Not.Tv power on have flashes of pictures,few sec.than dies,have only sound left?Yes.Ur tv have dead 1 or 2 long board call the LCD inverter boards.These 1 or 2 long LCD inverter boards help the LCD screen to have a backlight to produre a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 LCD inverter long boards for the replacement.
Aug 09, 2010 | Samsung LN32A550 32 in. LCD TV
When you turn on the television when it is on stand by the television remote it clicks rather than once when I first bought the tele it is now 7 - 10 times. Once on and warmed up then it goes off and on...
When you buy a samsung, you buy a LED TV with a panel manufactured
by the company "S - LCD" which belongs to 50/50 % sony and samsung.
The S - LCD company is fully driven under samsung engineering.
Today, sony seems to buy their panels from "sharp corp" and trying to
seperate from samsung due to the cold war (high competition ) between
them.
Just go for the samsung UN32C6500 32" 1080p LED HDTV.
Theres no better picture quality you can buy for 32".
Good luck...
Jun 14, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Buy Samsung LN32A550 32 in. 1080p LCD HDTV Free shipping Order Today! [Click Here!] Samsung LE32B650T2 32-inch Widescreen Full HD 1080p Samsung LE32B650T2 32-inch Widescreen Full HD 1080p Save On "Buy...
SPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMv
Jul 02, 2009 | Samsung LN32A550 32 in. LCD TV
Mobile getting switched off often
ME too know
Save On "Buy Samsung LN32A550 32 in. 1080p LCD HDTV" You can Buy Samsung LN32A550 32 in. 1080p LCD HDTV In Stock. Low Prices Samsung LN32A550 32 in. 1080p LCD HDTV Shops & Purchase Online - Quick & Easy.
Discount "Buy Samsung LN32A550 32 in. 1080p LCD HDTV" Free Shipping & Pay No Sales Tax! You can Buy Samsung LN32A550 32 in. 1080p LCD HDTV In Stock Low Prices Samsung LN32A550 32 in. 1080p LCD HDTV Shops & Purchase Online - Quick & Easy.
Jul 02, 2009 | Nokia 6233 Cellular Phone
Samsung LN32A550 32-Inch 1080p LCD HDTV
Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV Free shipping Order Today! [Click Here!]
Save On "Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV" You can Buy Samsung LN32A550 32 in. 1080p LCD HDTV In Stock. Low Prices Samsung LN32A550 32 in. 1080p LCD HDTV Shops & Purchase Online - Quick & Easy.
Discount "Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV" Free Shipping & Pay No Sales Tax! You can Buy Samsung LN32A550 32 in. 1080p LCD HDTV In Stock Low Prices Samsung LN32A550 32 in. 1080p LCD HDTV Shops & Purchase Online - Quick & Easy.
Dec 10, 2008 | Samsung TXJ2879 28" TV
Samsung lcd tv le40r8
if the unit is under warranty call samsung for the nearest authorized repair place. the problem is a bad main board.
Feb 24, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Tv screen not working
will buy your non operating fujitsu p55xha40us i have one with a broken pdp glass please e mail migsdaone@yahoo.com
Jan 05, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
Samsung LN-R328W 32 in. HD-Ready LCD Television Logo
233 people viewed this question
Jerry Greenberg
Jerry Greenberg
